Converting to u bolts and top plates.
Postby 1lowcab [OP] » December 1st 2017, 8:45pm
Quick question, What top plate do I use for this? I have a set of wangler top plates form a junkyard (really good price) they are the same as the Crown Automotive 52006421 (thats what that part number is for).
My problem is my spring perches are juuussst a hair to wide, not wide enough to drill through them like on a fiberglass spring van but wide enough that the ubolts go through at weird angles.
Any ideas?
1lowcab
Firing on 8 Cylinders (L3)
Topics: 58
Images: 165
Re: Converting to u bolts and top plates.
Postby akforceten » December 1st 2017, 8:47pm
I grabbed some from a ford ranger /explorer
98638 100250
akforceten
Years of Membership: akforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full years
Topics: 32
Images: 128
Alias (AKA): akforceten
Extra Info: SLE 4x4 7 inch lift
Postby 1lowcab [OP] » December 1st 2017, 8:52pm
On your 95, did it have fiberglass springs originally or steel?
1lowcab
Topics: 58
Images: 165
Postby 1lowcab [OP] » December 1st 2017, 8:59pm
Pics to show my problem
See the spring perch in the other 2 ubolt holes
Where ubolt will hit, the 2 black marks
Can't drill through this as it would weaken everything.
1lowcab
Topics: 58
Images: 165
Postby TurnNburn » December 1st 2017, 9:32pm
My suggestion would be to buy the appropriately sized plates. That part number is what Will used in his signature. Maybe they cross referenced wrong?
https://sites.google.com/site/astrosafa ... pring-lift
$7 on amazon https://www.amazon.com/Crown-Automotive ... 3a64d0d139
I wouldn't grind the spring perch to make them fit without reinforcing afterwards
TurnNburn
Green Status (L4)
Green Status (L4)
Alias (AKA): iGoogle
Postby 1lowcab [OP] » December 1st 2017, 9:59pm
Right, the plate in Wills sig is a Crown Automotive 52006421 and is made to fit an 87-95 Wrangler YJ, those are the plates I got at the yard.
https://www.crownautomotive.net/Leaf-Spring-Plate-Rear/52006421.html
They must work for the fiberglass guys as the perch is wider and you can drill through but not for the steel guys as they have the narrower perch.
Heres how Will did it on his post (he had the wider perches)
I won't be grinding anything at it would weaken the perch too much and be a pain to reinforce.
1lowcab
Topics: 58
Images: 165
Postby 1lowcab [OP] » December 2nd 2017, 4:55am
I just ordered some top plates, by the measurements they gave they should fit perfectly over the perch....I hope, lol!
I'll update once I get them.
1lowcab
Topics: 58
Images: 165
Postby TurnNburn » December 5th 2017, 5:39pm
I am glad you decided to not drill holes in your spring perch
TurnNburn
Green Status (L4)
Green Status (L4)
Postby 1lowcab [OP] » December 5th 2017, 5:51pm
I have some top plates coming, I have a bunch of parts coming but man it's taking them FOREVER to get here!!! I hate ordering stuff this time of year....SOOOOOOO sloooooooooow.
1lowcab
Topics: 58
Images: 165
Postby Rinny » December 5th 2017, 10:32pm
I am watchin cause I am a copy cat, lol. I will be doing this mod when I clean up under the dogs tail as someone so nicely pointed out :rofl: No but really I am going to do this when I finish the back half of the underside and the rear diff, axel housing, backing plates calipers(new duel piston), well you get the idea. I be watchin!!
03Astro AWD/4WD
TorsenDiffs,3:73'S,VettServo
NP236TC
Dual Piston Rear Calipers
GY DTrac 235/85/R16
ARB &/Custom bumpers
2x6x1/4 Rockrails
Rinny
Years of Membership: Rinny has been a member for 5 full yearsRinny has been a member for 5 full yearsRinny has been a member for 5 full yearsRinny has been a member for 5 full yearsRinny has been a member for 5 full years
Images: 6
Extra Info: 5.7L NP236
Postby 1lowcab [OP] » December 6th 2017, 12:37am
Hey, feel free to copy away. I'm just hoping it turns out good, lol!
The top plates are supposed to be here Thursday so I got started on the rearend.
Pulled out the rearend I used for testing...
And started getting my old rearend (the one with the locker) ready for the top plates.
Here are the stock holes for the clamshells
Here are the holes I drilled for 5/8 Ubolts, the holes are tight against the axle housing and spring perch.
