helper spring rear end lift
Postby fellowtraveler [OP] » September 16th 2020, 4:17am
I rescue food a couple times a week with my 98 Astro. So I thought it might be a good idea to add a set of helper springs to the rear. Which I did. On with the Hellwig 815 springs no problem. So now when shes unloaded (which is the majority of the time) my back end is racked about 2-3 inches higher than the front. My question is: Will this rear end lift adversely effect any of the overall suspension elements/parts or overall general operational status and/or handling. Have never experienced this particular set of circumstances (in any vehicle I have owned) I thought I'd ask before putting a bunch of miles on her. :chevy:
fellowtraveler
Topics: 7
Extra Info: LS RWD
  • Leaf spring clack
    by smokinjoe » April 20th 2020, 3:11am in Stock Suspension
    April 25th 2020, 9:20pm
  • rear ride height
    by Rod's Trucks » April 30th 2020, 4:49am in Stock Suspension
    Last post by augidog View the latest post
    April 30th 2020, 5:40pm
    9
    77
    September 28th 2020, 10:03am
Re: helper spring rear end lift
Postby 97cargocrawler » September 16th 2020, 7:46am
Because your pinion angle will change, added wear on the driveshaft CV joints and transmission mounts. Possibly other components if you start to have vibrations from the angle change. A decent amount of rake will also change the caster angle of the front wheels. So some added wear could appear..though seems unlikely.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby fellowtraveler [OP] » September 16th 2020, 3:08pm
So would it be then smart to raise the front end a few inches to level it out?
fellowtraveler
Topics: 7
Extra Info: LS RWD
Postby 97cargocrawler » September 16th 2020, 6:26pm
I think the wear will be minimal but depends on the current condition of your driveline. Personally I hate how rake looks and feels so I would do a 2" body lift.
97cargocrawler
Topics: 42
Postby fellowtraveler [OP] » September 16th 2020, 9:13pm
I feel the same - since the back is already lifted (via the helper springs) - is it possible to just raise to front to equalize?
fellowtraveler
Topics: 7
Extra Info: LS RWD
Postby 97cargocrawler » September 17th 2020, 4:59am
fellowtraveler wrote:is it possible to just raise to front to equalize?
2" body lift. aka. "pucks, blocks or spacers" that go in between the front subframe and body. This is the cheapest and easiest way to lift the front of a RWD van and the only way to correct rake and pinion angle at the same time.
97cargocrawler
Topics: 42
Postby MechBob » September 17th 2020, 5:32am
OK,just coming from an old mechanic.The kit you put on is a load leveler,is adjustable,the key is to raise the vehicle to stock height,unloaded.Then it will also help when vehicle is loaded.Running it jacked up in the back can-increase u-joint wear,increase vibrations,affect the braking system(normal braking), and affect the ABS braking system.Not to mention,being a 2wd, increases understeer.Just seems to me yopu have used the product wrong.There is nothing wrong with a "leveling" kit, when used/installed properly.
MechBob
Blue Status (L2)
Blue Status (L2)
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Return to Stock Suspension
It is currently September 28th 2020, 10:03am
Stock Suspension Forum
Rando
in Stock Suspension
Date: Sep 26 '20
Time: 3:28am
Attached by: augidog
augidog
in Stock Suspension
Comments: 13
Date: Sep 17 '20
Time: 3:42pm
petema
in Stock Suspension
Comments: 13
Date: Sep 16 '20
Time: 1:09pm
Attached by: bowtie262
bowtie262
in Stock Suspension
Comments: 18
Date: Sep 09 '20
Time: 11:59pm
bowtie262
in Stock Suspension
Comments: 18
Date: Sep 05 '20
Time: 12:46pm
