New upper ball joint needs tightening
Postby swharris [OP] » August 9th 2014, 2:34am
Finished a complete front rebuild and noticed a slight clunk on hard right turns. Opened her up and it turns out the left upper joint was not tight to spec. Upon tightening it, I could not get it to spec before the joint started to spin.
How can I tighten it without the joint spinning? BTW I tried with a jack under the a-arm and with the van on the ground...no luck. Thanks.
swharris
Years of Membership: swharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full years
Topics: 81
Images: 4
Alias (AKA): S4
Extra Info: 4.3 Vortec 2wd
Re: New upper ball joint needs tightening
Postby RECox286 » August 9th 2014, 3:48am
Make darned sure that there is no foriegn object, like grease, dirt, fingers, etc on the twe mating
surfaces BEFORE they are put together. You may even want to rough the tapers with some plumbers'
sandpaper, and then check the fit for misfit, in which case the misfitting piece will need to be changed.
It's not common, but tapers are subject to damage, especially if the joint was loose before it was taken
apart initially. It happens.
Good luck there, and keep on truck'n.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Return to Stock Suspension
It is currently April 13th 2021, 5:28pm
Stock Suspension Forum
in Stock Suspension
Date: Mar 25 '21
Time: 2:54am
BPACH
in Stock Suspension
Date: Mar 22 '21
Time: 11:58pm
Coronavan
in Stock Suspension
Date: Feb 09 '21
Time: 2:18am
Coronavan
in Stock Suspension
Date: Feb 08 '21
Time: 3:11am
in Stock Suspension
Date: Jan 23 '21
Time: 7:38am
