V-8 SB400 swap and Body Swap
Postby Porsche928gts [OP] » January 1st 2021, 11:06pm
Happy New Years everyone and sorry I have been a stranger, just been so busy with work and side work, I finally decided to retire back on Dec. 4th. Anyways, does anyone know know if I can swap a 2005 AWD chassis with a 1995 Body? I only ask since I came across a sweet 1995 Astro with 97,000 miles in excellent shape, but it's a 2wd. Also makes my life easy since 1995 and older are pre-emissions in New York. Any insight on this would be great. Thanks. Mike
Porsche928gts
Alias (AKA): Mikey
Extra Info: Cargo 2WD
  • L31 Swap questions
    by dcsleeper » November 9th 2020, 12:29am in V8 Swap
    November 27th 2020, 6:27pm
  • Adding injector plugs for v8 swap help
    by Tony410 » February 5th 2021, 2:32am in V8 Swap
    February 5th 2021, 4:11am
    81
    April 14th 2021, 12:29am
Re: V-8 SB400 swap and Body Swap
Postby markmitch » January 1st 2021, 11:39pm
Yes it can be done.
The easiest thing would be to take everything from the 05 and install it into the 95 body after you get the 95 stripped.
The engines are a little different but the 95 engine and trans should be easy to resell. Oh and the 05 has six lug wheels and the 95 has 5 so you would have to also swap the rear axles. I am currently putting a 89 rear drive Astro RS on a 98 AWD frame with a V8. matter of fact I am about 85% done. If you go V8 you will need the passenger side exhaust manifold like this https://www.ebay.com/itm/RH-EXHAUST-MAN ... 2749.l2649
But do not buy one yet let me make sure it fits first since I just ordered mine. I made the motor mounts from 1/4 inch steel plate. you will need a special oil pan made from a 4.3 v6 steel pan I got mine from here but you will have to email the owner to see if he still has some-https://jagsthatrun.com/
then the oil pump pick up for a 4.3 4x4 s-10 to match the pan shape. Now to use a 400 small block I think you may need a special flywheel to fit the 4l60E which is what transmission is in your 05. But I am not sure on this point. Feel free to ask me any questions as you progress on your project. Mark
Firing on 8 Cylinders (L6)
Topics: 629
Images: 21
Extra Info: RS V8 AWD
Postby Porsche928gts [OP] » January 1st 2021, 11:53pm
Hey, thanks markmitch. Can I ask why I can't run the 6 lug rear axle? I prefer the 6 lug since it's getting a SB400 and also plan on adding a snow plow when it's done. Mike
Porsche928gts
Alias (AKA): Mikey
Postby Rod's Trucks » January 2nd 2021, 12:34am
You 'can' run the 5 lug wheels on the front and the 6-lug on the rear, but when it comes to carrying a spare, wha are you planning?
You could also do conversion spacers, if there is such an item for that combination.
Rod J
Rod's Trucks
Topics: 35
Images: 57
Alias (AKA): Rod and/or WE7X
Postby markmitch » January 2nd 2021, 12:46am
if you use the 95 it has the 5 lug on the rear axle which is why I said you will have to swap rear axles. The frame is only under the front so when you swap frames the rear axle is still on the 95 body.
Topics: 629
Images: 21
Postby Porsche928gts [OP] » January 2nd 2021, 1:35am
Ok, now I understand what you are saying. Thanks.
Porsche928gts
Alias (AKA): Mikey
Postby Porsche928gts [OP] » January 2nd 2021, 1:38am
Sorry I missed you Rod, not concerned about a spare at all. Just want to run the 6-lug wheels and suspension that came with the 2005.
Porsche928gts
Alias (AKA): Mikey
Postby Mmusicman » January 3rd 2021, 1:21am
I have a 400-SB sitting on an engine stand (for about 20 years now) that I intend to swap with the engine in my 92 Astro (it has a 350 now). I bought this crate motor NEW from GM back in the 80's.
I LOVE this engine!
Had it in my G20 van for quite a few years.
It has the torque of a BIG BLOCK in a small block package!
Eventually I threw in a Comp Roller Cam, dual quad Offenhauser intake, dual Edelbrock carbs, big-valve angle plug high-compression heads, Pete-Jackson gear drive, Mallory and Accel ignition system, Hooker Super-Comp headers, etc.
It's just waiting for me to bring it back to life!
Here's how it looked back then after I gave it some love...
Eventually I even supercharged it.
It's still sitting on the stand with the supercharger setup.
I only pulled it because (at the time) I put in something bigger.
The 400-SB uses it own EXTERNALLY balanced flex-plate.
You will need to find one compatible with later model transmissions.
Good luck with your project!
Take pictures! :D
Topics: 73
Images: 59
Postby markmitch » January 3rd 2021, 2:18am
Exactly what I was thinking on the flywheel just could not remember why I was thinking that if that makes sense. externally balanced was what I could not remember.
Topics: 629
Images: 21
Postby sixsix » January 3rd 2021, 3:19am
Sounds like I need to get my Popcorn coupons back out.
I Love Peaches also & Wolverines and Gophers
Topics: 39
Images: 1342
Postby markmitch » January 8th 2021, 4:13pm
I orderd a different exhaust manifold for the passenger side of my V8 because the truck manifold I had rubbed against the frame. After doing a bunch of research and looking at pictures I ordered one for an 80's truck with 350/305 V8
I got it in yesterday and it fits perfect.
This is what I ordered: https://www.ebay.com/itm/RH-EXHAUST-MAN ... 2749.l2649
Topics: 629
Images: 21
Return to V8 Swap
It is currently April 14th 2021, 12:29am
V8 Swap Forum
Bikley
in V8 Swap
Comments: 23
Date: Apr 10 '21
Time: 11:02pm
Bikley
in V8 Swap
Comments: 42
Date: Apr 10 '21
Time: 10:57pm
Bikley
in V8 Swap
Comments: 23
Date: Apr 09 '21
Time: 2:56am
Bikley
in V8 Swap
Comments: 23
Date: Apr 08 '21
Time: 3:20am
in V8 Swap
Comments: 19
Date: Apr 07 '21
Time: 1:00am
