Anybody Know What Front End Sway Bar/Link/Arm Kit This Is?
Postby ri$e*above [OP] » July 10th 2020, 7:10pm
I have a 2002 Safari AWD with a 7 inch Journey lift kit, that is currently running at a 5 inch lift. Can anybody help me identify what parts and what work has been done to the front end? The previous owner had it installed and he had an alignment done. Also, does it look like the ball joints have been flipped? Does everything seem to look ok?
I'm new to Astros/Safaris and lifting, so I'm going through old posts and trying to swat up on info.
Cheers :thumbup:
CURRENT: 2002 GMC SAFARI AWD SLE 'GOLD DIGGER'. 5 INCH LIFT. G80. GT4.
ri$e*above
Fueling (5/8 tank)
Fueling (5/8 tank)
Topics: 17
Images: 4
Van Model Year: 2002
Extra Info: AWD SLE
  • Rough Country upper A-Arm
    by Hillbent » April 20th 2020, 6:38am in Lifted Suspension
    Last post by loganlexow View the latest post
    July 6th 2020, 6:50pm
  • Bouncy Rear End
    by Manny ManVan » May 10th 2020, 4:07am in Lifted Suspension
    Last post by Manny ManVan View the latest post
    May 12th 2020, 1:29am
    74
    September 21st 2020, 8:16pm
Re: Anyone Know What Front End Sway Bar/Link/Arm Kit This Is
Postby augidog » July 10th 2020, 7:54pm
edit, will look at the pic now.
to me it looks like a stock bar (the flattened curves indicate probably hollow) with replacement bushings and aftermarket end links. a standard OE configuration, including the ball joints, looks exactly like my 95 AWD. with my record lately, I should probably add "corrections welcome."
lots of new parts, good for you.
augidog
Topics: 16
Alias (AKA): Augie
Extra Info: AWD High-Top
Postby ri$e*above [OP] » July 10th 2020, 8:10pm
augidog wrote:edit, will look at the pic now.
to me it looks like a stock bar (the flattened curves indicate probably hollow) with replacement bushings and aftermarket end links. a standard OE configuration, including the upper ball joints, looks exactly like my 95 AWD.
Thanks for the reply :thumbup:
Do the ball joints look flipped? If not, should they be with the 5 or 7 inch lift?
What else looks to have been replaced with new parts besides the sway bar bushings and end links?
ri$e*above
Fueling (5/8 tank)
Fueling (5/8 tank)
Topics: 17
Images: 4
Extra Info: AWD SLE
Postby augidog » July 10th 2020, 8:15pm
they're not flipped. I can't advise on lifting. someone who knows will be along shortly, count on that.
I see replacement ball joints and at least one new idler arm.
augidog
Topics: 16
Alias (AKA): Augie
Re: Anybody Know What Front End Sway Bar/Link/Arm Kit This I
Postby Rinny » July 10th 2020, 8:30pm
It appears to me the upper ball joints have been moved to the bottom of the upper control arm.
03Astro AWD/4WD
TorsenDiffs,3:73'S,VettServo
NP236TC
Dual Piston Rear Calipers
GY DTrac 235/85/R16
ARB &/Custom bumpers
2x6x1/4 Rockrails
Rinny
Years of Membership: Rinny has been a member for 4 full yearsRinny has been a member for 4 full yearsRinny has been a member for 4 full yearsRinny has been a member for 4 full years
Topics: 56
Images: 6
Extra Info: 5.7L NP236
Postby augidog » July 10th 2020, 8:48pm
Rinny wrote:It appears to me the upper ball joints have been moved to the bottom of the upper control arm.
I had to do a double take, and you are correct, not flipped but moved down for sure. or, that's what flipped means?
edit...the lowers as well.
augidog wrote:with my record lately, I should probably add "corrections welcome."
I knew it!
augidog
Topics: 16
Alias (AKA): Augie
Postby ri$e*above [OP] » July 11th 2020, 3:42am
augidog wrote:I had to do a double take, and you are correct, not flipped but moved down for sure. or, that's what flipped means?
Thanks :thumbup:
I'm also confused by the ball joints. If they have been moved to the bottom, is that what flipped means? If so, I should be ok with them as they are with the current 5 inch lift?
ri$e*above
Fueling (5/8 tank)
Fueling (5/8 tank)
Topics: 17
Images: 4
Extra Info: AWD SLE
Postby dit » August 2nd 2020, 4:26pm
Yes that is what "flipped" refers to and yes yours have been flipped. Other noticeable changes include new poly swaybar bushings and upgraded swaybar links.
The idler arms look new also; imagine that! 8-)
4" lift, 31x10.50's, NP 242j/c, 4.10s torsen, S10 front disconnect, rack & pinion, rock sliders, skid plate, ARB fridge,100w solar, swing out rear rack with foldout camp table, bed and passenger swivel chair
1981 Toyota 4x4 pu
1974 John Deere 710
dit
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: dit has been a member for 9 full yearsdit has been a member for 9 full yearsdit has been a member for 9 full yearsdit has been a member for 9 full yearsdit has been a member for 9 full yearsdit has been a member for 9 full yearsdit has been a member for 9 full yearsdit has been a member for 9 full yearsdit has been a member for 9 full years
Alias (AKA): photovan
Extra Info: awd 4 inch lift
Postby gavio » August 2nd 2020, 10:18pm
Yes, if the front end alignment comes into spec (camber specifically) than you are good to go with the ball joints flipped.... Only reason to put them back would be if you had too much positive camber and it couldn't be aligned....
gavio
Topics: 77
Images: 4
Return to Lifted Suspension
It is currently September 21st 2020, 8:16pm
Lifted Suspension Forum
Jakob1994
Date: Sep 17 '20
Time: 5:03pm
Attached by: ri$e*above
ri$e*above
Date: Jul 11 '20
Time: 7:10pm
ri$e*above
Date: Jul 10 '20
Time: 7:47pm
ri$e*above
Date: Jul 10 '20
Time: 2:37am
Attached by: Coaster
Coaster
Date: Jun 28 '20
Time: 5:56pm
Users browsing this forum: marchese68marchese68 is online! and 13 guests
