airbagit shackle fit
Postby pannebreaux [OP] » December 8th 2015, 11:52pm
are they direct fit? i know i read somewhere in here that washers were needed, but it seems i'd be hard pressed to fit a pair of 1/8" washers between the bushings and the shackle.
pannebreaux
Years of Membership: pannebreaux has been a member for 5 full yearspannebreaux has been a member for 5 full yearspannebreaux has been a member for 5 full yearspannebreaux has been a member for 5 full yearspannebreaux has been a member for 5 full years
Topics: 27
Images: 47
Re: airbagit shackle fit
Postby Corsemoto » December 9th 2015, 4:05am
They fit fine without the need for washers, if you get the correct shackles for 2.5" leaf springs and not the earlier fiberglass leaf springs, or other generic shackles with wider spacing.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby pannebreaux [OP] » December 9th 2015, 2:21pm
much appreciation. i've read through so many lift posts i probably confused it with info from an older model installation. wanted to make sure i had all the needed parts before i started.
pannebreaux
Topics: 27
Images: 47
Postby 97cargocrawler » December 10th 2015, 12:54am
You might want to consider replacing the rubber bushings in the main leafs with poly. The rubber tends to squeak a lot and create an unstable feeling. It's really not a fun job though.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby pannebreaux [OP] » December 10th 2015, 3:42pm
97cargocrawler wrote:You might want to consider replacing the rubber bushings in the main leafs with poly. The rubber tends to squeak a lot and create an unstable feeling. It's really not a fun job though.
thanks for the tip. the bushings i have now are fairly new, but i have another set of springs i'll be adding a leaf to that will need new bushings.
i'm going to attempt to make a military full wrap style leaf which will require me putting some heat on the top leaf eyes when i bend the wrap around the eyes so i'll need to replace them anyway. if i have to press a bushing or bearing. i won't use a previously installed part unless it's an emergency.
i installed my airbagit shackles yesterday in about an hour. i got a little over 2" of lift unloaded, but i also have the coil overs helping. i'm sure once i finish my roof rack and put my camping and music equipment plus my hitch hauler tool box in it, i'll lose an inch or more. it rides a whole lot better than it did.
before the van was sitting about 1/2" off the 4 1/2" energy suspension bump stops and it didn't take much of a bump to rattle the whole van when it was empty. when it was loaded it sat on the stops and wasn't as rough but drove a bit squirrely. last night i was hitting holes and bumps on purpose with no jarring side effects.
pannebreaux
Topics: 27
Images: 47
Postby Meterpig » December 17th 2015, 6:32am
I had to use a large crowbar to get my new springs to fit into the airbaggit shackles.
Meterpig
Firing on 5 Cylinders (L2)
Years of Membership: Meterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full years
Topics: 63
Alias (AKA): meterpig
Van Model Year: 2002
Extra Info: Not a minivan
Postby pannebreaux [OP] » December 27th 2015, 5:13pm
Meterpig wrote:I had to use a large crowbar to get my new springs to fit into the airbaggit shackles.
mine went in smooth and easy without a fight. the only thing i wished i had done different is grease them before i installed. holding the flex hose and pumping half a tube from dinky grease pistol to fill empty shackles wasn't fun.
pannebreaux
Topics: 27
Images: 47
Return to Lifted Suspension
It is currently March 1st 2021, 1:50am
Lifted Suspension Forum
Attached by: SportsBoy
SportsBoy
Comments: 28
Date: Feb 15 '21
Time: 3:20am
SportsBoy
Comments: 28
Date: Feb 08 '21
Time: 2:46pm
pmou
Comments: 94
Date: Feb 05 '21
Time: 4:42pm
pmou
Comments: 94
Date: Feb 04 '21
Time: 6:47pm
Attached by: icebrrg3rd
icebrrg3rd
Comments: 28
Date: Jan 22 '21
Time: 4:09am
