Fuel pump/fuel lines
Postby drew [OP] » December 31st 2010, 4:50pm
I wanted to post this topic in the "Engine" section, but could not find the button for a "New Topic" if a mod could please move this for me, it would be greatly appreciated.
Thanksgiving weekend, i replaced my Fuel pump on my 2004 2WD Astro Cargo. I have driven it close to 2000 worry-free miles. Upon starting the van yesterday, it cranked but stalled, and fuel ran down from my fuel line send coming from the fuel pump. I climbed under the van to find that the nylon fuel line had come disconnected from the metal flared end fuel line that attaches to the frame. I took a look at everything, everything looked good, and I re-installed the line. I've ran the van at idle in my driveway for close to a half an hour, with no issues. I am kind of stumped as to why this may have happenned, at 60psi, i would believe that the line would have blew apart well before this. i also thought quite possibly i hadn't seated both sides of the blue clip in the nylon hose to the flared metal line properly, when i put the fuel pump in. Does anyone have any experience with this sort of problem?
I searched all throughout this forum over the last day and i noticed that there is an O-ring in this area. when everything is taken apart, where should i see this O-ring? Is it inside the flared end of the nylon hose, between the blue plastic clip and the black nylon hose, or should it be between the blue clip and the flared steel line? if there is no O-ring present on my fuel lines, would it hold pressure at all, or would i be leaking fuel all over the place?
Sorry for all the questions at once, but I am stumped, and leaking fuel makes me nervous.
Thanks in advance for any help.
drew
Years of Membership: drew has been a member for 11 full yearsdrew has been a member for 11 full yearsdrew has been a member for 11 full yearsdrew has been a member for 11 full yearsdrew has been a member for 11 full yearsdrew has been a member for 11 full yearsdrew has been a member for 11 full yearsdrew has been a member for 11 full yearsdrew has been a member for 11 full yearsdrew has been a member for 11 full yearsdrew has been a member for 11 full years
Topics: 5
Alias (AKA): snotmerchants
Extra Info: Black Cargo Van
  • Fuel Pump Voltage???
    by Left Coast Resident » December 23rd 2020, 4:33am in Engines
    Last post by N6KB View the latest post
    December 24th 2020, 7:49pm
  • Non-Splice Fuel Pump (It's a Bosch)
    by OldSchoolNoe » February 16th 2021, 7:39am in Engines
    March 11th 2021, 10:58pm
    35
    April 12th 2021, 4:11am
Re: Fuel pump/fuel lines
Postby Matrixx » January 1st 2011, 4:31pm
The O rings are located on the inside of the Female Connector.
Might I suggest you spray the Male Connector with some WD40 before you install it. Makes work a lot easier I find.
Hope this helps.:)
Matrixx
Postby drew [OP] » January 1st 2011, 5:57pm
Thank you. It's all back together, and i've been pulling and tugging on that line, it doesn't seem that it will come apart again.
I drove the van about 40 miles yesterday, and everything is still in place.
I'm gonna chalk this one up to not seating the clip properly when i installed the fuel pump.
drew
Topics: 5
Postby Phantom » January 1st 2011, 6:15pm
Is your Astro black ? do you have any pics of your van to share?
Phantom
Firing on 7 Cylinders (L4)
Postby drew [OP] » January 1st 2011, 6:37pm
Phantom wrote:Is your Astro black ? do you have any pics of your van to share?
there's some pics of my van in this thread... they are older pics from around 2004-2005
https://www.astrosafari.com/viewtopic.php?t=6142
drew
Topics: 5
It is currently April 12th 2021, 4:11am
kvargas1356
Time: 10:20pm
Attached by: jfunkngroove
Comments: 17
Date: Apr 10 '21
Time: 10:38pm
Date: Apr 08 '21
Time: 8:52pm
Comments: 17
Date: Apr 08 '21
Time: 1:55am
Date: Mar 22 '21
Time: 2:11pm
Users browsing this forum: roshindelmanroshindelman is online!, SportsBoySportsBoy is online! and 19 guests
