Injector spider question
Postby Nitetimes [OP] » December 27th 2010, 5:13am
Swapping out 4.3, straight swap 4.3 to 4.3 but the fuel lines on the spiders were different, the original had a return line the replacement motor had a steel plug where the return line would be. Is there a diffidence in the unit as far as return/no return? I need to know because the van doesn't want to stay running. It will start and doesn't seem to miss while it's running but it won't run for more than 10-15 seconds then sounds like it's running out of gas (plenty in the tank). About the only thing I didn't swap on the motors was the plenum and the intake/injectors, was hoping to use the 30k mile ones as opposed to the 180k mile ones. We can't find anything else that should be causing this so it seems to be that the no return injector unit has to be causing the problem???
Anyone know for certain if there is a difference or not? If not we need to start looking elsewhere for the solution, Any help would be appreciated...thanks, R
Nitetimes
Years of Membership: Nitetimes has been a member for 9 full yearsNitetimes has been a member for 9 full yearsNitetimes has been a member for 9 full yearsNitetimes has been a member for 9 full yearsNitetimes has been a member for 9 full yearsNitetimes has been a member for 9 full yearsNitetimes has been a member for 9 full yearsNitetimes has been a member for 9 full yearsNitetimes has been a member for 9 full years
Extra Info: 4.3 AWD
  • which injector cleaner fits Astro misfires over 30mph
    by huddy » September 27th 2020, 5:06am in Engines
    October 19th 2020, 1:57pm
  • Let's Look at My Spider and Intake Stuff
    by Sparkydog » September 29th 2020, 3:36pm in Engines
    September 30th 2020, 10:52pm
    9
    66
    November 25th 2020, 2:12pm
Re: Injector spider question
Postby Gary » December 27th 2010, 5:46am
Could you tell us what yr is the engine you put in and what it came from??.
Gary
Dearly Departed
Firing on 4 Cylinders (L3)
Topics: 136
Extra Info: high top
Postby Phantom » December 27th 2010, 5:48am
There are various configurations of the 4.3 depending on what year and VIN you have , the first place I would look is at exactly what versions you have , we can probably get you a diagram , but not knowing what the 2 configurations you have; would not know what way to direct you ,
Phantom
Firing on 7 Cylinders (L4)
Postby Nitetimes [OP] » December 27th 2010, 5:56am
Gary wrote:Could you tell us what yr is the engine you put in and what it came from??.
Nope and nope.....came from a junkyard.
The van is an 04 AWD
No codes came up but it didn't really run long
Nitetimes
Extra Info: 4.3 AWD
Postby Gary » December 27th 2010, 6:08am
Take the casting number off the back of the engine.
Gary
Dearly Departed
Topics: 136
Postby Nitetimes [OP] » December 27th 2010, 4:23pm
Gary wrote:Take the casting number off the back of the engine.
Don't know how much these help but..........
Old motor: GM 4.3LG ... 14099090 ........ D134 .........14
New motor:GM 4.3LG ... 14099090 ........G215 .........14
Edit to add; VIN from van ..... 1GCDL19X84B130729
I'm beginning to believe I either need to change the injector top unit but I just don't see why there would be any difference in them as far as the fuel inlet/outlet ports, or the entire injector spider.
Can anyone tell me how they can run an injected motor with no fuel return line? That kinda has me a bit perplexed? Haven't seen a motor with no return for quite a while. What happens to the excess fuel from the pump at idle? lower volume seems to be the answer but then what happens when you get on it? Smart fuel pump??
Nitetimes
Extra Info: 4.3 AWD
Postby Nitetimes [OP] » December 27th 2010, 4:33pm
I'd really like to get this thing out of here today so any help/ideas you could give would be greatly appreciate!!!! :) :) :) :ty:
Nitetimes
Extra Info: 4.3 AWD
Postby Phantom » December 27th 2010, 5:48pm
Well it seems that the casting number . 14099090 is the same block casting number through many years , not sure what those other number are , more research is needed on that , maybe they are date codes , if you research how GM used date codes it may help decode them , The "X" on a 2004 is the system you have on the old motor
, you may have a "W" engine which is slightly different injection system , maybe you can swap the injection spider from the Old engine onto the new engine , or maybe you can ask the place you got the old engine from what year it is and what it came out of ,
Phantom
Postby Nitetimes [OP] » December 27th 2010, 7:26pm
Phantom wrote:maybe you can swap the injection spider from the Old engine onto the new engine ,
Really hoping to avoid using any more parts than necessary from a 180k motor on a 30k motor but I will if I have to
Nitetimes
Extra Info: 4.3 AWD
Postby doyoulikeithere » December 28th 2010, 2:35am
maybe a stupid question....
Can you pull out the steel plug, and put in the fuel return??
:twisted:
doyoulikeithere
Firing on 7 Cylinders (L1)
Years of Membership: doyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full years
Topics: 26
Images: 11
Postby Nitetimes [OP] » December 28th 2010, 3:23am
doyoulikeithere wrote:maybe a stupid question....
Exactly what I did do. But the more research I do the more likely it seems that it won't work with the 'new' spider. While playing with it today we believe it may be trying to hydro lock, which leads me to believe that whatever year the 'new' one is it won't work with the 2 line (in/out) return system. It seems the return on the single line system is near the tank, with the excess fuel returning back there rather than going thru the injection unit.
Nitetimes
Extra Info: 4.3 AWD
It is currently November 25th 2020, 2:12pm
Attached by: Slime
Slime
Time: 11:11pm
K-TRON
Comments: 23
Date: Nov 16 '20
Time: 1:07am
Attached by: Devonian
Devonian
Date: Nov 13 '20
Time: 2:19am
K-TRON
Comments: 23
Date: Nov 12 '20
Time: 2:51am
Devonian
Date: Nov 11 '20
Time: 10:25pm
