My new 2000 AWD - wow, drifty! Will shocks help?
Postby castlerox [OP] » June 22nd 2013, 11:03pm
Hey all.
I just had the pleasure of test driving my newly acquired 2000 AWD. It's pretty dang nice.
I put on 4 new tires and took her for a spin...
Coming from the Vanagon world, this astro seems SUPER DUPER drifty. I understand it is pretty high profile but I was all over the road from wind and Semi's and grooves in the road. I felt afraid. Winding around at 70 felt plain deadly. Is this normal for an Astro or is an upgraded suspension going to help?
I don't know much about suspension upgrades at all. There will be a 2" lift (OVL) in the future but I would rather spend dollars where they count most at the moment - which is a stable stable ride on the Freeway.
Any thoughts to get her stabilized.
1998 AWD LT
1991 Montero GEN 1 LS
2007 Yamaha XT
Phoenix/Flagstaff, AZ
castlerox
Years of Membership: castlerox has been a member for 7 full yearscastlerox has been a member for 7 full yearscastlerox has been a member for 7 full yearscastlerox has been a member for 7 full yearscastlerox has been a member for 7 full yearscastlerox has been a member for 7 full yearscastlerox has been a member for 7 full years
Topics: 32
Images: 2
  • New Front 2000 AWD Hub
    by Mmusicman » November 6th 2020, 7:15pm in Stock Suspension
    Last post by tungtide View the latest post
    November 6th 2020, 10:21pm
  • '99 AWD Shock Replacement
    by SnacktimeKC » November 2nd 2020, 3:26am in Stock Suspension
    November 20th 2020, 9:39pm
    December 4th 2020, 5:46pm
Re: My new 2000 AWD - wow, drifty! Will shocks help?
Postby deleteitall » June 22nd 2013, 11:18pm
What tires and psi are you running?
deleteitall
Years of Membership: deleteitall has been a member for 9 full yearsdeleteitall has been a member for 9 full yearsdeleteitall has been a member for 9 full yearsdeleteitall has been a member for 9 full yearsdeleteitall has been a member for 9 full yearsdeleteitall has been a member for 9 full yearsdeleteitall has been a member for 9 full yearsdeleteitall has been a member for 9 full yearsdeleteitall has been a member for 9 full years
Topics: 26
Extra Info: LT 4.3 V6 RWD
Postby castlerox [OP] » June 22nd 2013, 11:22pm
Hi!
Kumho Solus K21's 235/70/r15
PSI - Hmmmm.....
1998 AWD LT
2007 Yamaha XT
castlerox
Topics: 32
Images: 2
Postby Sailing_Faith » June 22nd 2013, 11:28pm
A through check of the front suspension is in order. One bad pitman arm can make the vans drift a bit, a few loose bits working together might make quite unruley.
Sailing_Faith
Images: 5
Alias (AKA): s/v Faith
Extra Info: SLT 4.3l RWD G80
Postby deleteitall » June 22nd 2013, 11:29pm
Those are 44 psi max - try setting them to 44 psi and see what that does. The shop probably set them to under 35 psi or lower since that is what the GM door placard states. I run my tires at 44 psi and it helped a lot with sway and handling.
deleteitall
Topics: 26
Postby Corsemoto » June 22nd 2013, 11:31pm
LT tires with stiffer carcass help, so do high quality shocks. If you're going to do a 2" lift at some point, stock length shocks are fine for that amount of lift. I say it a lot but Bilstein HD are pretty amazing on these vans but making sure all the other suspensions and steering components are in good condition along with alignment are critical as well. Moog idler arms and sway bar mounts and link end bushings are a nice upgrade to worn parts. It's likely the torsion bars and leaf springs have sagged as well. Torsion bars could probably use a bit of adjustment to adjust and level ride height. Hellwig makes a rear sway bar kit that would also help with stability.
With those items sorted out, I think you'd be amazed at how much of a difference they make and contribute to a more planted and stable feeling van.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby Leeann_93 » June 23rd 2013, 12:49am
^ beaten to it again.
