Clank/clunk when braking and accelerating
Postby Sharkey51 [OP] » October 5th 2016, 5:56am
Hello, new to the site. Ton of good info here so thanks everyone!
Hoping for some feedback on a problem...
Can't figure out where a clank sound(metal on metal type) is coming from. I've had it for a while now. It only happens when first braking hardish while going slowish and when accelerating a bit fast from a stop. Like with forward g force and backward g force. Feels/sounds like it's coming from under my feet behind/beside driver front wheel well. Not too loud but noticeable and unpleasant. Don't hear it when going over bumps, turning hard or turning hard over bumps. With the front on jacks my wheels, steering and suspension components feel pretty solid. Checked the caliper for play, that felt solid too. Recently put on 2" body lift with pucks, new subframe bushings and bolts torqued to spec, so that should be solid. Can't figure it out? Any suggestions would be much appreciated! Thanks.
Sharkey51
Years of Membership: Sharkey51 has been a member for 4 full yearsSharkey51 has been a member for 4 full yearsSharkey51 has been a member for 4 full yearsSharkey51 has been a member for 4 full years
Extra Info: SLT RWD
Re: Clank/clunk when braking and accelerating
Postby Ksmith » October 5th 2016, 11:28am
I had a similar issue with my '96... I had the front shocks replaced and the mechanic hadn't tightened the shock mounts... that was it, simple fix, just tighten up 1 mount and it was done.
Kurt
Ksmith
Years of Membership: Ksmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full years
Topics: 21
Alias (AKA): Brushfire
Extra Info: AWD Z71
Postby Sharkey51 [OP] » October 5th 2016, 3:35pm
Hmm, I put new shocks in a while ago, had a little trouble getting the top nuts tight. Thought they were good in the end, but maybe not? I'll check that out... Thanks.
Sharkey51
Extra Info: SLT RWD
Postby TurnNburn » October 5th 2016, 6:12pm
Motor mounts and transmission mount are also worth checking out. can you make that noise happen if you do a brake stand while stationary? Or do you have to be moving?
TurnNburn
Green Status (L4)
Green Status (L4)
Alias (AKA): iGoogle
Postby Mmusicman » October 5th 2016, 7:55pm
Oddly, I've had ball joints do this
Topics: 73
Images: 49
Postby Sharkey51 [OP] » October 5th 2016, 10:33pm
Thanks for the response.
Checked/tightened shock mounts, motor mounts and
transmission mount. Doesn't make the sound with brake stand. Can make sound easy by going forward slowly and hitting the brakes and then backward slowly and hitting the brakes. Sometimes it's a single and sometimes a double clunk/clank. Feels like it's right under my feet. Was thinking it had to be brake related but I double checked calipers and pads for any play. While I had it up I rechecked for any play in the steering and suspension.
Could the ball joints feel solid by hand but still have play when driving?
Sharkey51
Extra Info: SLT RWD
Postby Sharkey51 [OP] » October 7th 2016, 3:35am
Okay I'm an idiot!
It was my subframe bolts. Just put new bushings and bolts in recently and torqued them to spec. Thinking back, there was no clunks for a couple days and then it came back. Guess before it was the spent bushings and then the loose new bolts. Not sure how they came loose or if the bushings just settled down some? I'll have to keep an eye on them.
Oh well, at least I thoroughly checked every other bushing and ball joint and they look good.
Thanks for the input!
Sharkey51
Extra Info: SLT RWD
Postby TurnNburn » October 7th 2016, 4:56am
Yeah that's pretty common for bushings to settle. Even metal can "relax".. Good advice for any one doing there own work, especially when lifting(or lowering), to recheck all of there work after a hundred miles or so.
TurnNburn
Green Status (L4)
Green Status (L4)
Return to Stock Suspension
It is currently February 25th 2021, 8:16pm
Stock Suspension Forum
Coronavan
in Stock Suspension
Date: Feb 09 '21
Time: 2:18am
Coronavan
in Stock Suspension
Date: Feb 08 '21
Time: 3:11am
in Stock Suspension
Date: Jan 23 '21
Time: 7:38am
tungtide
in Stock Suspension
Date: Jan 04 '21
Time: 3:53pm
tungtide
in Stock Suspension
Comments: 25
Date: Jan 03 '21
Time: 9:09pm
