Longer Sway Bar End Links for Raised Vans
Postby Lumpy [OP] » July 15th 2014, 4:26pm
Hey Cargo, or anyone with a lifted front SUSPENSION (vs just a body lift)...
What length are your sway bar end links?
My front corners have grown so much that the ends of the bar are no longer parallel. I have what I think are 4 1/4" links. I"m guessing I need more like 6 or 6.125.
Is it as simple as measuring to the point where your sway bar would be parallel?
  • Torsion bar adjustment
    by Lowcountry » December 31st 2020, 7:51am in Lifted Suspension
    Last post by Lowcountry View the latest post
    December 31st 2020, 5:26pm
  • rear end thrust angle?? what did i do?
    by Sp3cialNe3dz » September 8th 2020, 1:24am in Lifted Suspension
    September 10th 2020, 7:39pm
    9
    83
    February 26th 2021, 10:49am
Re: Longer Sway Bar End Links for Raised Vans
Postby 97cargocrawler » July 15th 2014, 8:30pm
Lumpy wrote:Is it as simple as measuring to the point where your sway bar would be parallel?
I believe so. I need longer ones too.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby Lumpy [OP] » July 15th 2014, 8:38pm
Anything wrong, do you'spose, with using an appropriate length of DOM tubing and a length of 3/8 hardened allthread? Make it any length needed.
Postby 97cargocrawler » July 15th 2014, 8:53pm
Nope. That's probably what I'm gonna do.
97cargocrawler
Topics: 42
Postby 97cargocrawler » July 20th 2014, 9:06am
How long did you need to lengthen yours? Mine only need an inch or so...hence why I haven't bothered yet. If it needs a significant amount of length it would probably be safer to add some blocks under the sway bar mounts.
97cargocrawler
Topics: 42
Postby Lumpy [OP] » July 20th 2014, 3:55pm
I haven't done it yet. It might only be an inch or two. The sway bar end is touching the bushings at 180* opposite points. It's not really utilizing all of the bushing. I just loosened the nuts a turn and the cornering is dramatically improved. So I'm going to go ahead and build longer links.
I think what I'll do is cut some long, hardened allthread. Put it all together with nuts on both sides of the bushings and their keepers, no tube for now. Then I'll adjust and tune them to the length I want. When I find the ideal setting, I'll measure and cut DOM tubing to fit between the upper and lower bushings.
Waiting for the heat to break (Brake for uncle Bob) before I can do any work on anything. Emassing parts for lots of projects right now. I've got a man cave floor full of steel waiting to be cut, welded, ground, painted.
It's been about 120* in my van when I get in. Metal sitting in the sun for an hour easily reaches 150*.
Return to Lifted Suspension
It is currently February 26th 2021, 10:49am
Lifted Suspension Forum
Attached by: SportsBoy
SportsBoy
Comments: 28
Date: Feb 15 '21
Time: 3:20am
SportsBoy
Comments: 28
Date: Feb 08 '21
Time: 2:46pm
pmou
Comments: 94
Date: Feb 05 '21
Time: 4:42pm
pmou
Comments: 94
Date: Feb 04 '21
Time: 6:47pm
Attached by: icebrrg3rd
icebrrg3rd
Comments: 28
Date: Jan 22 '21
Time: 4:09am
