is there an add-a-leaf here?
Postby jamestkirk [OP] » July 9th 2010, 1:41am
purchased this '04 Astro AWD cargo van recently. i'm not sure what the stock configuration is for the rear suspension and whether or not the original owner stiffened it up already. here's a shot of the leaf spring...i counted 4 in there total. is there an add a leaf already?
as you can see the rear of the van is quite a bit higher than the front. obviously, i don't think any work has been done with the torsion bars.
kirk out
jamestkirk
Years of Membership: jamestkirk has been a member for 10 full yearsjamestkirk has been a member for 10 full yearsjamestkirk has been a member for 10 full yearsjamestkirk has been a member for 10 full yearsjamestkirk has been a member for 10 full yearsjamestkirk has been a member for 10 full yearsjamestkirk has been a member for 10 full yearsjamestkirk has been a member for 10 full yearsjamestkirk has been a member for 10 full yearsjamestkirk has been a member for 10 full years
Extra Info: AWD cargo van
Re: is there an add-a-leaf here?
Postby jeephunter16 » July 9th 2010, 2:50am
There is clearly an add a leaf on there haha, would look really good if you jacked up the front to level it out
DRIVE IT HARD
jeephunter16
Years of Membership: jeephunter16 has been a member for 10 full yearsjeephunter16 has been a member for 10 full yearsjeephunter16 has been a member for 10 full yearsjeephunter16 has been a member for 10 full yearsjeephunter16 has been a member for 10 full yearsjeephunter16 has been a member for 10 full yearsjeephunter16 has been a member for 10 full yearsjeephunter16 has been a member for 10 full yearsjeephunter16 has been a member for 10 full yearsjeephunter16 has been a member for 10 full years
Topics: 16
Alias (AKA): Erik
Extra Info: 4.3 AWD LT
Postby icebrrg3rd » July 9th 2010, 2:49pm
Maybe someone will chime in who has the steel leafs, as mine has the mono leaf (fiberglass), but I didn't think a helper leaf jacked it up, just made it stiffer. What do the hangers look like? They might have put on an aftermarket one to raise it up so when it was loaded it didn't sit too far down.
-Andrew
icebrrg3rd
Topics: 50
Alias (AKA): Andrew
Van Model Year: 1991
Postby LEVE » July 9th 2010, 2:52pm
I would think that a VIN check at a Dealer could tell you the configuration. It looks to me that the van has overload springs on it to help carry weight of the cargo. Is it OEM? Don't know. :shrug:
LEVE
Years of Membership: LEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full years
Topics: 18
Extra Info: AWD 4.3L-W
Postby Woodweasel » July 9th 2010, 3:43pm
My 99' Cargo has 3 leafs. The fat bottom one looks like an add-on, from the factory ? ? ? I have seen a few cargos running around that have the rear end jacked up like that. I bet it was an option for like the utiliies companies so they could carry a little more.
Woodweasel
Firing on 7 Cylinders (L1)
Years of Membership: Woodweasel has been a member for 11 full yearsWoodweasel has been a member for 11 full yearsWoodweasel has been a member for 11 full yearsWoodweasel has been a member for 11 full yearsWoodweasel has been a member for 11 full yearsWoodweasel has been a member for 11 full yearsWoodweasel has been a member for 11 full yearsWoodweasel has been a member for 11 full yearsWoodweasel has been a member for 11 full yearsWoodweasel has been a member for 11 full yearsWoodweasel has been a member for 11 full years
Topics: 36
Extra Info: 140K miles
Postby astroturf » July 9th 2010, 3:52pm
Woodweasel wrote:My 99' Cargo has 3 leafs. The fat bottom one looks like an add-on, from the factory ? ? ? I have seen a few cargos running around that have the rear end jacked up like that. I bet it was an option for like the utiliies companies so they could carry a little more.
Good point Wood
I just looked at my 05 2wd pass and I've got 3
Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby Woodweasel » July 9th 2010, 3:57pm
good havin you back......again.
Woodweasel
Topics: 36
Postby astroturf » July 9th 2010, 4:07pm
Woodweasel wrote:good havin you back......again.
What can I say...
Management would not accept my Goodbye Letter.
Plus you know I've read every word since.
Thanks Wood
PS Praise Be to the Delete Button.
astroturf
Topics: 112
Postby jamestkirk [OP] » July 9th 2010, 11:58pm
here's a couple more shots, oh, and yes this was a fleet vehicle for a utility company...
kirk out
jamestkirk
Postby astroturf » July 10th 2010, 12:34am
That is aftermarket...
