Best price on QUALITY front end parts?
Postby beazleybub [OP] » May 7th 2012, 2:43am
I'm in the middle of a complete tear down on my Astro's front suspension and priced all the parts at Advance Auto. Needless to say before taxes I got $804.77! :eek: Anybody have some suggestions where I can get quality parts for a reasonable price?
I priced MOOG but am willing to compromise a bit but not on critical safety parts. My wife will be driving this van.
Here's the parts list...
Advance auto parts.
Moog Lower Control Arm Bushing Kit #K6109 25.99 (2 required)
Moog Upper Control Arm Bushing Kit #K6409 53.99 (1 required)
Moog Cam Bolt Kit #K6302 29.99 (1 required)
Moog Adjusting Sleeve #ES2004S 15.99 (2 required)
Moog Upper Ball Joint #k5208 33.99 (2 required)
Moog Lower Ball Joint #K6141 46.99 (2 required)
Moog Sway Bar Link Kit #K5252 5.99 (2 required)
Moog Outer Tie Rod End #ES2019RLT 26.99 (2 required)
Moog Inner Tie Rod End #ES2020RLT 25.99 (2 required)
Moog Right Idler Arm #K6366T 116.99 (1 required)
Moog Left Idler Arm #K6365T 116.99 (1 required)
Moog Drag Link #DS1066 82.99 (1 required)
Moog Lower Coil Spring Isolator #K160046 9.99 (2 required)
Moog Upper Coil Spring Isolator #K160045 9.99 (2 required)
$804.77 total
1997 Chevy Astro 4.3L RWD 230,000 Miles and been to Germany
1997 Chevy Astro 4.3L AWD 205,000 Miles and Possessed
beazleybub
Years of Membership: beazleybub has been a member for 9 full yearsbeazleybub has been a member for 9 full yearsbeazleybub has been a member for 9 full yearsbeazleybub has been a member for 9 full yearsbeazleybub has been a member for 9 full yearsbeazleybub has been a member for 9 full yearsbeazleybub has been a member for 9 full yearsbeazleybub has been a member for 9 full yearsbeazleybub has been a member for 9 full years
Alias (AKA): beazleybub
Extra Info: 1997 Astro 4.3L RWD
  • Questions on Astro Rear end Decisions
    by pasdriz1234 » October 29th 2020, 12:12am in Stock Suspension
    October 31st 2020, 12:59am
  • Front Sway Bar Replacement
    by 4dastro » November 1st 2020, 5:46pm in Stock Suspension
    November 3rd 2020, 7:28pm
    7
    40
    April 13th 2021, 5:34pm
Re: Best price on QUALITY front end parts?
Postby Corsemoto » May 7th 2012, 2:46am
You can either:
Google "advance auto promo codes" and try some of these options to save $
http://www.retailmenot.com/view/advanceautoparts.com
The P20 code is always a good one to save 20% or try inputting other codes to see what gives you the best savings.
or
http://www.rockauto.com/ with dscount code listed in the Vendors Row forum on this site https://www.astrosafari.com/viewforum.php?f=109
or
http://www.amazon.com
are probably the best options for saving money. I spend quite a bit of time researching prices/discounts on items before purchasing to get the best deal possible from decent and reputable sources which allows me to do even more maintenance and upgrades with quality components.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby Jasen » May 7th 2012, 2:49am
I don't see you saving much money over that price for top notch parts, those prices look about the same as far as the parts I recently replaced on mine.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Postby beazleybub [OP] » May 7th 2012, 2:52am
Holy Crap! :shock: Rock Auto has the "Moog Right Idler Arm #K6366T 116.99 (1 required)" for 37.79!! That's 79.20 LOWER!
Thanks for the suggestions :ty:
beazleybub
Postby chevymaher » May 7th 2012, 2:53am
beazleybub wrote:Holy Crap! :shock: Rock Auto has the "Moog Right Idler Arm #K6366T 116.99 (1 required)" for 37.79!! That's 79.20 LOWER!
Keep saving money like that and you will be down to a couple hundred quick.
