So now I take the heads off the motor thinking head gasket, or something else, even though it passes a block test with no HC in the coolant. Take my summit aluminum heads with less than a thousand miles on them in and have them checked for cracks which come out ok. The gaskets looked fine, but the bolts seemed loose when removing the heads so I chalked my problem up to the Chinese head bolts I was using. Throw the motor back together with ARP bolts and steel head gaskets and I still have the exact same problem.
Am I the unluckiest guy at the auto store and can't get a working stat or is there something I'm missing. Took my water pump apart and the impeller is fine and correct direction pump.
The engine in question is a older 4 bolt block, 200cc aluminum heads, Procomp Rpm air gap manifold, headers, RV cam.
One thing I have noticed is that this style of intake has the groove machined into the head for the longer newer style GM thermostats with the rubber ring, I'm running the older shorter style of t-stat.
