Sway bar shopping
Sway bar shopping
Postby smokinjoe [OP] » October 22nd 2017, 5:19am
So my sway bar is broken and I haven't had luck at JYs. I looked on rockauto but they call it a stabilizer bar and only seem to offer one by mevotech for $109
On ebay I found some from 60 something and up.
So any recommendations? Am I going to not get good results with a $70 unit compared to a $110 one?
Anyone know this?
smokinjoe
Firing on 5 Cylinders (L2)
Topics: 270
Alias (AKA): smokinjoe
Van Model Year: 2002
Extra Info: RWD
  • Front Sway Bar Replacement
    by 4dastro » November 1st 2020, 5:46pm in Stock Suspension
    November 3rd 2020, 7:28pm
    9
    50
    April 13th 2021, 4:59pm
Re: Sway bar shopping
Postby five10freak » October 22nd 2017, 5:40am
I don't have enough info to compare the two examples you are referencing, but I can say that I use Hellwig front and rear sway bars and absolutely love them.
five10freak
Years of Membership: five10freak has been a member for 8 full yearsfive10freak has been a member for 8 full yearsfive10freak has been a member for 8 full yearsfive10freak has been a member for 8 full yearsfive10freak has been a member for 8 full yearsfive10freak has been a member for 8 full yearsfive10freak has been a member for 8 full yearsfive10freak has been a member for 8 full years
Topics: 24
Images: 232
Alias (AKA): five10freak
Extra Info: LS 4.3L V6 RWD
Postby MI_Ghost » October 22nd 2017, 6:22am
I replaced my front bar and added the rear with Belltech pieces. It was about $350 for both and the difference it makes in the handling is worth it.
85-05 RWD
Belltech 5428 Sway Bar Front 1 3/8" Diameter. (35mm), Solid
Belltech 5528 Sway Bar Rear 7/8" Diameter. (22mm), Solid
Belltech 9913 Sway Bar Kit, Front & Rear
Addco 772 Sway Bar Front 1 1/4" Diameter (33mm), Solid
Addco 642 Sway Bar Rear 7/8" Diameter (22mm), Solid
Hellwig 7556 FRONT Sway Bar 1 1/8" diameter (29mm), Solid
Hellwig 7534 REAR Sway Bar 3/4" diameter (19mm), Solid
Dorman 927-104 Sway Bar Front 1 1/16" Diameter (28 mm), Stock replacement, Tube
90-05 AWD
Dorman 927-103 Sway Bar Front 1 1/8" diameter (29mm), Stock replacement, Tube
Addco 316 Sway Bar Rear 7/8 in. Diameter, Solid
The thicker the bar the stiffer it will be. After that shop around for price.
~Ghost
Ast' Cargo: 2001 Astro Cargo
Beauty: 2009 Impala LT
MI_Ghost
Topics: 7
Images: 107
Alias (AKA): Ghost
Van Model Year: 2001
Extra Info: Big White RWD Box
Postby smokinjoe [OP] » October 22nd 2017, 1:43pm
So my van is a 2wd 02 LS. I don't have a rear one stock right?
Ghost thanks for the items, that sounds like something Id want to do.
Will I get worse results with non name brand stuff?
smokinjoe
Topics: 270
Extra Info: RWD
Postby MI_Ghost » October 22nd 2017, 2:25pm
smokinjoe wrote:So my van is a 2wd 02 LS. I don't have a rear one stock right?
Correct, The only van that cam stock with the rear bar is the RS/GT sport model.
These are nearly impossible to find anymore.
smokinjoe wrote:Will I get worse results with non name brand stuff?
That cheap sway bar on eBay looks like a Chinese knock off of the Dorman part.
It will likely preform as well as the stock bar. For a little while.
~Ghost
MI_Ghost
Topics: 7
Images: 107
Alias (AKA): Ghost
Postby 1lowcab » October 22nd 2017, 3:41pm
I have the Dorman replacement on mine, works great plus its a solid bar and won't crack like the original.
1lowcab
Firing on 8 Cylinders (L3)
Topics: 58
Images: 165
Postby five10freak » October 22nd 2017, 3:59pm
Pay cheap get cheap. Although I think they all come from China, LOL. For me it comes down to size, warranty, and overall finish. That’s where the price change is. I fear the cheaper versions will begin to rust out quickly as appossed to a known name brand that powder coats them.
I mainly chose Hellwig because I liked there gray hammer tone powder coated finish and when I was reaserching rear sway bars that company kept popping up as a good one. Now moving forward almost 5 years later my front oem sway bar snaps ( a common problem ) I ordered the matching front Hellwig bar. The rear bar still looks new, dirty but rust free.
five10freak
Topics: 24
Images: 232
Postby kennysmoke » October 22nd 2017, 4:46pm
I put the solid Dorman on my '03 AWD... HUGE improvment over the hollow stock bar. I see no reason to spend big money on a "better" name brand. I had done so years ago for one for my 1 ton van that was powder coated and it rusted just the same as the Dorman on my Astro... I live in the rust belt tho.
"Live Free Or Die" Image
kennysmoke
Blue Status (L2)
Blue Status (L2)
Topics: 68
Images: 7
Alias (AKA): kennysmoke
Extra Info: AWD Tow Pakage
Postby smokinjoe [OP] » October 22nd 2017, 7:42pm
Does dorman make a rear one too?
