by lupulinshift [OP] » December 11th 2020, 7:02am
by lupulinshift [OP] » December 11th 2020, 7:13am
by AstroOafAdventurer
» December 11th 2020, 7:28am
by lupulinshift [OP] » December 11th 2020, 7:44am
by stent » December 11th 2020, 7:50am
by lupulinshift [OP] » December 11th 2020, 7:52am
by dcsleeper » December 11th 2020, 9:47am
by SportsBoy » December 11th 2020, 3:52pm
lupulinshift wrote:I think I might have just stumbled on an answer. I think I can just drill new holes a couple inches up to mount the shocks? Also, I think I have the torsion keys cranked pretty high but I might be able to slightly level it out a bit more if I go higher.
by lupulinshift [OP] » December 11th 2020, 8:59pm
by sixsix » December 11th 2020, 9:27pm
by dcsleeper » December 11th 2020, 9:34pm
by lupulinshift [OP] » December 11th 2020, 9:36pm
sixsix wrote:Do you have the Van jacked up with the Axle/Housing/Diff just hanging down by the Springs ?
If so, are you not supposed jack up Stuff to reach ? Just wondering and asking...
I did see you had Stands there.
and...![]()
by lupulinshift [OP] » December 11th 2020, 9:40pm
dcsleeper wrote:If you buy shackles and drill higher holes, you can bring it back down to a stock shackle lift height. Then you shock mounts would probably be ok without mods.
If you google 'CA-20 shackles' it will find them straight away. These cost me $28
I tend to not like to change torsion bar settings due to needing alignment after.
by dcsleeper » December 11th 2020, 9:55pm
by lupulinshift [OP] » December 11th 2020, 9:58pm
dcsleeper wrote:" guess I can't use the combination of the shackles and s10 leafs with stock shocks huh?"
You can't use the combination of the shackles and s10 leafs because it is too high for you.
Once you have stock length shackles, I bet the shocks will reach.
by stent » December 12th 2020, 6:52pm
by lupulinshift [OP] » December 14th 2020, 1:46am
stent wrote:rake...crank those torsion bars DOWN!!!king-of-the-road-album-cover-sticker__26534.1539884927.jpg91DWKHJ4qXL._SL1500_.jpg
https://www.youtube.com/watch?v=_9IR8Xw ... 42SUDy16K2
its so close !!!!!!!!!!!! but it's at maximum extension with the van at rest.....mmmm.jpeg
somehow i don't think that this is what JOR intended.....
all kidding aside - measure the compressed & extended length of your rear shocks. go back to the JY before they crush the van you got the springs from, and get the shackles they used to use on your project. while you're there measure the compressed & extended length of the JY van shocks, the previous owner might have done some homework on the suspension & found a shock with better travel range for his/hers modded rear. if you like the looks of those shocks you could get them cheap. if you mount shocks that are stretched out with the van just sitting they will act like suspension travel limiting straps and guarantee a lousy ride. your'e doing all kinds of stuff to your van & learning quick - keep it up & enjoy what your'e doing!!!!!!!!!!!!!
by stent » December 15th 2020, 7:47am
lupulinshift wrote: Really thought I was grabbing stock safari leaf springs haha it's always something. I've been browsing what size wheels to get after I finish the lift, any recommendations?
by stent » December 15th 2020, 8:50am
by lupulinshift [OP] » December 17th 2020, 1:02am
It is currently February 28th 2021, 1:42am
Lifted Suspension Forum |
Moderator: chevy57bert![]() |
Previous topic Next topic |
Sponsors |
