lower control arm bushings bolts
Postby baily144 [OP] » March 30th 2021, 11:15pm
Hi
Does anyone know what the bolt and nut size is for the lower control arm of a 2003 astro rwd.
Are both the same size?
I figure I may have to cut them off, I'd like to have new ones ready.
Bolts size? Gm part numbers?
Alex
baily144
Years of Membership: baily144 has been a member for 7 full yearsbaily144 has been a member for 7 full yearsbaily144 has been a member for 7 full yearsbaily144 has been a member for 7 full yearsbaily144 has been a member for 7 full yearsbaily144 has been a member for 7 full yearsbaily144 has been a member for 7 full years
Topics: 35
Alias (AKA): Alex
  • lower control arm bushings
    by baily144 » March 27th 2021, 3:25am in Stock Suspension
    Last post by baily144 View the latest post
    March 27th 2021, 3:49am
  • torsion bar stuck in control arm.
    by keith92ext » May 8th 2021, 11:31pm in Stock Suspension
    Today, 1:42am
    7
    98
    May 16th 2021, 6:51am
Re: lower control arm bushings bolts
Postby AstroWill » April 1st 2021, 8:46pm
Have you checked GMPartsPrime or any of the other GM parts sites?
Topics: 109
Images: 473
Postby baily144 [OP] » April 1st 2021, 9:08pm
yup....there's only AWD bolts by Dorman. Theres no listing for RWD bolts
baily144
Topics: 35
Alias (AKA): Alex
Postby AstroWill » April 1st 2021, 9:15pm
https://www.gmpartsprime.com/auto-parts ... front.html
Bottom of the page.
11517901 BOLT, HEXAGON,M14X2X90,34 THREAD,28 OUTSIDE DIAMETER,10.9,7114,MACHINE,HEADER POINT(FRONT LOWER CONTROL ARM)
Topics: 109
Images: 473
Postby baily144 [OP] » April 1st 2021, 9:25pm
Thks man that helps I'll see if I can find them
baily144
Topics: 35
Alias (AKA): Alex
Postby baily144 [OP] » April 30th 2021, 2:53am
ok ordered them them from GM , but I'm confused by them.
Standard Parts
11517901 is highlighted in the diagram
11517901
11517901
$6.26
$3.99
NUT, HEXAGON M14X2X13(FRONT LOWER CONTROL ARM)
Fitting Vehicle Options:
M1
the bolt has a thread at the front of the bolt , are these bolts threaded into the frame brackets ?
also the bolts are smaller than the bushings they flop around .....has anyone taken the control arms off before ..... this doesn't seem right to me
any help ?
baily144
Topics: 35
Alias (AKA): Alex
lower control arm bolts
Postby baily144 [OP] » May 3rd 2021, 9:09pm
2003 astro RWD cargo van
I ordered the lower control arm bolts from GM , but I'm confused by them.
Standard Parts
11517901
11517901
$6.26
$3.99
M1
any help ?
baily144
Topics: 35
Alias (AKA): Alex
Postby AstroWill » May 3rd 2021, 11:19pm
All of mine are AWD, so I have no idea on a RWD. What size are the bolts that were removed?
Topics: 109
Images: 473
Postby baily144 [OP] » May 4th 2021, 12:24am
I have no idea.... The weather hasn't been very good to attempt it yet.... Still wondering if the old bolts will ever come out.
Thks Alex
baily144
Topics: 35
Alias (AKA): Alex
Postby AstroWill » May 4th 2021, 2:19am
What about the bushings? I assume that you have ordered replacements already, what are the dimensions of those bushings listed at?
Topics: 109
Images: 473
Postby baily144 [OP] » May 4th 2021, 3:38am
Heres the moog that i got and AC Delco
the numbers seem differant but not far off ..
here s the bolt info ....seems like the right bolt but flops around in the bushing
Standard Parts
11517901
11517901
$6.26
$3.99
Require Quantity:
04
Package Quantity:
1
1
Add To Cart
11516074 is highlighted in the diagram
11516074
11516074
M1
Require Quantity:
04
Package Quantity:
Moog.docx
(13.67 KiB) Downloaded 4 times
baily144
Topics: 35
Alias (AKA): Alex
Return to Stock Suspension
It is currently May 16th 2021, 6:51am
Stock Suspension Forum
in Stock Suspension
Comments: 9
Date: May 12 '21
Time: 2:43pm
baily144
in Stock Suspension
Date: May 03 '21
Time: 9:08pm
baily144
in Stock Suspension
Date: Apr 30 '21
Time: 2:52am
in Stock Suspension
Date: Apr 22 '21
Time: 4:55pm
Attached by: Toskavat
Toskavat
in Stock Suspension
Date: Apr 22 '21
Time: 5:01pm
