Solid front axle swap
Postby kcorleyap [OP] » May 7th 2008, 12:24pm
I am beginning to assemble parts for a high pinion dana 44 SFA swap with leaf springs. Does any one have information and photos on a front axle swap? I am not sure where the spring mounts are welded or bolted to the subframe or if any reinforcements are required. Thanks.
kcorleyap
Years of Membership: kcorleyap has been a member for 12 full yearskcorleyap has been a member for 12 full yearskcorleyap has been a member for 12 full yearskcorleyap has been a member for 12 full yearskcorleyap has been a member for 12 full yearskcorleyap has been a member for 12 full yearskcorleyap has been a member for 12 full yearskcorleyap has been a member for 12 full yearskcorleyap has been a member for 12 full yearskcorleyap has been a member for 12 full yearskcorleyap has been a member for 12 full yearskcorleyap has been a member for 12 full years
Re: Solid front axle swap
Postby 9dawgs » May 9th 2008, 1:38pm
Check out this link: [Rule 21 Violation] You can also email Dean. He should be able to give you any info you need for this swap. If you live near him, I would suspect he would even drop by to give a hand :) Hope this helps.
Last edited by AstroAustin on September 26th 2008, 10:01pm, edited 1 time in total.
Reason: This post does not comply with forum rules (Rule 21), the infraction in this post has been removed and this post has been locked.
Jim<><
'99 Astro 4x2, OVERLAND 4" Lift, Rancho RS5000 shocks, BF Goodrich AT TA KO 31X10.50/15, K&N Filter, Optima Red Top, KC Off-road Lighting, Rockford Fosgate RFX 9000
9dawgs
Years of Membership: 9dawgs has been a member for 12 full years9dawgs has been a member for 12 full years9dawgs has been a member for 12 full years9dawgs has been a member for 12 full years9dawgs has been a member for 12 full years9dawgs has been a member for 12 full years9dawgs has been a member for 12 full years9dawgs has been a member for 12 full years9dawgs has been a member for 12 full years9dawgs has been a member for 12 full years9dawgs has been a member for 12 full years9dawgs has been a member for 12 full years
Postby kcorleyap [OP] » March 1st 2009, 9:49pm
Last year a posted a request on a dana 44 solid front axle install. Finally getting around to putting it in. However, the pics and information link to "deans" install is now flagged by rule 21. How do I get this information again? It seemed really good when I looked at it some time ago.
kcorleyap
Postby AstroAustin » March 1st 2009, 10:22pm
Send 9dawgs and private message and maybe he can provide you with information on the front axle swap or put you in contact with Dean.
-AstroAustin
[email protected]
Full FBSS Air Suspension :: Triangulated 4-Link :: Engine Driven Compressor :: 4 Air Tanks :: 1/2" SMC Valves :: Phantom Billet Grill
AstroAustin
Firing on 8 Cylinders (L1)
Years of Membership: AstroAustin has been a member for 12 full yearsAstroAustin has been a member for 12 full yearsAstroAustin has been a member for 12 full yearsAstroAustin has been a member for 12 full yearsAstroAustin has been a member for 12 full yearsAstroAustin has been a member for 12 full yearsAstroAustin has been a member for 12 full yearsAstroAustin has been a member for 12 full yearsAstroAustin has been a member for 12 full yearsAstroAustin has been a member for 12 full yearsAstroAustin has been a member for 12 full yearsAstroAustin has been a member for 12 full years
Topics: 120
Images: 18
Van Model Year: 1988
Extra Info: 4.3L V6 FBSS AirRide
Postby coppermtn » March 10th 2009, 7:12pm
i can get some of my pics up soon. Dana 44 up front with shackles in the rear and spring hangers up front. Its more inboard than the rear sring stock mounts. its a driver drop.
87 4.3 V6 auto. SFA dana 44 ox locked, 5.13 gears, prorock dana 60 detroit rear. Stak 3 speed t-case. Tom woods shafts. 37 inch krawlers.
coppermtn
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: coppermtn has been a member for 11 full yearscoppermtn has been a member for 11 full yearscoppermtn has been a member for 11 full yearscoppermtn has been a member for 11 full yearscoppermtn has been a member for 11 full yearscoppermtn has been a member for 11 full yearscoppermtn has been a member for 11 full yearscoppermtn has been a member for 11 full yearscoppermtn has been a member for 11 full yearscoppermtn has been a member for 11 full yearscoppermtn has been a member for 11 full years
Topics: 13
Alias (AKA): soup kitchen
Postby moparcolt » January 20th 2010, 5:06am
So wher is there info on what parts to use and how to do this swap? I have a 97 I have been thinking about doing this to for a while now and about ready to do it. any pics and info would be appreciated!
Chris
Chris Collier
Huntsburg, OH
1997 astro CS AWD
2000 astro LT AWD
2002 astro LS AWD
moparcolt
Years of Membership: moparcolt has been a member for 12 full yearsmoparcolt has been a member for 12 full yearsmoparcolt has been a member for 12 full yearsmoparcolt has been a member for 12 full yearsmoparcolt has been a member for 12 full yearsmoparcolt has been a member for 12 full yearsmoparcolt has been a member for 12 full yearsmoparcolt has been a member for 12 full yearsmoparcolt has been a member for 12 full yearsmoparcolt has been a member for 12 full yearsmoparcolt has been a member for 12 full yearsmoparcolt has been a member for 12 full years
Extra Info: LT AWD
Return to Lifted Suspension
It is currently October 26th 2020, 1:52am
Lifted Suspension Forum
K-TRON
Date: Oct 23 '20
Time: 6:05am
Date: Oct 23 '20
Time: 5:16am
wilsc449
Date: Oct 21 '20
Time: 3:40am
pmou
Comments: 51
Date: Oct 20 '20
Time: 2:36am
Attached by: Sparkydog
Sparkydog
Date: Oct 15 '20
Time: 12:40am
Users browsing this forum: Yandex [Bot] and 7 guests