Then for craps and giggles I wire brushed the housing and hit it with some Rustoleum.
Here are the old clamshell parts, goodbye forever crappy pieces!
In memory of Lumpy.... :D
All this work to get rid of this ghetto engineered, hillbilly AF, rigged up crap...it was sturdy and worked fine but looked pretty poopie.
I'll post updates when the parts come in.
1lowcab
Topics: 58
Images: 165
Postby markmitch » December 6th 2017, 1:20am
what are the red pieces on the rear axle? bumpstops? PN and manufacturer please. My rubber ones are junk will those you have work an a 2 wheel drive van?
Firing on 8 Cylinders (L6)
Topics: 626
Images: 20
Extra Info: RS V8 AWD
Postby 1lowcab [OP] » December 6th 2017, 1:27am
They are Energy Suspension part # 9.9143R, they have them in black too. If your bumpstops are like the 2nd gen ones they will work great, I don't know how the 1st gen ones are mounted.
Here is how they mount to a 2nd gen
1lowcab
Topics: 58
Images: 165
Postby dramey » December 6th 2017, 1:38am
I have Timbrens for my bump stops.
dramey
Firing on 7 Cylinders (L1)
Extra Info: AWD Cargo Van
Postby Coaster » December 6th 2017, 2:48am
i used my first gen bumpstops on my second gen axles. they is the same
I LIVE IN NORTH DAKOTA
Coaster
Years of Membership: Coaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full years
Topics: 113
Extra Info: 4.3 cargo 2wd
Postby 1lowcab [OP] » December 8th 2017, 12:34am
Parts came in and I was busy!
Here are the top plates fresh from Amazon, part number 3F-UPLT. They are BEEFY!!!!!!
I had to open up the center hole and elongate the outer 2 holes.
The reason being is the outboard part of the axle is 2-3/4", the inboard side is 3" and I just needed a touch more room on the out board side of the plate...not pretty but I got it done.
And I got some ubolts made locally. I used 5/8 ubolts, 2 of them are 3" wide for the inboard sides and 2 of them are 2-3/4" wide for the outboard sides. You would have to measure your own length as I have an extra spring in mine plus an overload spring.
Old vs new....hefty, hefty hefty!
Then I looked at my bumpstops, they were serving no purpose way down there so I decided to make an extended mount for them so they would function again.
Got some steel
Measured it out and chopped it up.
And welded up these guys.
Welded it in place on the axle. Wish I'd of thought about this when the axle was out...would have been a lot easier! :roll:
And then installed the plates and ubolts.
Man it was nice tightening those top plates down and feeling them torque and not bend, lol!
With those beefy plates and 5/8 bolts that rearend is going NOWHERE!!!!!!!!!!!!!!
1lowcab
Topics: 58
Images: 165
Postby TurnNburn » December 8th 2017, 1:07am
I like where you are going with those bump stop lift plates. When I did my lift I just threw what was left of mine away and never looked back.
TurnNburn
Green Status (L4)
Green Status (L4)
Postby 1lowcab [OP] » December 8th 2017, 1:25am
Thanks man. I was going to buy longer bumpstops but really couldn't find any long enough. So if you can't get a longer bumpstop you make a longer mount...If the mountain won't come to Muhammad... or something like that.
1lowcab
Topics: 58
Images: 165
Postby Rinny » December 8th 2017, 10:23pm
I don't suppose you made a cardboard template of those plates I could scan into a c&c machine by ant chance?
03Astro AWD/4WD
NP236TC
GY DTrac 235/85/R16
2x6x1/4 Rockrails
Rinny
Images: 6
Postby WimpTech » December 8th 2017, 11:05pm
1lowcab wrote:In memory of Lumpy.... :D
WimpTech
Firing on 4 Cylinders (L5)
Topics: 38
Images: 322
Alias (AKA): =Wimpy=
Extra Info: AWD 3+1 Lift
Return to Stock Suspension
It is currently February 25th 2021, 12:00pm
Stock Suspension Forum
Coronavan
in Stock Suspension
Date: Feb 09 '21
Time: 2:18am
Coronavan
in Stock Suspension
Date: Feb 08 '21
Time: 3:11am
in Stock Suspension
Date: Jan 23 '21
Time: 7:38am
tungtide
in Stock Suspension
Date: Jan 04 '21
Time: 3:53pm
tungtide
in Stock Suspension
Comments: 25
Date: Jan 03 '21
Time: 9:09pm
