What kinda HP can I expect
Postby Bertscova [OP] » September 21st 2009, 9:17pm
I rebuilt a 1994 K1500 vin k 5.7, used the 4.3 TBI unit with the stock 5.7 injectors, converted it to a roller cam,
stock bottom end other than the cam
Here are the cam spec's
The GM part # is 14097395 duration at lash point in degrees (intake/exhaust) is 288/308; duration at .050"
tappet lift (intake/exhaust) is 196/206; and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 431/451.
Valve lash is zero/zero and lobe centerline is 109 degrees
But I'm using 1.6 roller tip rockers
the heads are rebuilt stock with a set of good springs, I believe 194/150
exhaust
a set of those headers recomended for the engine swap.
2.5" pipe to the y then 3" single from y to a 40 series flowmaster single 3" in to dual 2.5 out
with 2.5" tail pipe out the rear.
Can someone give me a rough idea as to the HP i will have on this setup.
Horsies sell cars Torque wins races
1990 2wd Astro Van
1990 5.7 TBI w/roller cam upgrade
700R4
Stock Distributor w/ Upgraded electronics
Bertscova
Years of Membership: Bertscova has been a member for 12 full yearsBertscova has been a member for 12 full yearsBertscova has been a member for 12 full yearsBertscova has been a member for 12 full yearsBertscova has been a member for 12 full yearsBertscova has been a member for 12 full yearsBertscova has been a member for 12 full yearsBertscova has been a member for 12 full yearsBertscova has been a member for 12 full yearsBertscova has been a member for 12 full yearsBertscova has been a member for 12 full yearsBertscova has been a member for 12 full years
Topics: 54
Alias (AKA): Bert
Extra Info: TBI 5.7 Roller
Re: What kinda HP can I expect
Postby Mr_Roboto » September 26th 2009, 8:53pm
As a guess I would say 250-300 if there are some TBI mods done, probably splitting the difference. I would put a TPI or other high pressure fuel pump in the tank b/c you will probably need to put the fuel pressure past 15 PSI to get there which is where the stock pump maxes at. The heads will probably hold you back and eventually the TBI instake will as well.
Mr_Roboto
Firing on 1 Cylinder (L2)
Years of Membership: Mr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full years
Topics: 51
Postby webcat » September 26th 2009, 9:54pm
I would guess 250 HP
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
Postby Bertscova [OP] » September 29th 2009, 12:45am
Mr_Roboto wrote:As a guess I would say 250-300 if there are some TBI mods done, probably splitting the difference. I would put a TPI or other high pressure fuel pump in the tank b/c you will probably need to put the fuel pressure past 15 PSI to get there which is where the stock pump maxes at. The heads will probably hold you back and eventually the TBI instake will as well.
I put a new Bosch fuel pump in with a fuel pressure rating of 26psi But it only hold 15psi at the TB. Is there a fuel pressure reg between the tank and the TB unit.
1990 2wd Astro Van
700R4
Bertscova
Topics: 54
Alias (AKA): Bert
Postby webcat » September 29th 2009, 3:05am
The fuel psi regulator is on your throttle body , i just bought a adjustable regulator that replaces it , i should've bought a external one instead because its kinda hard to adjust when its on your throttle body!
http://www.google.com/product_url?q=htt ... n&sa=title
webcat
Topics: 253
Return to V8 Swap
It is currently April 12th 2021, 6:59am
V8 Swap Forum
Bikley
in V8 Swap
Comments: 23
Date: Apr 10 '21
Time: 11:02pm
Bikley
in V8 Swap
Comments: 42
Date: Apr 10 '21
Time: 10:57pm
Bikley
in V8 Swap
Comments: 23
Date: Apr 09 '21
Time: 2:56am
Bikley
in V8 Swap
Comments: 23
Date: Apr 08 '21
Time: 3:20am
in V8 Swap
Comments: 19
Date: Apr 07 '21
Time: 1:00am