Postby Corsemoto » June 23rd 2013, 1:02am
Lol, sorry! :oops:
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby Leeann_93 » June 23rd 2013, 1:12am
Corsemoto wrote:Lol, sorry! :oops:
No you're not :lol:
Postby spree001 » June 23rd 2013, 2:06am
Spree001 here. I just put on Michelin LTX M/S2 tires yesterday with no problems. They are 235/75/15's. Ride and handling greatly improved. I tried to make them rub but couldn't. Just thought I'd put it out there Oh, It's my 2000 passenger astro with 36211 miles on it . The tires I took off were the original tires when sold new..
spree001
Years of Membership: spree001 has been a member for 7 full yearsspree001 has been a member for 7 full yearsspree001 has been a member for 7 full yearsspree001 has been a member for 7 full yearsspree001 has been a member for 7 full yearsspree001 has been a member for 7 full yearsspree001 has been a member for 7 full years
Images: 7
Extra Info: ls with 35800 miles
Postby Big_kid » June 23rd 2013, 5:31am
I replaced the shocks on mine, it helped some. Putting LT tires on it made a world of difference though. The "wet sponge" feeling in turns went away, as did most of the body roll. (Genera lGrabber AT2, I run 44PSI in them)
Firing on 7 Cylinders (L7)
Topics: 185
Images: 333
Extra Info: 2WD 5.7 V8
Postby castlerox [OP] » June 23rd 2013, 7:19am
Damn... my gut was telling me I was buying the wrong tires....
1998 AWD LT
2007 Yamaha XT
castlerox
Topics: 32
Images: 2
Postby crgastro » June 23rd 2013, 7:54am
i had those tires they were on my Outback for 20k miles they were half worn down and there is an on ramp to i-205 in Vancouver Washington that i could take in my outback and could get the whole car sideways on a stock non turbo 1998 Subaru Outback with 200k miles on it. i did not buy them again.
crgastro
Years of Membership: crgastro has been a member for 10 full yearscrgastro has been a member for 10 full yearscrgastro has been a member for 10 full yearscrgastro has been a member for 10 full yearscrgastro has been a member for 10 full yearscrgastro has been a member for 10 full yearscrgastro has been a member for 10 full yearscrgastro has been a member for 10 full yearscrgastro has been a member for 10 full yearscrgastro has been a member for 10 full years
Topics: 63
Extra Info: LS 4.3L V6 AWD
Postby Leeann_93 » June 23rd 2013, 3:38pm
I took off almost brand new Michelin P-rated tires and put on Firestone Destination LE2 LT-rated tires. Made a huge difference in the wallowy feel of the van. I also run them at 39 psi instead of the 35 on the door sticker.
Postby RECox286 » June 23rd 2013, 3:50pm
Khumo is COO China, and I had to run 38 psi when I unknowingly said OK to a set all around. I prefer any
Mitchelin as they seem to be a more stiff sidewall and you can run them at sticker recommended pressure to
get a decent ride. I simply refuse to put Khumo tires on the truck any more. (Personal preference.)
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby Leeann_93 » June 23rd 2013, 4:00pm
I hate Kumho tires personally, too. But the Michelins that came on the '02 had a max pressure of 34 (!) psi...that wasn't working for me.
I've been very happy with the Firestones on my '99 and on my '02.
Postby Corsemoto » June 23rd 2013, 7:38pm
No you're not :lol:
You got me! :doh: :lol:
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby RECox286 » June 23rd 2013, 9:41pm
Fight nice ! Else I'll stop the truck and put you both out...
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Postby Leeann_93 » June 23rd 2013, 9:50pm
RECox286 wrote:Fight nice ! Else I'll stop the truck and put you both out...
Uncle Bob
We were! Smiling and everything :lol:
Postby castlerox [OP] » June 23rd 2013, 10:14pm
I am going to head to Discount tire tomorrow and see if they can help me out with a swap... Hoping that my 10 years with them will help my case in a swap out. the manager DID manage to talk me into the Kumho's even though I was questioning the ply/rating.
I also just poked my head underneath and noticed the 2 front shocks are mismatched. Is that a big deal?
1998 AWD LT
2007 Yamaha XT
castlerox
Topics: 32
Images: 2
Return to Stock Suspension
It is currently December 4th 2020, 5:46pm
Stock Suspension Forum
petema
in Stock Suspension
Date: Today
Time: 12:51am
Attached by: markmitch
in Stock Suspension
Comments: 18
Date: Nov 10 '20
Time: 2:01am
in Stock Suspension
Date: Nov 06 '20
Time: 6:16pm
keithi70
in Stock Suspension
Date: Oct 17 '20
Time: 12:49pm
Rando
in Stock Suspension
Date: Sep 26 '20
Time: 3:28am
