Normal compression readings?
Postby alacran1 [OP] » August 22nd 2016, 5:09pm
Two years ago my dads van had a valve bend on cylinder 1. I took the heads to a machine shop and they machined the heads and installed everything new ready to be installed for $140. I put everything back on together started on the first crank. I took it to get smog twice with it passing right away. Couple days ago it had a cel and a p0301. I did a compression check to see if it wasnt the heads and it read 150 on all cylinders. It turned out to be the cylinder 1 spark plug wire that was touching against the exhaust cylinder toasting it and cracking it. Replaced the wires and she now runs smooth. I never did a compression test before on the van after the heads replacement. Is 150psi on all cylinders good?
alacran1
Years of Membership: alacran1 has been a member for 6 full yearsalacran1 has been a member for 6 full yearsalacran1 has been a member for 6 full yearsalacran1 has been a member for 6 full yearsalacran1 has been a member for 6 full yearsalacran1 has been a member for 6 full years
Topics: 5
Extra Info: 4.3 v6 vortex
  • Incorrect Fuel level readings, bad pump?
    by pmou » July 13th 2020, 9:27pm in Engines
    Last post by MmusicmanMmusicman is online! View the latest post
    July 14th 2020, 4:02am
    50
    October 1st 2020, 4:17am
Re: Normal compression readings?
Postby AstroWill » August 22nd 2016, 8:51pm
Yes.
In 2016 ~66mil voted for Clinton, ~63mil voted for Trump and ~100mil(eligible) didn't vote Make a difference - register+vote!
Topics: 106
Images: 437
Postby Leeann_93Leeann_93 is online! » August 22nd 2016, 10:41pm
Real good
Postby TurnNburn » August 23rd 2016, 12:16am
150 is pretty good for an old motor with im assuming a lot of miles. Typically you are looking for all of the cylinders to be within 10% of each other. if they are all at 150, then you are in great shape.
TurnNburn
Green Status (L4)
Green Status (L4)
Alias (AKA): iGoogle
It is currently October 1st 2020, 4:17am
hankheat
Time: 2:53pm
bradyalderin
Time: 1:53pm
Attached by: Sparkydog
Sparkydog
Date: Sep 29 '20
Time: 3:38pm
Comments: 60
Date: Sep 28 '20
Time: 11:32pm
bradyalderin
Date: Sep 27 '20
Time: 11:43pm
Users browsing this forum: No registered users and 17 guests