Look at the spacing in the upper and lower sandwich brackets for the springs. Do you see the space? Remove the smaller Portion of spring, It will just slide out. Get it back to stock or rework the top portion to have full contact with the bottom. It is a weak spot in the axle attachment points. As with anything I say... Just my two cents. Here is a pic of a properly seated sandwich so to speak...
astroturf
Topics: 112
Postby kennyj » July 10th 2010, 2:11am
Nice catch on the bracket, Jim. Yeah, I'd pull them out of there, unless you plan on running your van really loaded. That much rear lift has got to play hell with your handling and front end alignment, and it must ride like a rock!
kennyj
Blue Status (L2)
Blue Status (L2)
Years of Membership: kennyj has been a member for 10 full yearskennyj has been a member for 10 full yearskennyj has been a member for 10 full yearskennyj has been a member for 10 full yearskennyj has been a member for 10 full yearskennyj has been a member for 10 full yearskennyj has been a member for 10 full yearskennyj has been a member for 10 full yearskennyj has been a member for 10 full yearskennyj has been a member for 10 full years
Topics: 41
Alias (AKA): Kenny
Extra Info: 250k+ miles
Postby jamestkirk [OP] » July 10th 2010, 3:12am
oh yea, i get it. here's some more
so at the bottom of the stack is a thick piece of rubber. there are thin pieces inbetween the each leaf and another somewhat thicker piece on the top. so what you guys are saying is crank down the sandwich bracket so they're all tightly in contact with the axle. BTW i'll be using the add a leaf provided to me by overland here in a bit when i do the 4" lift and i'll get rid of that short one. what about creaking/squeeking noises without any rubber? will the sandwich bracket be able to squeeze down enough to make tight contact with the leafs and the axle?
yea, it's stiff, but the shocks are so beat that i'm bouncing around alot and swaying back and forth. not for long...thanks!!!!
kirk out
jamestkirk
Postby Woodweasel » July 10th 2010, 2:20pm
jamestkirk wrote:here's a couple more shots, oh, and yes this was a fleet vehicle for a utility company...
[ https://www.astrosafari.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=18541 ][ https://www.astrosafari.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=18543 ]
kirk out
DANG!!! Disc brakes on the rear!!!! I WANT SOME !!!!! Was that an option?
Woodweasel
Topics: 36
Postby astroturf » July 10th 2010, 2:27pm
3rd Gens Wood, 3rd Gens... 03-05.
astroturf
Topics: 112
Postby Woodweasel » July 10th 2010, 2:51pm
Dang. Learn something new everyday. Now I want a 03-05 ! So they wait till the last 2 years for that and then take it away. Will the rear end out of a genIII slide under a Gen II ?
Woodweasel
Topics: 36
Postby astroturf » July 10th 2010, 2:53pm
Woodweasel wrote:Dang. Learn something new everyday. Now I want a 03-05 ! So they wait till the last 2 years for that and then take it away. Will the rear end out of a genIII slide under a Gen II ?
Sure, But i am sure that there would be a lot more to it than just that.
astroturf
Topics: 112
Postby jamestkirk [OP] » July 14th 2010, 4:55pm
kennyj wrote:Nice catch on the bracket, Jim. Yeah, I'd pull them out of there, unless you plan on running your van really loaded. That much rear lift has got to play hell with your handling and front end alignment, and it must ride like a rock!
well, you know, i like the lift and i will be installing interior cabinetry and stuff and the high top to make it a campervan. i've got Overland's 4" kit and i'm debating on whether or not to use Dan's add a leafs or keep those in there. i've just installed the 2" body lift and cranked the torsion bars and now the front is about even with the back. still have to install the shackles.
is it riding like a rock? hhhmm, since this is my first astro i have no reference. i guess i like stiff suspension!
kirk out
jamestkirk
Return to Lifted Suspension
It is currently January 25th 2021, 7:07pm
Lifted Suspension Forum
Attached by: icebrrg3rd
icebrrg3rd
Date: Jan 22 '21
Time: 4:09am
Attached by: SportsBoy
SportsBoy
Date: Jan 21 '21
Time: 3:24am
pmou
Comments: 86
Date: Jan 20 '21
Time: 4:16pm
Attached by: mglsite
mglsite
Date: Jan 15 '21
Time: 2:02am
sixsixsixsix is online!
Comments: 328
Date: Jan 06 '21
Time: 12:09am
