Lower ball joint
Lower ball joint
Postby Cabinetmaker [OP] » August 1st 2020, 5:17pm
Is a washer needed under the castle nut on the lower ball joint
Cabinetmaker
Years of Membership: Cabinetmaker has been a member for 1 full year
Re: Lower ball joint
Postby Mmusicman » August 1st 2020, 5:20pm
Cabinetmaker wrote:Is a washer needed under the castle nut on the lower ball joint
No. I've never seen one used or needed.
But if the castle-nut should somehow wind up past the cotter-pin.. then I would use one.
If that DID happen.. I'd be a little concerned as to why.
Firing on 4 Cylinders (L5)
Topics: 71
Images: 49
Postby Cabinetmaker [OP] » August 1st 2020, 5:24pm
This is the case. There was no washer on the old one.
Cabinetmaker
Postby chevymaher » August 1st 2020, 10:02pm
I hacve had this happen on aftermarket ones. Just use what you got to to line the keyway up.
Return to Stock Suspension
It is currently August 4th 2020, 9:02am
Stock Suspension Forum
johnv
in Stock Suspension
Date: Jul 30 '20
Time: 7:20pm
Attached by: MechBob
MechBob
in Stock Suspension
Date: Jul 14 '20
Time: 3:57pm
chucksurette
in Stock Suspension
Date: Jul 14 '20
Time: 2:34pm
observer
in Stock Suspension
Date: Jul 05 '20
Time: 8:38pm
chucksurette
in Stock Suspension
Date: Jul 05 '20
Time: 1:12am
