by Fatjoe216 [OP] » October 8th 2009, 4:32am
by johnny-77 » October 8th 2009, 4:54am
by Bertscova » October 8th 2009, 5:35am
johnny-77 wrote:Even though the 350 starter and the 4.3 starter have the same nose cone the V8 starter has a heaver duty motor on it. Just be sure that you're making a good connection at the starter. The V6 starter will usually work just fine for a stock 350.
by Fatjoe216 [OP] » October 8th 2009, 5:15pm
by Bertscova » October 8th 2009, 9:31pm
by Fatjoe216 [OP] » October 8th 2009, 11:55pm
Bertscova wrote:It was tight to turn it by hand. But when I started it for the first time it turned like normal I didn't notice any drag. But remember I had a new starter with a 800 cca New battery and stock 8.5-1 compression ratio. That will make a difference. How old it your starter and battery, and what is the cca (cold cranking amps) of the battery ? Do you know what your comression ratio is ?
by Fatjoe216 [OP] » October 9th 2009, 3:41am
Fatjoe216 wrote:Bertscova wrote:It was tight to turn it by hand. But when I started it for the first time it turned like normal I didn't notice any drag. But remember I had a new starter with a 800 cca New battery and stock 8.5-1 compression ratio. That will make a difference. How old it your starter and battery, and what is the cca (cold cranking amps) of the battery ? Do you know what your comression ratio is ?
The starter is about 3 yrs old. Battery is 700 cca. Not quite sure of compression ratio. Everything is bone stock no add ons.Prob the same as your's.
by Bertscova » October 9th 2009, 6:58am
by astro355 » October 9th 2009, 11:57am
by Fatjoe216 [OP] » October 9th 2009, 12:22pm
Bertscova wrote:I would put a new starter on it they are $45. for a rebuilt on from napa. You could prob get one cheaper from Advanced Auto but I've never had any luck with theirs. Also charge the battery it could be low
http://www.napaonline.com/MasterPages/N ... -+Standard
by astro355 » October 9th 2009, 12:27pm
Fatjoe216 wrote:Bertscova wrote:I would put a new starter on it they are $45. for a rebuilt on from napa. You could prob get one cheaper from Advanced Auto but I've never had any luck with theirs. Also charge the battery it could be low
I pulled off the stater and applied 12v from the battery. It engages and turns freely. I also charged the battery for a while.
by Fatjoe216 [OP] » October 9th 2009, 12:31pm
astro355 wrote:What exactly do you mean by the engine still drags?
What grade/kind of oil are you running for the break-in?
by Bertscova » October 9th 2009, 10:33pm
by astro355 » October 9th 2009, 11:14pm
by Fatjoe216 [OP] » October 10th 2009, 9:42pm
Bertscova wrote:Like astro355 said you can't get a good test on the starter unless its under a load. A bad starter that won't even turn a old wornout motor could still spin freely off of the vehicle.. I know this is probably a dumb question but did you use assembly lube when you assembled the engine?
by webcat » October 10th 2009, 11:23pm
by astro355 » October 11th 2009, 1:51am
by Fatjoe216 [OP] » October 11th 2009, 7:58pm
by Bertscova » October 11th 2009, 8:22pm
by Fatjoe216 [OP] » October 11th 2009, 8:29pm
Bertscova wrote:Do you have fuel. You should be able to see the injectors spraying as you turn the engine over. Does it try to start or back fire or any thing.
It is currently February 25th 2021, 7:47pm
V8 Swap Forum |
Swapping A V8 Engine Into An Astro/Safari Van, 8-Cyclinder Upgrade, V8 Conversion, Power Increase, V6 to V8. |
Moderator: chevy57bert |
Previous topic Next topic |
Sponsors |
