Lift Handling
Lift Handling
Postby TPP [OP] » August 10th 2020, 2:33am
I am thinking about getting the lift so I can install 30" tires when I need to replace them, probably in the next few months.
How do these vans handle with a 4" lift? Do you have to do anything about the caster angle? I'm asking because I did a 4" rough county lift on my jeep, I'm only running 30's and it should be 33's and now it rides horrible and is all over the road and the suspension is super stiff and steering is loose when going straight. Are there any common issues with lifting these vans? I like the way it rides now but wouldn't mind having a lil extra ground clearance.
TPP
Extra Info: SLT AWD
Re: Lift Handling
Postby 97cargocrawler » August 10th 2020, 5:54am
I have 11" of lift and the van has improved handling over stock.
Since your asking for advice mine would be to tackle the problems with your Jeep first. Learn something there before attempting to modify something that doesn't lend itself to lifting easily and has **** handling from the factory. Jeeps are absolutely the most common lifted vehicle in the history of mankind. If you can't perfect that leave the van bone stock. 30" tires aint ****. Teeny tiny lil pieces of rubber. They should feel solid af if you did it right.
:2:
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Re: Lift Handling
Postby TPP [OP] » August 10th 2020, 4:26pm
Thanks. I do need to fix my jeep first. I blew the 4banger engine earlier this year, that's part of the reason why I bought my van lol. Trying to get the replacement engine back in now, then I will address the suspension issue. I talked to a Jeep shop and they told me I most likely need to add steel shims to get the caster angle to 6°.
PS- Your van looks sick.
TPP
Extra Info: SLT AWD
Re: Lift Handling
Postby SportsBoy » August 10th 2020, 7:17pm
I know many people with 4" of lift say the handling is just fine. With a body lift, the handling shouldn't really change at all. Adding in a torsion lift in the front makes the ride more harsh more overall, so they say. People add a rear sway bar as they go higher to reduce body roll.
Mostly with these vans it seems like you need to replace the idler arms as they go and have light truck rated tires so you don't bounce down the road as much.
SportsBoy
Topics: 23
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Re: Lift Handling
Postby Mmusicman » August 10th 2020, 10:43pm
BODY LIFT does NOT affect handling WHATSOEVER!
Body lift has no affect on springs, fronts shocks, steering components, alignment, front drivetrain, suspension in ANY way. All of these parts are connected to the sub-frame... the body is simply spaced higher above it.
My lifted van DRIVES PERFECT! RIDES PERFECT!
No affect at all.
But sitting higher can make you more susceptible to head-winds and cross-winds.
All vans deal with this already anyway... just a tiny bit more when lifted.
Topics: 73
Images: 49
Re: Lift Handling
Postby Leeann_93 » August 10th 2020, 10:59pm
TPP wrote:Thanks. I do need to fix my jeep first. I blew the 4banger engine earlier this year, that's part of the reason why I bought my van lol. Trying to get the replacement engine back in now, then I will address the suspension issue. I talked to a Jeep shop and they told me I most likely need to add steel shims to get the caster angle to 6°.
Did you get replacement upper a-arms for a lifted Jeep? They're readily available for my Liberty from jeepinbyal.com (though I have a set for an unlifted Liberty on mine because it also adds replaceable, greasable ball joints), but he doesn't have anything for Wranglers.
Re: Lift Handling
Postby TPP [OP] » August 17th 2020, 2:20am
My jeep is old, it's leaf springs all around.
TPP
Extra Info: SLT AWD
Return to Lifted Suspension
It is currently March 4th 2021, 1:29pm
Lifted Suspension Forum
Attached by: SportsBoy
SportsBoy
Comments: 28
Date: Feb 15 '21
Time: 3:20am
SportsBoy
Comments: 28
Date: Feb 08 '21
Time: 2:46pm
pmou
Comments: 94
Date: Feb 05 '21
Time: 4:42pm
pmou
Comments: 94
Date: Feb 04 '21
Time: 6:47pm
Attached by: icebrrg3rd
icebrrg3rd
Comments: 28
Date: Jan 22 '21
Time: 4:09am