Topics: 91
Postby Corsemoto » May 7th 2012, 3:03am
Cut and paste part #s into Google Shopping:
http://www.amazon.com/Moog-K6109-Lower-Control-Bushing/dp/B000C59XX8 $16.75
[url]
http://www.amazon.com/Moog-K6409-Upper- ... 519&sr=1-1 [/url] $39.12
Monroe Sensa-Trac Light Truck Shock Absorber #30763 45.99 (2 required)
Incorrect part # correct #37063
http://www.amazon.com/Monroe-37063-Sensa-Trac-Light-Absorber/dp/B000C55LLQ $37.09
http://www.amazon.com/Moog-K6302-Upper-Control-Bushing/dp/B000C54388 $21.31
http://www.amazon.com/Moog-ES2004S-Steering-Center-Link/dp/B000C55VWU $8.6
http://www.rockauto.com/catalog/raframe ... 208-296107 $19.35
http://www.amazon.com/Moog-K5208-Upper-Ball-Joint/dp/B000C59XO2 $23.73
http://www.amazon.com/Moog-K6141-Lower-Ball-Joint/dp/B000C57Y02 $34.93
http://www.amazon.com/Moog-K5252-Sway-Bar-Link/dp/B000C59XL0 $7.92
http://www.amazon.com/Moog-ES2019RLT-Steering-Center-Link/dp/B000C57V8M $21.71
http://www.rockauto.com/catalog/raframecatalog.php?catalog=11&partnum=ES2020RLT&a=FR11-ES2020RLT-242682 $15.36
http://www.amazon.com/Moog-ES2020RLT-Steering-Center-Link/dp/B000C57VAAMoog Right Idler Arm #K6366T 116.99 (1 required) $20.94
http://www.amazon.com/Moog-K6365T-Steering-Idler-Arm/dp/B000C59Y5K $79.47
http://www.amazon.com/Moog-DS1066-Steering-Center-Link/dp/B000C55VL6 $51.22
Moog Upper Control Arm Shaft Kit (OPTIONAL) Includes control arm bushings #K6449 51.99 (2 required)
http://www.rockauto.com/catalog/raframecatalog.php?catalog=11&partnum=K6449&a=FR11-K6449-419273 $31.79
http://www.amazon.com/Moog-K6449-Ball-Joint/dp/B000C57Y6Q/ref=sr_1_1?ie=UTF8&qid=1336356087&sr=8-1 $36.21
http://www.amazon.com/Moog-K160046-Coil-Spring-Insulator/dp/B002M6BYEQ $10.52
http://www.amazon.com/Moog-K160045-Coil-Spring-Insulator/dp/tech-data/B002M6J6VO $10.52
Didn't add it up...
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby paintdrying » May 7th 2012, 3:07am
As a matter of principle I will gladly pay more for a part on rock Auto than I would at any brick and mortar store. Rock auto gives you outstanding deals on shipping as well as parts. They ship super fast, there customer service is first class. I love them, and have been buying for years. Remember to use the discount code.....
Places like Advanced make it with the must have the parts now people.
and of course commercial accounts ...
On a side note, i would replace the bushings that hold the sway bar to the frame as well.
I bought raybestos because Moog was to expensive. They worked for what I needed, maybe I would buy them again. They were a step above total crap.
I just dropped 400 bucks into my front end. I got the kyb heavy duty shocks for the front. The ones i put on the rear are wonderful.
Bit the bullet buy the moog, your wife is driving it- only the best for her!
paintdrying
Topics: 94
Extra Info: 108 000
Postby beazleybub [OP] » May 7th 2012, 3:08am
If I purchased my parts from multiple vendors the shipping would quickly outweigh the parts.
I just saved over $300 using Rock Auto :)
beazleybub
Postby Corsemoto » May 7th 2012, 3:13am
I know, I ordered my front end parts from Rock Auto last year. I just showed both prices to give you an idea on the difference as it can still be cheaper overall to order them from either Amazon or Rock Auto. If you have an Amazon Prime membership ($79 / year) many of those items are eligible for free two day shipping or free super saver shipping.
Rock Auto code is here: https://www.astrosafari.com/viewforum.php?f=109
I'll second, or third that I've had great results with Rock Auto and more than a few mishaps with Amazon recently not to mention the parts can come from many different vendors/sources when purchasing from Amazon.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby beazleybub [OP] » May 7th 2012, 3:30am
Just placed my order with Rock Auto. They had everything on the list minus one K6141 BJ (they only had one in stock) and the shocks. Total was 444.84 with shipping. Not bad at all.
beazleybub
Postby Jasen » May 7th 2012, 3:32am
Good deal, you might try justsuspensions for the shocks.
200k
Ultra gauge
Topics: 260
Images: 101
Postby beazleybub [OP] » May 7th 2012, 3:53am
Funny, I goofed on the Advance auto total cost. :lol:
It actually came to 804.77 before taxes. (fixed the post)
I have to call Rock Auto in the morning. The shopping cart said they only had one K6141 BJ in stock but when I double checked it changed to being in stock. I think the price changed or something. When I placed my order the K6141 came to 15.23 but now if you go to Rock Auto it says 28.79. I must have gotten the last of a sale price or something. I need to call them before they process the order and have them add the other Ball Joint to the order.
Anyhow, I saved some serious coin. :character-beavisbutthead:
beazleybub
Postby Corsemoto » May 7th 2012, 4:04am
Nice! :handgestures-thumbup:
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby beazleybub [OP] » May 15th 2012, 7:59am
Thanks everybody. I appreciate all the advise.
beazleybub
Return to Stock Suspension
It is currently April 13th 2021, 5:34pm
Stock Suspension Forum
in Stock Suspension
Date: Mar 25 '21
Time: 2:54am
BPACH
in Stock Suspension
Date: Mar 22 '21
Time: 11:58pm
Coronavan
in Stock Suspension
Date: Feb 09 '21
Time: 2:18am
Coronavan
in Stock Suspension
Date: Feb 08 '21
Time: 3:11am
in Stock Suspension
Date: Jan 23 '21
Time: 7:38am
cron
