This is the TPI intake I got. I acquired the base from the engine I got, the rails plenum and the runners were bought off a member of http://www.thirdgen.org. It looks pretty awesome IMO, and besides that has decent characteristics for a mild to moderately hot 305 build.
My porting tools. I have a lot of time into the intake with these, mosty using the sanding drums.
Starting out, you can see the gasket material left. It potruded into the port significantly. I ended up replacing the gaskets with Mr. Gasket P.N. MRG-146. These are available through Auto Zone, Summit, Jegs and other palces. Notice the "lip" inside the port. It potrudes in almost 1/8 inch, and the stock gaskets actually stick inside the runner. I'm sure that it is not good for flow, especially if you've got some AS&M or SLP runners.
These are a couple of ports I have worked. This was done with only sanding drums. Notice how the entrance is massive compared to what it previously was. There was also a "bend" inside the left runner that has been smoothed down for a more even transition.
After starting the runners, I used a 6 inch extension on my grinder and did a little work on the insides of the port walls. These aren't perfect or near perfect, I just gave em a quick run over.
Runners from the head side. Not much work here, finished a quick run inside the runners and squared them up a bit with the "flat" sanding disc pictured above.
Plenum entrance. There are two "bumps" in front of the EGR holes here. Removed those, and the bevel at the entrance where the throttle body bolts in.
Where the runners bolt up, merged them together and enlarged them. This is for the plausible future acquisition of some SLP runners that would be heavily ported.
My runners. Not a heck of a lot you can do with stockers, so I just smoothed em a hair.
Stock intake port. notice the lip in the casting.
Lip removed. Sure I lost low end power with this, but hopefully it will help my top end. I guess time will tell.
These are the runners where they meet up with the intake. I enlarged the entrance because the core shift had caused there to be part of the port potruding into the intake area, which can cause turbulence. I smoothed this out with the flat disk then transitioned it in with the 3/4 drums and the 3/8 drums in the corners.
stock exhaust runner. note how much the valve guide potrudes into the port. Not good
Ported runner, I also cut the valve guide as you can see. I went all out on these, as the polishing reduces carbon and heat retention.
This is the stock exhaust port. You can get an idea of how much the valve guide potrudes into these heads, and how much the throat narrows.
Ported throat once again the valve guide cut. Becomes a lot more obvious how much matieral was removed from the guides, and once gaain no more lip either. I suspect this will be detrimental to the intake but far less detrimental to the exhaust since it's going out not in.
