by SilverBullet1997 [OP] » May 16th 2013, 4:22pm
by limon » May 16th 2013, 5:49pm
by SilverBullet1997 [OP] » May 16th 2013, 6:06pm
limon wrote:You might want to order some clips too. I broke a few...
Cheap on EBay
by 97cargocrawler » May 16th 2013, 6:11pm
by SilverBullet1997 [OP] » May 16th 2013, 6:24pm
by SilverBullet1997 [OP] » May 16th 2013, 6:30pm
Me wrote:----- Original Message -----
To: Gerald
Sent: Fri, 03 May 2013 08:26:55 -0700 (PDT)
Subject: Re: 4-5" lift kit L9605-4LK
Have you heard about any kind of vibration occurring after installing this lift from the rear that had to be corrected with Pinion Shims? If so what size pinion shims should I use, I seen some people when they did the 2" lift used a 4º shim.. I am wondering since this is the 4"-5" lift, do I need a shim with more of an angle like 8º?
Any input you may have on this would be awesome, if you have a little information on problems that I may run in to, and what others did to fix/correct these problems that would be great too.
Thanks Gerald
-Kevin
Gerald @ OLV wrote:Hello Kevin,
don't mess with the pinion angle unless you have to. The 2" kits tend to suffer from this problem which is easily corrected with a shim. Determining the amount of degree is a little more involved but not beyond the backyard mechanic. You would measure the angle the yoke at your tranny sits and at the yoke on the pinion. Subtract one from the other for your difference. Not all of them will be alike so it's hard to standardize and say so much lift so much shim.
In your case it is a 4" lift which I have never had a single complaint about the vibration. I think it's because the springs are stiffer than stock and don't let the axle rotate when the shackles are put on. 2" kits use the existing leaf springs on the vehicle which are often sagging already. The front of the leaf flattens out when the shackles are put on which allows the pinion to point up.
So no worries the 4" kit really works nice . Just follow the instructions and you'll be fine. Pay attention to the upper ball joint relocation. It's simple enough but some guys try to avoid it. The wheels will have negative camber if you don't do it.
Your kit will be leaving tomorrow or Monday. We had 5 orders come in before yours so I got a bit swamped. It never rains but it pours.
Good problem though,
Gerald
by 97cargocrawler » May 16th 2013, 6:43pm
by SilverBullet1997 [OP] » May 16th 2013, 6:55pm
by 97cargocrawler » May 16th 2013, 7:08pm
by SilverBullet1997 [OP] » May 16th 2013, 7:30pm
by Corsemoto » May 16th 2013, 8:10pm
by Philly758 » May 16th 2013, 8:57pm
Cheap on EBay
by Corsemoto » May 16th 2013, 9:10pm
by Corsemoto » May 16th 2013, 9:21pm
by 97cargocrawler » May 16th 2013, 9:21pm
by Philly758 » May 16th 2013, 9:27pm
by SilverBullet1997 [OP] » May 16th 2013, 9:58pm
Corsemoto wrote:Silver, the Rancho RS999112 were the first rear shocks I tried for my van as I didn't want to relocate shock mounts. Being that they are the larger 2.75" diameter body, they don't fit. If you hold one up to the lower shock mount, you'll see why, the tube is too large and contacts the rear axle well before you van position the lower mount into position to bolt in place. That is why I went with the RS999147 and relocated lower shock mounts.
https://www.astrosafari.com/viewtopic.php?f=40&t=13131&start=20#p147805
It may work with modified and raised stock lower mounts, maybe not but also your shocks may then be too long and bottom prematurely on compression. Something to think about.
Also, when you install front shocks, be sure to relocate upper ball joints or the upper control arm will contact the larger than stock 2.18" diameter shock body. On a twin-tube design this isn't the end of the world as it is the inner tube the piston rides on but still something to look out for.
by thegreenmachine » May 16th 2013, 11:10pm
by SilverBullet1997 [OP] » May 16th 2013, 11:16pm
thegreenmachine wrote:Lumpy has a thread somewhere where he just cut and bent the bracket up then drilling a new hole higher on bracket.
It is currently January 26th 2021, 4:25am
Lifted Suspension Forum |
Moderator: chevy57bert |
Previous topic Next topic |
Sponsors |