Also rockauto seems to have just a mevotech but I cant find dimentions on the site. Anyone know about them?
Where is a good source for dorman or helwig?
smokinjoe
Topics: 270
Extra Info: RWD
Postby MI_Ghost » October 23rd 2017, 4:53am
Part # for the mevotech?
Mevotech is fairly new In the market. I have not seen anything negative about them yet.
Thanks for the correction on the Dorman being a solid bar!
No, Dorman does not offer a rear sway bar. They only deal in OEM spec replacement parts. The RS/GT rear bar was a complicated mess for mounting. There would be little to no profit trying to reproduce it at a marketable price. Not sure it would work with steel leaf springs.
With the addition of front & rear bars with KYB Gas-A-Just shocks my van went from a wallering whale that would get a nun arrested for being drunk to straight arrow fingertip control. The rear bar really does make that much difference.
~Ghost
MI_Ghost
Topics: 7
Images: 107
Alias (AKA): Ghost
Postby WinnieVan » October 23rd 2017, 9:17am
WinnieVan
Firing on 3 Cylinders (L3)
Years of Membership: WinnieVan has been a member for 4 full yearsWinnieVan has been a member for 4 full yearsWinnieVan has been a member for 4 full yearsWinnieVan has been a member for 4 full years
Topics: 64
Images: 27
Postby smokinjoe [OP] » October 24th 2017, 3:49am
So I am sold on doing front and rear. Will check ebay for a front helwig.
Ghost do you remember where you got that deal?
smokinjoe
Topics: 270
Extra Info: RWD
Postby MI_Ghost » October 25th 2017, 5:27am
I got mine off eBay. Still listed.
Search
Astro sway bar belltech
Astro sway bar hellwig
~Ghost
MI_Ghost
Topics: 7
Images: 107
Alias (AKA): Ghost
Postby smokinjoe [OP] » October 25th 2017, 1:30pm
Ok cool ghost I ordered them. Thanks.
smokinjoe
Topics: 270
Extra Info: RWD
Postby Toskavat » October 25th 2017, 3:04pm
I contacted SDtrucksprings about price matching their ebay price on the rear Hellwig bar. After a nice chat session with them, they actually beat that price. Cost was $167. and will be shipped soon.
Toskavat
Years of Membership: Toskavat has been a member for 6 full yearsToskavat has been a member for 6 full yearsToskavat has been a member for 6 full yearsToskavat has been a member for 6 full yearsToskavat has been a member for 6 full yearsToskavat has been a member for 6 full years
Images: 25
Alias (AKA): ASTRORC
Extra Info: 4.3 V6 2WD
Postby WinnieVan » October 25th 2017, 4:32pm
Toskavat wrote:I contacted SDtrucksprings about price matching their ebay price on the rear Hellwig bar. After a nice chat session with them, they actually beat that price. Cost was $167. and will be shipped soon.
Cool. How much was shipping?
Sent from my iPhone using Tapatalk
WinnieVan
Topics: 64
Images: 27
Postby Rinny » October 25th 2017, 5:20pm
I installed the dorman solid bar on my 03 AWD
03Astro AWD/4WD
TorsenDiffs,3:73'S,VettServo
NP236TC
Dual Piston Rear Calipers
GY DTrac 235/85/R16
ARB &/Custom bumpers
2x6x1/4 Rockrails
Rinny
Years of Membership: Rinny has been a member for 5 full yearsRinny has been a member for 5 full yearsRinny has been a member for 5 full yearsRinny has been a member for 5 full yearsRinny has been a member for 5 full years
Images: 6
Extra Info: 5.7L NP236
Postby Toskavat » October 25th 2017, 5:40pm
@ WV, was listed as free UPS.
Toskavat
Images: 25
Postby TurnNburn » October 25th 2017, 5:52pm
Good to know they have the hellwig kit in stock. I have been trying to purchase one for about a month and everyone says they have it in stock when I order it, but a couple of days later I get an email that they are on back order and they don't actually have any.
And 167 is cheaper then your going to find anywhere (I have been shopping)
TurnNburn
Green Status (L4)
Green Status (L4)
Alias (AKA): iGoogle
Postby Ken2.7 » October 25th 2017, 5:54pm
I looked at the Dorman front sway bar for my 2000 AWD and Autozone on line offered a discount and free shipping bringing the total to $122. I liked what I read about it so I ordered it.
Ken2.7
Years of Membership: Ken2.7 has been a member for 8 full yearsKen2.7 has been a member for 8 full yearsKen2.7 has been a member for 8 full yearsKen2.7 has been a member for 8 full yearsKen2.7 has been a member for 8 full yearsKen2.7 has been a member for 8 full yearsKen2.7 has been a member for 8 full yearsKen2.7 has been a member for 8 full years
Topics: 34
Alias (AKA): Ken
Return to Stock Suspension
It is currently April 13th 2021, 4:59pm
Stock Suspension Forum
in Stock Suspension
Date: Mar 25 '21
Time: 2:54am
BPACH
in Stock Suspension
Date: Mar 22 '21
Time: 11:58pm
Coronavan
in Stock Suspension
Date: Feb 09 '21
Time: 2:18am
Coronavan
in Stock Suspension
Date: Feb 08 '21
Time: 3:11am
in Stock Suspension
Date: Jan 23 '21
Time: 7:38am
