So I have been building a 97 safari and handicap van and recently discovered there is just to much rust on the frame to be a reliable off road rig. The vechile only has 80k on the engine and I just did a lot of work including:
Rear HD leafs
3-5” journeys kit
Kyb mono shocks all four corners
30” tires
Complete front suspension steering components
Upper and lower contol arms
Spider injectors
Water pump
Radiator
Steering gear box
Etc.
My only options to salvage what iv’e done is buy another van and swap parts to the new vehicle OR replace the front frame with another AWD.
I’m looking for some advice, what would you do?
Also what years will my suspension parts be compatible with?
I know control arms changed and added a coil spring ant some point. And I’m assuming they did away with the torsion bars. Any advice will help. While buying the vehicle I made a poor choice and was side tracked by the low mileage and high top, but as I got into it. Lots of rust was evident.
