Looking for V8 into AWD info
Postby markmitch [OP] » September 17th 2020, 5:03pm
This is pertaining to the old style conventional small block Chevy, ie 350, 305, 327, etc. I need to know specifically how did you deal with the oil pan? Did anyone find an older style oil pan for from the older full front axle trucks? or did you have to fabricate one? Thanks Mark.
Firing on 8 Cylinders (L6)
Topics: 629
Images: 21
Extra Info: RS V8 AWD
  • Non LS V8 4x4 or AWD oil pan
    by markmitch » October 23rd 2020, 12:48am in V8 Swap
    April 10th 2021, 10:58pm
  • LS into Gen1 RWD
    by elstoner420 » February 28th 2021, 3:02am in V8 Swap
    March 15th 2021, 1:08am
    9
    87
    April 12th 2021, 4:07am
Re: Looking for V8 into AWD info
Postby Rinny » September 17th 2020, 5:50pm
Mark how much can you spend on the pan an can you weld?
03Astro AWD/4WD
TorsenDiffs,3:73'S,VettServo
NP236TC
Dual Piston Rear Calipers
GY DTrac 235/85/R16
ARB &/Custom bumpers
2x6x1/4 Rockrails
Rinny
Years of Membership: Rinny has been a member for 5 full yearsRinny has been a member for 5 full yearsRinny has been a member for 5 full yearsRinny has been a member for 5 full yearsRinny has been a member for 5 full years
Images: 6
Extra Info: 5.7L NP236
Postby markmitch [OP] » September 17th 2020, 6:18pm
I can weld but not an oil pan that has to be leak free, I know JTR used to sell a pan for the swap but it is no longer shown on the site and I just received an email saying they only sell the part to be welded in. It has to be tig welded to get it to seal is what I read.
Topics: 629
Images: 21
Postby markmitch [OP] » September 17th 2020, 6:25pm
I think I will measure the front sump of the 4.3 oil pan and go to pick n pull and see what v8 4x4 trucks came with stock
Topics: 629
Images: 21
Postby markmitch [OP] » September 17th 2020, 6:56pm
apparently there is a section of oil pan sold by JTR publishing to weld into the 4.3 steel pan to make it fit the V8 BUT you can no longer buy the 4.3 AWD pan new. So I guess I will have to grab one from pick n pull then take it to a machine shop to have it cleaned thoroughly then take it and the pan section to a welding shop to have it made. I find it hard to believe with all the V8 4x4 trucks made over the years that none will fit this project.
Topics: 629
Images: 21
Postby Mmusicman » September 17th 2020, 8:30pm
Since my AWD body is lifted.. when I put a V8 in mine I intend to lift the motor as well, and not screw with the pan. Something about a sectioned and divided pan bothers me. Raising the mounts shouldn't be difficult at all. I've read that 2 inches of engine lift should be adequate... but uncertain if that applies to Gen 1 V8 block. I'll probably borrow one of those plastic mock-up blocks (from a friend) to fit it for certain.
Topics: 73
Images: 59
Postby Bigforkg » September 18th 2020, 3:23am
Mmusicman wrote:Since my AWD body is lifted.. when I put a V8 in mine I intend to lift the motor as well, and not screw with the pan. Something about a sectioned and divided pan bothers me. Raising the mounts shouldn't be difficult at all. I've read that 2 inches of engine lift should be adequate... but uncertain if that applies to Gen 1 V8 block. I'll probably borrow one of those plastic mock-up blocks (from a friend) to fit it for certain.
Funny, Mmusicman that is what I started today. 2 inch is very close, so I decided to go 2.5 inches. Plus Im putting in a 246 Tcase and needed the room for the slightly different clock position. Second, if a rubber mount failed completely should still be safe, no hole in a pan.
Bigforkg
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: Bigforkg has been a member for 1 full year
Images: 2
Extra Info: V8 4x4 246Tcase
Postby Mmusicman » September 18th 2020, 3:34am
Bigforkg wrote:Funny, Mmusicman that is what I started today. 2 inch is very close, so I decided to go 2.5 inches. Plus Im putting in a 246 Tcase and needed the room for the slightly different clock position. Second, if a rubber mount failed completely should still be safe, no hole in a pan.
Excellent! But when I said 2 inches.. I heard that was the minimum.
With lots of body lift.. I have plenty of room to add an extra inch or so.
2.5 inches sounds perfect.
You will be the expert.
Please take plenty of photos and share! :D
Topics: 73
Images: 59
Postby Bigforkg » September 22nd 2020, 1:26am
Ok, for the OP. Body lift min 3" with an 2.5"engine lift and you can use a stock oil pan. No need to spend $200 to $400 on a pan or modify 2 stock pans.
Bigforkg
Fueling (7/8 tank)
Fueling (7/8 tank)
Images: 2
Postby markmitch [OP] » September 22nd 2020, 2:14am
but when you lift the engine higher doesn't that mean you need to also lift the transmission and T case? then will it not mess with the drive shafts , axle /angles and such? I am no expert but the drivetrain angles must be retained or modified to some degree to match up right?
PS: I was told the oil pan can also be brazed -not sure about this info as of yet though.
