Motor Mounts for your v8 swap
Postby JaxSPL [OP] » July 31st 2010, 4:08am
While looking around O-reilly's website I came across motor mounts.
Trans-Dapt - Swap Mount
Part Number: 4676
Price: $114.68
Manufacturer's Warranty - Retain Receipt
For Small Block Chevy V8
With Pads
Part Number: 4696
Call for pricing
Without Pads
Not sure if this will help anybody, and I think places like jagsrus is cheaper. Just thought I would share this info.
"Installer's Nightmare" has officially come to life. Only 1 sub, but loud and clear.
Subwoofer enclosure designer. PM For More Info
JaxSPL
Firing on 8 Cylinders (L1)
Years of Membership: JaxSPL has been a member for 10 full yearsJaxSPL has been a member for 10 full yearsJaxSPL has been a member for 10 full yearsJaxSPL has been a member for 10 full yearsJaxSPL has been a member for 10 full yearsJaxSPL has been a member for 10 full yearsJaxSPL has been a member for 10 full yearsJaxSPL has been a member for 10 full yearsJaxSPL has been a member for 10 full yearsJaxSPL has been a member for 10 full years
Topics: 45
Images: 9
Extra Info: 4.3L V6 SPL
  • V8 and A/C
    by roketrex » March 28th 2020, 3:25am in V8 Swap
    Last post by Mr_Roboto View the latest post
    April 22nd 2020, 11:02pm
  • Will a 94 TBI V8 work in a 97 vortec astro?
    by VanLifeFreedom » April 22nd 2020, 4:06pm in V8 Swap
    April 23rd 2020, 7:34am
    August 13th 2020, 12:54pm
Re: Motor Mounts for your v8 swap
Postby tedanderson » July 31st 2010, 6:08pm
Thanks! This is useful to me.
I'm not doing a swap right away but I've been putting all of my ducks in a row. Not that I have a problem with buying mounts from some guy who builds them in his garage and sells them over the net but I feel a little more comfortable knowing that there is a place that I can call up any time and get them shipped immediately.
tedanderson
Firing on 8 Cylinders (L3)
Topics: 76
Alias (AKA): 2Big4aMiniVan
Postby Mr_Roboto » July 31st 2010, 8:52pm
I got mine off an ebay seller. It wouldn't surprise me to find out they are all from the same person quite honestly at least the same pattern. If you saw how thick they were I doubt you'd have too much concern. They were at least 2 if not 3 times as thick as the OEM mounts and the welds looked very nice. The only caveat I had was that I had to grind one for header clearance which is normal from my understanding.
Mr_Roboto
Firing on 1 Cylinder (L2)
Years of Membership: Mr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full years
Topics: 51
Postby Roaring4.3L » August 1st 2010, 8:42pm
Another option would be www.jagsthatrun.com they are showing the mounts for 2WD applications for $58 inc. shipping and the ones for AWD for $134
Andrew
1988 G-20 4.3L Vin Z THM400 (T/V Dreaming Leo)
1986 Celebrity Eurosport Sedan 2.5L Vin R (The Road Warrior)
1984 Fiero 2M4 SE 2.5L Vin R 4 Speed (The Arwing)
Roaring4.3L
Years of Membership: Roaring4.3L has been a member for 10 full yearsRoaring4.3L has been a member for 10 full yearsRoaring4.3L has been a member for 10 full yearsRoaring4.3L has been a member for 10 full yearsRoaring4.3L has been a member for 10 full yearsRoaring4.3L has been a member for 10 full yearsRoaring4.3L has been a member for 10 full yearsRoaring4.3L has been a member for 10 full yearsRoaring4.3L has been a member for 10 full yearsRoaring4.3L has been a member for 10 full years
Alias (AKA): Kovu
Extra Info: W4.3L RWD
Postby HVACPhil » August 17th 2010, 11:40pm
I got mine with the pads at Summit for $85, trans dapt brand.
HVACPhil
Years of Membership: HVACPhil has been a member for 10 full yearsHVACPhil has been a member for 10 full yearsHVACPhil has been a member for 10 full yearsHVACPhil has been a member for 10 full yearsHVACPhil has been a member for 10 full yearsHVACPhil has been a member for 10 full yearsHVACPhil has been a member for 10 full yearsHVACPhil has been a member for 10 full yearsHVACPhil has been a member for 10 full yearsHVACPhil has been a member for 10 full years
Extra Info: 5.7l V8 rwd
Postby TheRealDaddy » August 18th 2010, 1:39am
I just fabricated mine, using the old mounts to start with.
If you swap drivers side to passenger and passenger to driver you will find out that one of the holes lines up.
From there the hardest part was to weld a piece of plate steel onto the old mount and drill some holes.
I then had to trim the top of the drivers side mount (formerly the passenger side) to make room for the manifold, and you much make a notch at the bottom of which ever mount is on the same side as your knock sensor. Sorry I don't have better pictures of the finished product.
Please just call me Carter
current modes of transport:
91 GMC Safari XT 5.7 350
89 GMC Safari 5.7 350
83 Honda Shadow VT750C
78 Chevy El Camino (still in progress)
99 Hyundai Accent
08 Roketa JM Star touring scooter
TheRealDaddy
Years of Membership: TheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full years
Topics: 7
Alias (AKA): Carter
Extra Info: XT 5.7 V8 2WD
Postby Astro95 » January 10th 2011, 8:06am
I got a set of the Trans Dapt mounts from Summit. They were so badly made that I sent them back. I got another set from JTR (Jags That Run). They're a different style that's made from one piece of metal with the ears bent up. They're light years ahead of the old design.
1995 Astro 383/4L60E
Check out my engine swap pictures at http://www.facebook.com/album.php?aid=3 ... 755c74f24f
Astro95
Years of Membership: Astro95 has been a member for 11 full yearsAstro95 has been a member for 11 full yearsAstro95 has been a member for 11 full yearsAstro95 has been a member for 11 full yearsAstro95 has been a member for 11 full yearsAstro95 has been a member for 11 full yearsAstro95 has been a member for 11 full yearsAstro95 has been a member for 11 full yearsAstro95 has been a member for 11 full yearsAstro95 has been a member for 11 full yearsAstro95 has been a member for 11 full years
Return to V8 Swap
It is currently August 13th 2020, 12:54pm
V8 Swap Forum
Attached by: Rinny
Rinny
in V8 Swap
Comments: 690
Date: Jul 16 '20
Time: 10:29pm
in V8 Swap
Comments: 690
Date: Jul 14 '20
Time: 11:58pm
Attached by: Rinny
Rinny
in V8 Swap
Comments: 690
Date: Jul 11 '20
Time: 9:42pm
Attached by: Rinny
Rinny
in V8 Swap
Comments: 690
Date: Jul 11 '20
Time: 9:40pm
Attached by: Rinny
Rinny
in V8 Swap
Comments: 690
Date: Jul 11 '20
Time: 9:37pm
