Broken Sway Bar
Broken Sway Bar
Postby GuyS [OP] » July 13th 2019, 9:42pm
Although the photo suggests it had been broken for a while (the rust looked pretty deep), I had had the shocks replaced only 800 miles previously and the sway bar was not broken then.
Started hearing weird clunks in my 05 Astro. The noise would sometimes occur turning sharp (like backing into my driveway) and sometimes over speed bumps. It turned out to be a broken sway bar. The "V" break could have something to do to the torsion stress on a sway bar. Just sharing.
GuyS
Years of Membership: GuyS has been a member for 4 full yearsGuyS has been a member for 4 full yearsGuyS has been a member for 4 full yearsGuyS has been a member for 4 full years
Topics: 17
  • RS & GT factory sway bar.
    by bowtie262 » June 11th 2020, 2:56pm in Stock Suspension
    June 12th 2020, 7:51pm
  • Anti-Sway Bar Fitment Check
    by fellowtraveler » June 29th 2020, 11:47pm in Stock Suspension
    July 2nd 2020, 12:05am
    73
    September 22nd 2020, 6:50pm
Re: Broken Sway Bar
Postby GuyS [OP] » July 13th 2019, 9:52pm
Here is a photo I took of a leaking shock that prompted me to replace all shocks on the van 800 miles before the sway broke. You can see in the photo the sway bar was not broken then.
GuyS
Topics: 17
Re: Broken Sway Bar
Postby M_a_t_tM_a_t_t is online! » July 14th 2019, 2:12am
The ends are a common failure point. I think you can order a solid sway bar for a cargo for a direct swap.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD
1995 Mercury Tracer
2004 Chevy Astro AWD
2017 Kawasaki VersysX 300
Topics: 27
Images: 96
Extra Info: cl rwd
Re: Broken Sway Bar
Postby GuyS [OP] » July 14th 2019, 2:19pm
The sway bars seem to be readily available. Mine was in Vancouver BC
GuyS
Topics: 17
Re: Broken Sway Bar
Postby M_a_t_tM_a_t_t is online! » July 14th 2019, 4:08pm
I know passenger replacements are available, but the cargo replacement was solid and since they share subframes and suspension parts it should be a direct swap. Solid = less likely to break + better feeling around curves
1995 Mercury Tracer
Topics: 27
Images: 96
Extra Info: cl rwd
Re: Broken Sway Bar
Postby GuyS [OP] » July 14th 2019, 4:28pm
You know I searched through a few posts here and it seems that the hollow ones were factory. The solid ones are all that is available now. I am not sure but is there a difference between the sway bars that are on cargo vs a passenger Astro/Safari?
GuyS
Topics: 17
Re: Broken Sway Bar
Postby Leeann_93 » July 14th 2019, 4:58pm
Sway bars are all the same design/dimensions. Factory is hollow, aftermarket are all solid. The hollow bar is weak at the flattened area and always rusts and breaks there.
Re: Broken Sway Bar
Postby e7ats » November 21st 2019, 3:51am
I had about 110K on my swaybar when I noticed it cracking just behind the flat part. I purchased my swaybar from NAPA and it was a solid bar.
e7ats
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: e7ats has been a member for 12 full yearse7ats has been a member for 12 full yearse7ats has been a member for 12 full yearse7ats has been a member for 12 full yearse7ats has been a member for 12 full yearse7ats has been a member for 12 full yearse7ats has been a member for 12 full yearse7ats has been a member for 12 full yearse7ats has been a member for 12 full yearse7ats has been a member for 12 full yearse7ats has been a member for 12 full yearse7ats has been a member for 12 full years
Extra Info: 4.3 X AWD
Re: Broken Sway Bar
Postby smokinjoe » November 24th 2019, 10:10pm
I got beltech solid ones front and back & It handles like a camaro now.
smokinjoe
Firing on 5 Cylinders (L2)
Topics: 268
Alias (AKA): smokinjoe
Van Model Year: 2002
Extra Info: RWD
Re: Broken Sway Bar
Postby petema » September 16th 2020, 1:15pm
Welded the front sway bar today. One side was slightly split and the other more so, a piece fell of when removed. There tends to be some rust inside the bar, moisture enters the bar trough a small hole on each side, an inch or two from the drop link. REMOVAL of the bar was surprisingly easy once the idler arms where loosened and swung backwards. Using a pneumatic tool for bolt removal saves a lot of time. Drop links where renewed. Best way to remove them is by grinder, they are hardly reusable anyway. Pulled the worn half axle and put in a good regreased one with good rubber. The axle was originally the sole intention of the job, but you know how it is once you go ahead with something.
If everybody drove a 4x4, the use of salt on the roads would be reduced substantially.
petema
Fueling (Full tank)
Fueling (Full tank)
Years of Membership: petema has been a member for 5 full yearspetema has been a member for 5 full yearspetema has been a member for 5 full yearspetema has been a member for 5 full yearspetema has been a member for 5 full years
Images: 4
Alias (AKA): xm4617
Van Model Year: 1991
Extra Info: CL awd
Re: Broken Sway Bar
Postby MechBob » September 17th 2020, 5:43am
So,petema,I hope you consider this a temporary repair?Besides,if you install a solid bar you would be amazed.
MechBob
Blue Status (L2)
Blue Status (L2)
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Re: Broken Sway Bar
Postby petema » September 17th 2020, 8:42am
Thanks for your advice MechBob. With the availability of parts for the Astro, there is no good reason to wait for total breakdown until a new part is installed. P
petema
Fueling (Full tank)
Fueling (Full tank)
Images: 4
Alias (AKA): xm4617
Extra Info: CL awd
Re: Broken Sway Bar
Postby markmitch » September 17th 2020, 2:46pm
The solid ones are /were a higher tensile strength and were as ordered from GM My 89 has the factory solid bar with GM stickers on it so they were available from GM at one point.
Firing on 4 Cylinders (L6)
Topics: 596
Images: 20
Extra Info: RS V8
Re: Broken Sway Bar
Postby augidog » September 17th 2020, 3:44pm
MechBob wrote:So,petema,I hope you consider this a temporary repair?Besides,if you install a solid bar you would be amazed.
I know I was. my original hollow bar had become permanently twisted about 1"...my Dorman solid replacement kit is one of the best investments of time & money I've made, in my opinion.
here's a tip I learned when looking at my original links. they were still plastic-wrapped, and I realized it for easy assembly. I taped my replacement hardware together into easy-to-handle packs, and there was no searching for, or juggling of, washers and bushings, and zero cussing, while laying on my back under the van.
augidog
Topics: 16
Alias (AKA): Augie
Extra Info: AWD High-Top
Return to Stock Suspension
It is currently September 22nd 2020, 6:50pm
Stock Suspension Forum
Attached by: augidog
augidog
in Stock Suspension
Comments: 13
Date: Sep 17 '20
Time: 3:42pm
petema
in Stock Suspension
Comments: 13
Date: Sep 16 '20
Time: 1:09pm
Attached by: bowtie262
bowtie262
in Stock Suspension
Comments: 18
Date: Sep 09 '20
Time: 11:59pm
bowtie262
in Stock Suspension
Comments: 18
Date: Sep 05 '20
Time: 12:46pm
Ken2.7
in Stock Suspension
Date: Sep 04 '20
Time: 3:49pm
