Noise from new cap and rotor
Postby ctrice [OP] » December 14th 2010, 10:22pm
My wifes 2001 Safari was missing fairly bad through out the driving range, but especially noticeable at high speeds. My first thought was to change the cap and rotor which luckily did the trick (The old ones were trashed). My problem is that the new rotor clicks inside the rotor cap pretty loudly. The van is running great now, but outside of being kind of annoying should I be worried about the clicking at all. I am confident I installed everything nice and secure i.e. tightened the rotor and cap down as far as they could/should go. Any thoughts?
ctrice
Years of Membership: ctrice has been a member for 11 full yearsctrice has been a member for 11 full yearsctrice has been a member for 11 full yearsctrice has been a member for 11 full yearsctrice has been a member for 11 full yearsctrice has been a member for 11 full yearsctrice has been a member for 11 full yearsctrice has been a member for 11 full yearsctrice has been a member for 11 full yearsctrice has been a member for 11 full yearsctrice has been a member for 11 full years
  • Replaced plugs, cap, coil and ICM, now code P0108 is showing
    by tofino » July 4th 2020, 3:48pm in Engines
    Last post by sfeaver View the latest post
    July 6th 2020, 11:18pm
  • Oil fill cap keeps ghosting!
    by SlowRider » June 14th 2020, 5:04am in Engines
    Last post by Big_kid View the latest post
    June 14th 2020, 9:14pm
    7
    75
    October 26th 2020, 5:50pm
Re: Noise from new cap and rotor
Postby chevymaher » December 14th 2010, 10:27pm
Can you hear it with cover on. Or only off.Mine loud as snot with cover off always has been.Cant hear it once cover on.
Postby ctrice [OP] » December 14th 2010, 11:00pm
It's pretty dog-gone loud with the cover off and quite noticable with the cover on. I drove it around for a while and it seemed to dissapate some and I didnt really notice it at high speed. I did an experiment by not telling my wife about it before she drove it for the first time and she called me right away thinking something was wrong so it definitly was not there prior to the fix and It is loud enough for her to notice right away.
ctrice
Postby RECox286 » December 14th 2010, 11:34pm
Strange. Which flavor Cap and Rotor did you choose ? I've owned several different years from 85 to 01, but never had a clicking from the Dist. Always used the better parts, the caps with brass in the towers (Blue Streak, Borg Warner Select, the like. Could be the parts you chose to use, especially if it did not make noise before the change.
Let us know, and we'll put those parts on the naughty list. (maybe)
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby Phantom » December 14th 2010, 11:58pm
You could try removing it , inspecting to make sure no debris is caught inside cap , also check to be sure that the rotor is seated properly , it has little tabs on the bottom that fit in holes on the distributor and maybe it is not seated down all the way and sticking up a little causing a noise when spinning fast , Mine does not make any noise, yours should not either.
Phantom
Firing on 7 Cylinders (L4)
Postby ctrice [OP] » December 15th 2010, 2:31pm
I'll have to check on the parts brand name but they were generic from Advance Auto. They didnt appear to be poor quality. I am certain I installed them correctly with the plastic pins seated properly on the rotor. It is friggin' freezing here right now and I dont have a warm place to work on the van so I will deal with the clicking for now as the van is running fine. When it warms up a tad (above 35 at least) I will pull the cover and double check the install. I still welcome any comments though. thanks again
ctrice
Postby Phantom » December 15th 2010, 2:52pm
That clicking could possibly be spark arcing , maybe the coil wire , spark plug wire , use some dielectric grease in the boot ends . when you remove the engine cover run engine at night and look to see if you can see the arcing .
Phantom
Postby RECox286 » December 15th 2010, 3:08pm
If you take a look at some of the older posts, I'm sure you will find lots of discussion about ignition parts, the good-the bad-the ugly, the dos and don'ts, the whyfors and whynots.
'nuff said, on Dasher, on Comet, on Donner and Blitzen, dash away, dash away, dash away all... and to all a good night.
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Postby chevymaher » December 15th 2010, 3:12pm
You da man Bob you as silly as I am
It is currently October 26th 2020, 5:50pm
AstroTan
Date: Oct 21 '20
Time: 8:02pm
Attached by: Sparkydog
Sparkydog
Comments: 13
Date: Oct 20 '20
Time: 4:01pm
Sparkydog
Comments: 0
Date: Oct 13 '20
Time: 8:49pm
Comments: 61
Date: Oct 09 '20
Time: 2:58am
hankheat
Date: Oct 07 '20
Time: 6:30pm
Users browsing this forum: No registered users and 26 guests
