Thinking about a v8 swap in my 97
Postby boostedmax [OP] » May 18th 2009, 11:18pm
I keep hearing about people doing v-8 swaps in their older astro vans but i can't really get a good answer on how hard it is to do the swap on a 97.
I will be using a 97 motor to replace my current one and was woundering what other parts i will need?
Thanks to anyone who helps.
boostedmax
Years of Membership: boostedmax has been a member for 12 full yearsboostedmax has been a member for 12 full yearsboostedmax has been a member for 12 full yearsboostedmax has been a member for 12 full yearsboostedmax has been a member for 12 full yearsboostedmax has been a member for 12 full yearsboostedmax has been a member for 12 full yearsboostedmax has been a member for 12 full yearsboostedmax has been a member for 12 full yearsboostedmax has been a member for 12 full yearsboostedmax has been a member for 12 full yearsboostedmax has been a member for 12 full years
  • Will a 94 TBI V8 work in a 97 vortec astro?
    by VanLifeFreedom » April 22nd 2020, 4:06pm in V8 Swap
    April 23rd 2020, 7:34am
  • GMC/CHEV V8/4L60E/233 combo from factory?
    by LAZ 1 » June 14th 2020, 9:55pm in V8 Swap
    June 15th 2020, 9:55am
    October 21st 2020, 1:51pm
Re: Thinking about a v8 swap in my 97
Postby Gary » May 19th 2009, 5:14am
We have had members do swaps on the later yr vans.You can follow the same outline in general with the computer and wire harness from the donor v8.Keep in mind that the later vans have to have the engine come out of the bottom of the van via sub frame drop or cut the rad support and weld brackets back in to put it back together.
Let us know if you need anymore help.
Gary
Dearly Departed
Firing on 4 Cylinders (L3)
Topics: 136
Extra Info: high top
Return to V8 Swap
It is currently October 21st 2020, 1:51pm
V8 Swap Forum
Attached by: Rinny
Rinny
in V8 Swap
Comments: 698
Date: Sep 22 '20
Time: 10:19pm
Attached by: Rinny
Rinny
in V8 Swap
Comments: 698
Date: Sep 22 '20
Time: 10:08pm
Bigforkg
in V8 Swap
Comments: 36
Date: Sep 22 '20
Time: 1:18am
in V8 Swap
Comments: 38
Date: Sep 04 '20
Time: 7:14am
in V8 Swap
Comments: 38
Date: Sep 04 '20
Time: 6:38am
