monroe oaverloads not enough?
Postby cowboydan [OP] » August 11th 2010, 10:55pm
here is what i have. they help but not when my back seat is in, and when i have cargo. i think i can raise up 1 more inch... when i figure out how. i think i'll start with body lift resin pucks. then i will shape and insert as spacers inbetween the coil and top plate. i'll do it so i don't have to remove shocks. don't worry i got an idea.... i'll take pics as i go. it will make sense when i get going on it, i just need to find resin pucks? 1.75" diameter?
this is a bit better than lowering my front tq-bars. it rides well....just needs a bit more help
2006 sebring 2.7 touring: DD
cowboydan
Firing on 8 Cylinders (L2)
Topics: 67
Alias (AKA): cbd
Extra Info: 4.3w CL AWD
Re: monroe oaverloads not enough?
Postby astroturf » August 11th 2010, 11:44pm
Cowboy, What are you trying to do?
Thanks, Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby Dirk » August 11th 2010, 11:44pm
Why not replace them with the air inflatable shocks? (can't come up with the right name for them just now)
Then you would be able to adjust them to the load you're carrying.
I myself wouldn't want to mess around with shims between the coil and top plate on these.
1985 Astro conversion, engine type N 4.3 4BBL
If you can't fix it with a hammer you've got an electrical problem!
Parts are cheap breakdowns expensive.
Don't worry about miles per gallon, worry about smiles per gallon!
Dirk
Firing on 8 Cylinders (L1)
Years of Membership: Dirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full years
Images: 11
Extra Info: 4.3L 4BBL
Postby cowboydan [OP] » August 12th 2010, 2:41am
Dirk wrote:Why not replace them with the air inflatable shocks? (can't come up with the right name for them just now)
cause i paid for the shocks and i want my moneys worth. i just need one more inch of lift in the back to make it sit right. i don't need to replace shocks, i need to replace the bagged springs, but i don't have $$$ for new leafs.
cowboydan
Topics: 67
Alias (AKA): cbd
Postby workinVan » August 12th 2010, 3:22am
those shocks don't "lift" they support
they're made to keep the bounce out of heavy loads
if the leaf springs are shot then the only way to lift the body back up is to fix the springs
hit the junk yards and try to find an 03 to 05 to replace them affordably
i did the same shocks and did the same fix i suggested
2000 cargo 4.3 v6 W rwd, a/c, G80, silverstars, hood struts, magnaflow cat
and a big honkin air filter....possibly for sale make an offer
workinVan
Years of Membership: workinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full years
Topics: 9
Alias (AKA): notjim
Extra Info: 4.3 rwd cargo
Postby cowboydan [OP] » August 12th 2010, 4:23am
workinVan wrote:those shocks don't "lift" they support
they lifted my van 1" (yes i mesured) when i first put them on. if i put more pressure to the coils, they will lift more. i'm not shoping for leafs this year, i need other parts. this mod will be next to free, and it won't take me long to make them fit. when i find what i'm looking for, i will post pics,
cowboydan
Topics: 67
Alias (AKA): cbd
Postby Phantom » August 12th 2010, 2:45pm
I used those on a Olds Custom Cruiser wagon when the shocks went bad , they were decent ok but not as good as factory Air adjustable
Air adjustable shocks are quite affordable and many full size cars come with them from the factory,. they are self-adjusting , when the rear has additional weight added and lowers the rear of vehicle ,the sensor automatically increases the air in the shocks raising them to a preset height to bring the rear back to level position, . That position can be set to whatever you want it to be , you can find the air pump on many cars at the salvage yard ,
hope this helps
Phantom
Firing on 7 Cylinders (L4)
Postby workinVan » August 12th 2010, 11:13pm
lifted? or provided a little bit more load support so you got back towards stock height
workinVan
Topics: 9
Alias (AKA): notjim
Postby cowboydan [OP] » August 13th 2010, 12:17am
what's the difference? i didn't put them on to get over stock to begin with. 1" just wasn't enough.
cowboydan
Topics: 67
Alias (AKA): cbd
Postby Dirk » August 14th 2010, 12:14am
I think what workinVan means is, did the overloads lift your Van or simply restored it to stock height?
Dirk
Images: 11
Postby cowboydan [OP] » August 14th 2010, 1:26am
Dirk wrote:I think what workinVan means is, did the overloads lift your Van or simply restored it to stock height?
they are supposed keep stock height. i have pics of my van in in exterior forum. i think i need another inch, just so i can have my back seat in.
cowboydan
Topics: 67
Alias (AKA): cbd
Postby Dirk » August 14th 2010, 1:30am
If I remember correct you said they "lifted" your Van.
That would mean the back is either to heavy or the springs are worn out.
My guess is the springs are due for replacement.
Dirk
Images: 11
Postby cowboydan [OP] » August 14th 2010, 2:13am
Dirk wrote:If I remember correct you said they "lifted" your Van.
defenition of lift: to raise from one point to to a higher position, (1"). i had already mentioned that my springs were bagged and needed to be replaced
cowboydan
Topics: 67
Alias (AKA): cbd
Postby astroturf » August 14th 2010, 2:28am
astroturf wrote:Cowboy, What are you trying to do?
Thanks, Jim
Again, I ask. What are you trying to do?
Then just do it already, and stop with the banter...
Jim
astroturf
Topics: 112
Postby cowboydan [OP] » August 14th 2010, 2:41am
Thanks, Jim
Jim
just trying to get one more inch. you don't like banter?
cowboydan
Topics: 67
Alias (AKA): cbd
Postby astroturf » August 14th 2010, 2:42am
I love constructive banter...
astroturf
Topics: 112
Postby cowboydan [OP] » August 14th 2010, 2:51am
astroturf wrote:I love constructive banter...
contructive reading helps constructive banter.
cowboydan
Topics: 67
Alias (AKA): cbd
Postby astroturf » August 14th 2010, 2:59am
Well Thanks Cowboy...
I had never considered that.
Thanks Again, Jim
astroturf
Topics: 112
Postby workinVan » August 15th 2010, 4:59pm
constructive thinking helps with constructive results,
so i guess we've established that your springs suck and need to be replaced when you can afford to
and that the monroes are a stock height shock and can not provide lift above stock height or any adjustable lift either
so the resolution to the problem would be...
either replace springs or a 4 link setup with adjustable coilovers
ok glad we got that figured out, i'm gonna be somewhere else now not caring anymore, thanks and your welcome
notjim
workinVan
Topics: 9
Alias (AKA): notjim
Return to Stock Suspension
It is currently March 7th 2021, 1:42pm
Stock Suspension Forum
Coronavan
in Stock Suspension
Date: Feb 09 '21
Time: 2:18am
Coronavan
in Stock Suspension
Date: Feb 08 '21
Time: 3:11am
in Stock Suspension
Date: Jan 23 '21
Time: 7:38am
tungtide
in Stock Suspension
Date: Jan 04 '21
Time: 3:53pm
tungtide
in Stock Suspension
Comments: 25
Date: Jan 03 '21
Time: 9:09pm
