v-8 swap
v-8 swap
Postby dineros [OP] » August 18th 2010, 3:48pm
I have a v-8 5.7 350 from vandura 4X4 93.
my van is 93 RWD 4.3 4L60E .
will the TC from my 4L60E fitt ?
waht about the ECM? can i use the original v-6 ?
i'm waiting for the v-8 mounts from JTR and i want to start do the v8 swap...
dineros
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: dineros has been a member for 12 full yearsdineros has been a member for 12 full yearsdineros has been a member for 12 full yearsdineros has been a member for 12 full yearsdineros has been a member for 12 full yearsdineros has been a member for 12 full yearsdineros has been a member for 12 full yearsdineros has been a member for 12 full yearsdineros has been a member for 12 full yearsdineros has been a member for 12 full yearsdineros has been a member for 12 full yearsdineros has been a member for 12 full years
Topics: 9
Alias (AKA): NAOR
Extra Info: SLE 5.7L V-8 RWD
  • V-8 SB400 swap and Body Swap
    by Porsche928gts » January 1st 2021, 11:06pm in V8 Swap
    January 8th 2021, 4:13pm
  • L31 Swap questions
    by dcsleeper » November 9th 2020, 12:29am in V8 Swap
    November 27th 2020, 6:27pm
    90
    February 28th 2021, 1:57am
Re: v-8 swap
Postby chevy57bert » August 18th 2010, 9:30pm
You still have the Vandura? Would be easier if You have the ECM and wiring from that Car...
chevy57bert
Section Moderator
Section Moderator
Firing on 7 Cylinders (L3)
Years of Membership: chevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full years
Topics: 69
Images: 68
Alias (AKA): Bertjuh
Extra Info: Ext 4.3L rwd
Re: v-8 swap
Postby dineros [OP] » August 19th 2010, 4:06am
No , i don't have the ecm from it...
dineros
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 9
Alias (AKA): NAOR
Re: v-8 swap
Postby TheRealDaddy » August 19th 2010, 5:09am
dineros wrote:I have a v-8 5.7 350 from vandura 4X4 93.
That's a good match and should make things easy. The wiring harness should plug right in but you need to retain all the V8 engine controls. (ECM and MAP sensor) On the same note, use the Oil pressure sending unit and the water temperature sending units out of your V6 to keep your gauges reading correctly.
Please just call me Carter
current modes of transport:
91 GMC Safari XT 5.7 350
89 GMC Safari 5.7 350
83 Honda Shadow VT750C
78 Chevy El Camino (still in progress)
99 Hyundai Accent
08 Roketa JM Star touring scooter
TheRealDaddy
Years of Membership: TheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full years
Topics: 7
Alias (AKA): Carter
Extra Info: XT 5.7 V8 2WD
Re: v-8 swap
Postby dineros [OP] » October 29th 2010, 5:47am
update .
The V-8 is in the van.
I need to do the AC,ALT,VENT etc. and the shift kit for the trans.
pics in the gallery.
dineros
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 9
Alias (AKA): NAOR
Re: v-8 swap
Postby chevy57bert » October 30th 2010, 12:03pm
Did you encounter any problems to get it fit right? Exhaust clearance, What kind off Exhaust-manifolds did you use?
chevy57bert
Section Moderator
Section Moderator
Topics: 69
Images: 68
Re: v-8 swap
Postby dineros [OP] » October 30th 2010, 5:08pm
The same Exhaust-manifolds that come with the v-8 it's was perfect . a littel bents and it's in the place.
dineros
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 9
Alias (AKA): NAOR
Return to V8 Swap
It is currently February 28th 2021, 1:57am
V8 Swap Forum
in V8 Swap
Comments: 17
Date: Feb 22 '21
Time: 10:45pm
Attached by: cowgirlcullen
cowgirlcullen
in V8 Swap
Comments: 17
Date: Feb 22 '21
Time: 10:00pm
cowgirlcullen
in V8 Swap
Comments: 17
Date: Feb 16 '21
Time: 11:27pm
cowgirlcullen
in V8 Swap
Comments: 17
Date: Feb 15 '21
Time: 5:41pm
Bigforkg
in V8 Swap
Comments: 9
Date: Feb 14 '21
Time: 12:15am