Topics: 629
Images: 21
Postby Bigforkg » September 22nd 2020, 3:52am
markmitch wrote:but when you lift the engine higher doesn't that mean you need to also lift the transmission and T case? then will it not mess with the drive shafts , axle /angles and such? I am no expert but the drivetrain angles must be retained or modified to some degree to match up right?
Are you going to lift the body? If your keeping it stock height dont bother get a RWD then. With the AWD and v8 you will be modifying more than you think.
Yes. You lift trans and Tcase. The front drive shaft on mine is 1.3 degrees from Tcase to front diff, not even going to worry about that. The rear may need a little adjustment have to see when it goes back in. No different than lifting and putting s10 springs in.
Im sure the pans could piece it together but not going to be cheap if you find someone who can actually do it right. And if it leaks start over.
Bigforkg
Fueling (7/8 tank)
Fueling (7/8 tank)
Images: 2
Postby markmitch [OP] » September 22nd 2020, 5:03am
OK Thank you for the info-added it to my notebook so to speak, I have it saved on my google docs and sent to my email just in case. I will be doing a 2" lift possible 3" replacing the bushings in the differential and I have to make the motor mounts anyway so I got a small block chevy that is junk just to trial fit everything. Which means the frame from the 98 AWD will be sitting in my yard while I make parts and trial fit them. Once I get the parts made some of it will be powder coated. I am eventually switching the t case to a 233 too. I have to take my 2 wheel drive 700R4 apart to swap the output shaft too. The Astro I am putting this into is my 89 rear drive RS shorty. I will look into the ideas you posted Today I will climb under the 98 donor van and measure everything in stock form for my notes too. Thanks for the great info, Mark
Topics: 629
Images: 21
Postby Bigforkg » September 23rd 2020, 12:45am
I was not thinking, im putting a 246 Tcase and its clocked different. So a 231 or 233 is going to have more angle to the drive line.
Bigforkg
Fueling (7/8 tank)
Fueling (7/8 tank)
Images: 2
Postby AstroWill » September 24th 2020, 1:47am
Doesn't the book you purchased cover this? I though it was geared specifically to those engines/swaps.
Images: 473
Postby markmitch [OP] » September 24th 2020, 1:56am
its basic info, nothing in any of my books tells about the oil pan except that the publisher sells a section that will have to be welded into a 4.3 pan then the holes will have to be redrilled to fit the 350. I am most likely going to do this mod since I am not lifting the whole drive train. I will be doing a 3inch body lift then add a leaf type rear suspension lift. since I have both sets of steel factory leafs from two different Astro vans.I already bought most of the parts to swap the u shaped piece out to a bracket made for other trucks. I just need to figure out how to re attach my rear swap bar to it.
Topics: 629
Images: 21
Postby stent » September 30th 2020, 7:04pm
what about Milodon or Moroso oil pans?? i haven't looked into them but they used to be a couple of the go-to companies for engine swap stuff. maybe get lucky with a V8 Vega pan?? by the time a shop cuts up a pan & welds in the JagsThatRun extension patch the cost advantage would probably be gone. it might also be better to alter the sump of a pan rather than having 4 butt welds running across the gasket.
Images: 188
Extra Info: rwd cargo
Postby Mmusicman » September 30th 2020, 7:47pm
markmitch wrote:..I am not lifting the whole drive train. I will be doing a 3inch body lift..
The "body lift" is what gives you room to do the engine lift.
Then there's no need to cut up and weld oil pans.
This is how I will be doing mine
Topics: 73
Images: 59
Postby AstroWill » October 1st 2020, 4:51pm
markmitch wrote:its basic info, nothing in any of my books tells about the oil pan except that the publisher sells a section that will have to be welded into a 4.3 pan then the holes will have to be redrilled to fit the 350. I am most likely going to do this mod since I am not lifting the whole drive train. I will be doing a 3inch body lift then add a leaf type rear suspension lift. since I have both sets of steel factory leafs from two different Astro vans.I already bought most of the parts to swap the u shaped piece out to a bracket made for other trucks. I just need to figure out how to re attach my rear swap bar to it.
Ahh, maybe they updated it from the original. I thought originally they said to just cut two 4.3l AWD oil pans and join them together.
Images: 473
Postby markmitch [OP] » October 2nd 2020, 3:09pm
Yes I got the same info from another site, the one guy took two oil pans from S-10 4x4 trucks and made one v8 oil pan. He also said using two pans requires one weld whereas using two pans only requires one weld so less cahnce of problems. Mark
Topics: 629
Images: 21
Postby MechBob » October 2nd 2020, 3:21pm
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Return to V8 Swap
It is currently April 12th 2021, 4:07am
V8 Swap Forum
Bikley
in V8 Swap
Comments: 23
Date: Apr 10 '21
Time: 11:02pm
Bikley
in V8 Swap
Comments: 42
Date: Apr 10 '21
Time: 10:57pm
Bikley
in V8 Swap
Comments: 23
Date: Apr 09 '21
Time: 2:56am
Bikley
in V8 Swap
Comments: 23
Date: Apr 08 '21
Time: 3:20am
in V8 Swap
Comments: 19
Date: Apr 07 '21
Time: 1:00am
