Just ordered JOR 2-5" kit - Lift questions
Postby yohuallin [OP] » February 26th 2016, 7:35pm
So i finally took the plunge and ordered a kit. This is what i ordered, the 2-5" kit:
http://journeysoffroad.com/awd-astrosaf ... -kits.html
Eventually I will add an add-a-leaf kit. Click and Scroll down to see it.
http://journeysoffroad.com/astrosafari- ... ories.html
My question here is, with that kit, the add-a-leaf, and turning the stock torsion keys to level things out, what size tires could i fit. Im trying to figure this out so i can order it everything. Going on a trip this sunday for 10 days and would like to have all the parts by the time i get home.
Could i get away with 245/70/16? I dont mind trimming and cutting some things. I just want to make sure there is not other major modification needed to fit those tires.
This is on a 2004 btw.
Thanks.
Thats the van in question.
yohuallin
Years of Membership: yohuallin has been a member for 5 full yearsyohuallin has been a member for 5 full yearsyohuallin has been a member for 5 full yearsyohuallin has been a member for 5 full yearsyohuallin has been a member for 5 full years
Topics: 5
  • pair of JOR Shackles
    by lupulinshift » March 30th 2021, 1:49am in Lifted Suspension
    Last post by MI_Ghost View the latest post
    April 2nd 2021, 4:28pm
  • Shocks replacement necessary with lift kit?
    by wilsc449 » November 27th 2020, 11:05pm in Lifted Suspension
    December 29th 2020, 8:31pm
    53
    April 17th 2021, 4:20am
Re: Just ordered JOR 2-5" kit - Lift questions
Postby b00duh » February 26th 2016, 7:41pm
depends on how much of a lift you want to do on it. According to overland vans, you can fit 29" tires with their 2" lift; then the 4" lift can fit 30" - 31" tires.
b00duh
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: b00duh has been a member for 5 full yearsb00duh has been a member for 5 full yearsb00duh has been a member for 5 full yearsb00duh has been a member for 5 full yearsb00duh has been a member for 5 full years
Extra Info: SLE AWD
Postby 97cargocrawler » February 26th 2016, 7:55pm
In my opinion you're doing it *** backwards. Buy the wheels/tires you want and lift the van accordingly. The wheels/tires are the most important thing on the vehicle. You will either end up with a wheel combo that doesn't quite fit the look with a lift or you will compromise and end up cutting the **** out of your fenders.
I have always bought one test wheel of my desired brand and size and lifted the van to fit.
This question is soooooo :animals-deadhorse:
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby Lumpy » February 26th 2016, 9:06pm
97cargocrawler wrote:In my opinion you're doing it *** backwards. Buy the wheels/tires you want and lift the van accordingly. The wheels/tires are the most important thing on the vehicle. You will either end up with a wheel combo that doesn't quite fit the look with a lift or you will compromise and end up cutting the **** out of your fenders.
That, That and That.
Consider these two scenarios -
1) "I think my van would look ideal if I lifted it an additional 1" to balance the look"
vs
2) "I think my van would look ideal if I made the tires 1" smaller to balance the look"
Which one seems easier?
Postby yohuallin [OP] » February 26th 2016, 9:13pm
In my case I dont want to take any other route to the lift to begin with, and then isnt these kits somewhat adjustable. I dont really have the need to run 31" tires, but if 30 or 29 is not ideal for my set up then that would be the case.
I dont really see what the issue is with lifting the van, and then comparing the tires to the current height once is lifted...
Nways, thank you for the answer.
yohuallin
Topics: 5
Postby 97cargocrawler » February 26th 2016, 9:35pm
That JOR kit is really starting to annoy me. You're not going to get 4 or 5" with that kit in front, you be lucky to get 3" with your bars cranked hard. You can fit 235/75R15 with a 2" lift and a wee bit of rub and of course that's gonna depend on what tire/wheel combo you get.
97cargocrawler
Topics: 42
Postby Corsemoto » February 26th 2016, 9:48pm
With 2" lift (2" spacers, Airbagit lift shackles and slight torsion bar adjustment), 235/70-16 (29.3" diameter) fit on my 2004 with some bumper cover trimming/clearance in the front.
For a larger diameter tire you'll need more lift and/or clearance work. A 245/70-16 is closer to 30" than 29".
How much additional ride height you can gain from torsion lift depends on how sagged out your torsion bars are and how much you really want crank to angle the control arms. I saw as much as 1 1/2" - 1 3/4" with the stock torsion keys at or nearly maxed out.
If you're adjusting the torsion keys more than a slight amount, don't forget the alignment when you're done.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby yohuallin [OP] » February 26th 2016, 10:04pm
Corsemoto wrote:With 2" lift (2" spacers, Airbagit lift shackles and slight torsion bar adjustment), 235/70-16 (29.3" diameter) fit on my 2004 with some bumper cover trimming/clearance in the front.
thanks for the answer!
yohuallin
Topics: 5
Postby Lumpy » February 26th 2016, 11:17pm
Clearly you don't.
What's the purpose of your lift?
Postby HotWire » February 27th 2016, 2:21am
My 2003 AWD is lifted 3" in front with 2" pucks and !" cranked tbars, 4.5" rear with add-a-leaf and shackle. I have 245/70/16 and should've gone 245/74/16.
245/70/16 fit for me easy. Very slight trim on bumper cover. My tires do add 1-1/2" of ride height.
HotWire
Years of Membership: HotWire has been a member for 5 full yearsHotWire has been a member for 5 full yearsHotWire has been a member for 5 full yearsHotWire has been a member for 5 full yearsHotWire has been a member for 5 full years
Topics: 18
Images: 2
Extra Info: 4.3L V6 AWD
Return to Lifted Suspension
It is currently April 17th 2021, 4:20am
Lifted Suspension Forum
fe2o3
Date: Apr 12 '21
Time: 5:58pm
Date: Mar 25 '21
Time: 11:48pm
Attached by: SportsBoy
SportsBoy
Comments: 28
Date: Feb 15 '21
Time: 3:20am
SportsBoy
Comments: 28
Date: Feb 08 '21
Time: 2:46pm
pmou
Comments: 94
Date: Feb 05 '21
Time: 4:42pm
Users browsing this forum: BossmanBossman is online! and 6 guests
