So it begins
So it begins
Postby generaljake01 [OP] » March 20th 2009, 2:37am
Finally gettin started on the removal of the 4.3...I plan on taking out the sub-frame for the swap but i wanted the radiator and grille, etc out so i could do some deep cleaning and spray on some gloss black on the frame and underbelly/firewall...OH yeah :angry-cussingblack: by the way, anyone have a decent grille for sale LOL I kinda thought that i was forgettin a couple screws for it to come out...( the 4 or 5 under the grille) :dunce:
anyone have a decent grill for sale??
and so it begins cant get that 4.3 out fast enough
'87 LT with TBI 305/700r4 3.42s---94 S-10 shorty w 350/TH350
generaljake01
Years of Membership: generaljake01 has been a member for 12 full yearsgeneraljake01 has been a member for 12 full yearsgeneraljake01 has been a member for 12 full yearsgeneraljake01 has been a member for 12 full yearsgeneraljake01 has been a member for 12 full yearsgeneraljake01 has been a member for 12 full yearsgeneraljake01 has been a member for 12 full yearsgeneraljake01 has been a member for 12 full yearsgeneraljake01 has been a member for 12 full yearsgeneraljake01 has been a member for 12 full yearsgeneraljake01 has been a member for 12 full yearsgeneraljake01 has been a member for 12 full years
Topics: 24
Re: So it begins
Postby Mr_Roboto » March 20th 2009, 3:51am
I wish, mine is running around grille-less. I ended up using epoxy and cloth to re-inforce it when I still had a grille.
Mr_Roboto
Firing on 1 Cylinder (L2)
Years of Membership: Mr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full years
Topics: 51
Re: So it begins
Postby squeek daddy » April 24th 2009, 9:22pm
i could really use some picks or info on what all needs to be done to take it out that way.. BTW i do ahve a great grill for sale
97 blazer 4 dr 2wd
08 kia spectra (g/f car)
97 astro (part out)
78 olds delta 88 (part out)
my powder coating business http://www.facebook.com/NightOwlPowderCoatingLLC?ref=hl
squeek daddy
Years of Membership: squeek daddy has been a member for 12 full yearssqueek daddy has been a member for 12 full yearssqueek daddy has been a member for 12 full yearssqueek daddy has been a member for 12 full yearssqueek daddy has been a member for 12 full yearssqueek daddy has been a member for 12 full yearssqueek daddy has been a member for 12 full yearssqueek daddy has been a member for 12 full yearssqueek daddy has been a member for 12 full yearssqueek daddy has been a member for 12 full yearssqueek daddy has been a member for 12 full yearssqueek daddy has been a member for 12 full years
Topics: 18
Re: So it begins
Postby astro355 » April 24th 2009, 9:52pm
You really don't need to take the subframe out to do that engine swap in a 1st gen. You will have enough access to do your spring cleaning with the subframe still attached. But hey, if you want to remove it, that's your choice. :2:
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Re: So it begins
Postby generaljake01 [OP] » April 25th 2009, 2:20am
Yeah actually if the the front unbolts behind the radiator like mine did ('87) you dont absolutely have to unbolt the subframe to do the swap but because of how much more room ya get by doing so and how easy it was i did it anyway...you only have 6 large bolts and thats about it, I didnt undo the brake lines but i did unhook the steering yoke and the shift linkage and that give me about 4"-5" of additional clearance=TON OF ROOM...Its probably the easiest swap ive done out of about 4-5 v-8 swaps... (1)grille and headlight bezels (2)all radiator lines(trans coolant & H2O) (3) take off fan belt and fan (4) remove radiator and if u have a/c the condensor *have the A/C lines bled properly...not like i did (5)take loose the ground post behind driver headlight-this will help move the large wiring loom down and out of the way for eng. removal...(6)unhook fuel lines---depending on year and engine=tbi & carb models wont have too much pressure so you can just unhook em...(7) unhook exhaust from manifolds USE LOTS OF PENETRATING OIL (8)on this one i chose to unbolt the electronics/ECM goodies from intake manifold leaving the vacuum hoses and plugs intact, tie them up off to the side (9)undo the throttle and tv cables (10)unbolt the inspection cover and unbolt the torque converter (11) support with a jack and a 2X6(on trans pan) the transmission then take out all bellhousing bolts (12)and since you hopefully unhooked battery unhook & unbolt the starter...(13) and if engine hoist is in place you can unbolt and remove the 2 motormounts...use hoist to just take weight off mounts not actually pull on engine (14) most importantly is the good ole double and triple check to make sure nothing is connecting engine to body or frame :dunce: ALSO---IF YOU CHOSE NOT TO UNBOLT THE SUBFRAME ITS WAAAY EASIER TO GET THE FRONT OF THE VAN LIFTED UP A BIT WHICH GIVES YOU EASIER ACCESS WITH HOIST...I USED THOSE CAR RAMPS TO PARK THE VAN ON AND THIS GIVE ME MORE WORKING ROOM UNDER VAN AND ALSO BETTER ELEVATION FOR HOIST TO GET IN THERE... if you dont lift the van when you try to stick the hoist onto engine the end of the boom/hoist will hit the firewall possibly damaging your wiper motor... Im not sure if that was the kind of input you needed but thats my :2: take it or leave it ...Ill see if i still have any decent pics of removing the V-6... P.S. If i missed anything im sure someone else will chime in or ill remember and repost
generaljake01
Topics: 24
Re: So it begins
Postby generaljake01 [OP] » April 25th 2009, 2:29am
here are a few pics of the early stages of removal...
ONE LAST LOOK AT THE 4.3
GETTING CLOSER
LOOK AT THAT DIRTY GREASY SUB-FRAME = MORE WORK
generaljake01
Topics: 24
Return to V8 Swap
It is currently April 13th 2021, 6:28pm
V8 Swap Forum
Bikley
in V8 Swap
Comments: 23
Date: Apr 10 '21
Time: 11:02pm
Bikley
in V8 Swap
Comments: 42
Date: Apr 10 '21
Time: 10:57pm
Bikley
in V8 Swap
Comments: 23
Date: Apr 09 '21
Time: 2:56am
Bikley
in V8 Swap
Comments: 23
Date: Apr 08 '21
Time: 3:20am
in V8 Swap
Comments: 19
Date: Apr 07 '21
Time: 1:00am
