SO my 2002 cargo currently has 1 bums stop that looks like a stack of donuts. We I went to the local pick a part and the only stops I could find on an astro where solid rubber triangle shape things. Physically I believe they will fit on the axle, but my concern is they are about 1" taller then the one that is on the van.
If I leave them tall it will limit the travel, but if I overload the van the limited travel could help as it wont bottom out the shocks. If not I can trim down the bumps by about 1" to match what is currently there assuming that is the stock height and it has not flattened out a bit.
