Will 4.3 upgraded injectors swap into 5.7 injector housing
Postby timothy47130 [OP] » June 6th 2017, 4:02pm
As you know I am planing a 5.7 swap this month. The 5.7 I bought still has the poppet injectors. A month before my 4.3 went out I did the switch to the upgraded mini multi port injectors. I did some cross referencing and it looks like the 5.7 and the 4.3 use the same injectors. So can I use the 5.7 fuel distributor housing and install the 4.3 mini injectors in it? Of course I know I would be 2 injectors short , But purchasing 2 injectors is a lot less than buying the whole thing. This is a budget build and I need to save where I can. I hate the thought of having to run the poppet injectors untill I can afford the upgraded injector assembly. The 5.7 I got is badly carboned up from the old poppet injectors. Thanks
1998 chevy astro mark III conversion with 125,000 miles
all stock besides-
dual exhaust
rear lifted 1" with s-10 leafs
10,000 lb capacity transmission cooler
corvette 2nd gear servo
Trans-go SK4L60E shift kit
5.7 Vortec swap on the way
timothy47130
Years of Membership: timothy47130 has been a member for 5 full yearstimothy47130 has been a member for 5 full yearstimothy47130 has been a member for 5 full yearstimothy47130 has been a member for 5 full yearstimothy47130 has been a member for 5 full years
Topics: 41
Images: 7
Alias (AKA): Tim
Extra Info: mark III conversion
  • Looking for V8 into AWD info
    by markmitch » September 17th 2020, 5:03pm in V8 Swap
    September 18th 2020, 3:34am
  • 2005 Chavy Astro AWD Cargo Van V-8 Engine swap
    by Porsche928gts » May 26th 2020, 11:55pm in V8 Swap
    Last post by Porsche928gts View the latest post
    May 27th 2020, 10:15pm
    65
    September 21st 2020, 2:42pm
Re: Will 4.3 upgraded injectors swap into 5.7 injector housi
Postby icebrrg3rd » June 6th 2017, 7:47pm
I know it's different for a TBI because the 2 injectors are feeding 8 cylinder instead of 6, but with yours, each cylinder gets an injector all to itself, and the cylinders IIRC are identical in bore & stroke between the 4.3L & 5.7L, so I would tend to agree with your logic that the poppet injectors from a 4.3L will work on a 5.7L (with 2 more, of course).
Of course, I'm not a qualified mechanic, hopefully someone more knowledgeable will pipe in soon whether or not that's true.
Good luck with the budget build.
-Andrew
91 Chevy Astro 5L 5-speed, Ford 9" 261k mi
02 Chrysler Sebring Conv. 2.7L 5-speed 213k mi
10 Chrysler Town & Country 3.8L 180k mi
icebrrg3rd
Firing on 5 Cylinders (L3)
Years of Membership: icebrrg3rd has been a member for 10 full yearsicebrrg3rd has been a member for 10 full yearsicebrrg3rd has been a member for 10 full yearsicebrrg3rd has been a member for 10 full yearsicebrrg3rd has been a member for 10 full yearsicebrrg3rd has been a member for 10 full yearsicebrrg3rd has been a member for 10 full yearsicebrrg3rd has been a member for 10 full yearsicebrrg3rd has been a member for 10 full yearsicebrrg3rd has been a member for 10 full years
Topics: 49
Alias (AKA): Andrew
Van Model Year: 1991
Postby AstroWill » June 6th 2017, 7:52pm
No, you will have to buy the entire spider assembly.
Topics: 106
Images: 437
Postby timothy47130 [OP] » June 6th 2017, 8:28pm
You sir are right. I just read the TSB on the injectors and it states do not swap injector types. The bracket that holds them in the housing is different. Guess I will be cleaning the old poppet injectors for now. I will never find a 5.7 upgraded injector assembly at the junkyards around here for a decent price. They want almost new price for one.
all stock besides-
dual exhaust
timothy47130
Topics: 41
Images: 7
Alias (AKA): Tim
Postby icebrrg3rd » June 6th 2017, 10:28pm
Sorry about that, glad someone in-the-know responded with a correct answer, altho not the one you wanted.
-Andrew
icebrrg3rd
Topics: 49
Alias (AKA): Andrew
Return to V8 Swap
It is currently September 21st 2020, 2:42pm
V8 Swap Forum
in V8 Swap
Comments: 38
Date: Sep 04 '20
Time: 7:14am
in V8 Swap
Comments: 38
Date: Sep 04 '20
Time: 6:38am
in V8 Swap
Comments: 38
Date: Aug 28 '20
Time: 12:41am
dryhumor
in V8 Swap
Comments: 38
Date: Aug 27 '20
Time: 6:32pm
Attached by: Rinny
Rinny
in V8 Swap
Comments: 692
Date: Jul 16 '20
Time: 10:29pm
Users browsing this forum: Master slackerMaster slacker is online! and 7 guests
cron
