350 chevy question
350 chevy question
Postby markmitch [OP] » April 11th 2014, 1:07am
is it possible to bolt 88 TBI heads and TBI intake onto a 75 350 without any issues with compression ratio and such?. My neighbor asked me this today I did not know.
Firing on 8 Cylinders (L6)
Topics: 626
Images: 20
Extra Info: RS V8 AWD
  • V8 swap O2 sensor wire question
    by Bigforkg » February 14th 2021, 12:20am in V8 Swap
    Last post by Bigforkg View the latest post
    February 21st 2021, 5:39pm
    7
    26
    March 1st 2021, 6:12pm
Re: 350 chevy question
Postby markmitch [OP] » April 11th 2014, 1:27am
OK I found the info needed by googling it, Thanks anyway
Topics: 626
Images: 20
Postby 94 Van Guy » April 11th 2014, 2:21am
Don't leave us in the lurch, does it work?
Keith
'91 Chevy G30 Bus 39.3K Miles
Retired
Safari
87 Safari, 91 Astro
86 Astro, 85 Astro
88 Astro, 92 Astro
89 Astro, 88 Astro
94 Van Guy
Firing on 5 Cylinders (L3)
Years of Membership: 94 Van Guy has been a member for 11 full years94 Van Guy has been a member for 11 full years94 Van Guy has been a member for 11 full years94 Van Guy has been a member for 11 full years94 Van Guy has been a member for 11 full years94 Van Guy has been a member for 11 full years94 Van Guy has been a member for 11 full years94 Van Guy has been a member for 11 full years94 Van Guy has been a member for 11 full years94 Van Guy has been a member for 11 full years94 Van Guy has been a member for 11 full years
Topics: 71
Images: 44
Alias (AKA): Keith
Van Model Year: 1991
Extra Info: G30 Bus
Postby Big_kid » April 11th 2014, 3:29am
I was actually wondering about that myself the other day, if an "old school" block would work with more modern heads.
Firing on 7 Cylinders (L7)
Topics: 185
Images: 342
Extra Info: 2WD 5.7 V8
Postby markmitch [OP] » April 11th 2014, 6:31am
yes it may even raise compression ratio since the older blocks had bigger combustion areas to lower comp ratios for smog. old heads were 76 cc and newer are like 64 cc.
thats what I read online.
Topics: 626
Images: 20
Postby Astro Pop » April 11th 2014, 7:47am
But if you raise the compression, where will you get gas with high enough octane to run it without detonation problems?
Astro Pop
Topics: 41
Images: 9
Alias (AKA): Xfirepop
Van Model Year: 1996
Extra Info: AWD - 5 inch lift
Postby Mr_Roboto » April 16th 2014, 6:26pm
You'll raise up about 1.2 points, which isn't a ton considering it's probably an 8:1 wonder unless it has pop up pistons. I'd probably even go as far as to run .015 head gaskets just because the pistons are way likely to be down in the hole more than they should be to be good for quench.
Mr_Roboto
Firing on 1 Cylinder (L2)
Years of Membership: Mr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full years
Topics: 51
Postby markmitch [OP] » April 16th 2014, 11:38pm
yeah I agree from what I have read
Topics: 626
Images: 20
Postby vagabond » April 17th 2014, 1:00am
Thanks folks -- good schooling this old man.
vagabond
Years of Membership: vagabond has been a member for 7 full yearsvagabond has been a member for 7 full yearsvagabond has been a member for 7 full yearsvagabond has been a member for 7 full yearsvagabond has been a member for 7 full yearsvagabond has been a member for 7 full yearsvagabond has been a member for 7 full years
Alias (AKA): Vagabond
Extra Info: LT4.3 V6 RWD
Return to V8 Swap
It is currently March 1st 2021, 6:12pm
V8 Swap Forum
in V8 Swap
Comments: 17
Date: Feb 22 '21
Time: 10:45pm
Attached by: cowgirlcullen
cowgirlcullen
in V8 Swap
Comments: 17
Date: Feb 22 '21
Time: 10:00pm
cowgirlcullen
in V8 Swap
Comments: 17
Date: Feb 16 '21
Time: 11:27pm
cowgirlcullen
in V8 Swap
Comments: 17
Date: Feb 15 '21
Time: 5:41pm
Bigforkg
in V8 Swap
Comments: 9
Date: Feb 14 '21
Time: 12:15am
