cooling
cooling
Postby s10-den [OP] » March 27th 2008, 5:36pm
any one got any pics or links to the v8 cooling in a astroI dont want to use an electri fan,just dont trucst them.?Do they want to run on the warm side like a s10?
s10-den
Years of Membership: s10-den has been a member for 12 full yearss10-den has been a member for 12 full yearss10-den has been a member for 12 full yearss10-den has been a member for 12 full yearss10-den has been a member for 12 full yearss10-den has been a member for 12 full yearss10-den has been a member for 12 full yearss10-den has been a member for 12 full yearss10-den has been a member for 12 full yearss10-den has been a member for 12 full yearss10-den has been a member for 12 full yearss10-den has been a member for 12 full years
Re: cooling
Postby s10-den [OP] » March 27th 2008, 5:37pm
Man, this place is like a ghost town....
s10-den
Re: cooling
Postby AstroAustin » March 27th 2008, 7:20pm
s10-den wrote:Man, this place is like a ghost town....
Yea, I can see why you say this.... because from Thu Mar 27, 2008 9:36 am to Thu Mar 27, 2008 9:37 am nobody responded. What a ghost town.
:biglaugh: :biglaugh:
-AstroAustin
[email protected]
Full FBSS Air Suspension :: Triangulated 4-Link :: Engine Driven Compressor :: 4 Air Tanks :: 1/2" SMC Valves :: Phantom Billet Grill
AstroAustin
Firing on 8 Cylinders (L1)
Years of Membership: AstroAustin has been a member for 12 full yearsAstroAustin has been a member for 12 full yearsAstroAustin has been a member for 12 full yearsAstroAustin has been a member for 12 full yearsAstroAustin has been a member for 12 full yearsAstroAustin has been a member for 12 full yearsAstroAustin has been a member for 12 full yearsAstroAustin has been a member for 12 full yearsAstroAustin has been a member for 12 full yearsAstroAustin has been a member for 12 full yearsAstroAustin has been a member for 12 full yearsAstroAustin has been a member for 12 full years
Topics: 120
Images: 18
Van Model Year: 1988
Extra Info: 4.3L V6 FBSS AirRide
Re: cooling
Postby randyre » March 28th 2008, 7:46pm
I don't think they really run any hotter. Its only two more cylinders, and the total volume for the water in the block increased a bit. If you swapped to the V-8 because you blew a head gasket or overheated the V6, then your likely to have the same problem with the V8. :noflame:
If it ran OK before it will be fine. Big thing is, if you stick with the stock fan, you need to make sure you keep the shroud. It does take a bit of trimming, but no big deal. Without, it's likely to overheat.
Personally, I like eletric, dual electric to be exact. A bit of redundancy, plus you can crank the airflow up even when standing still in traffic. Way better than the stock setup IMHO.
Later...
Randy
randyre
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: randyre has been a member for 12 full yearsrandyre has been a member for 12 full yearsrandyre has been a member for 12 full yearsrandyre has been a member for 12 full yearsrandyre has been a member for 12 full yearsrandyre has been a member for 12 full yearsrandyre has been a member for 12 full yearsrandyre has been a member for 12 full yearsrandyre has been a member for 12 full yearsrandyre has been a member for 12 full yearsrandyre has been a member for 12 full yearsrandyre has been a member for 12 full years
Topics: 24
Extra Info: 400HP V8
  • ultimate V8 cooling fan
    by markmitch » May 26th 2014, 4:17pm in V8 Swap
    Last post by Lumpy View the latest post
    June 19th 2014, 3:27pm
    16Replies
    74Replies
    December 2nd 2020, 1:51pm
  • 350 cooling problem
    Attachment(s) by 4x4 VanMan » October 23rd 2014, 3:18pm in V8 Swap
    Last post by 4x4 VanMan View the latest post
    October 26th 2014, 2:53am
  • cooling problem-not much room
    Attachment(s) by markmitch » August 29th 2017, 1:16am in V8 Swap
    Last post by Mr_Roboto View the latest post
    August 29th 2017, 3:53pm
Return to V8 Swap
It is currently December 2nd 2020, 1:51pm
V8 Swap Forum
nwmod39
in V8 Swap
Comments: 143
Date: Nov 27 '20
Time: 1:19am
nwmod39
in V8 Swap
Comments: 143
Date: Nov 21 '20
Time: 2:06am
in V8 Swap
Date: Nov 17 '20
Time: 11:45pm
nwmod39
in V8 Swap
Comments: 143
Date: Nov 16 '20
Time: 6:06am
nwmod39
in V8 Swap
Comments: 57
Date: Nov 09 '20
Time: 5:40am
