P1406 Auxiliary Emission Control System Failure
Postby grandamle91 [OP] » January 21st 2011, 2:35am
What is this? Came on this morning after starting my van.
97 Astro
-Evan
MONSTRO 97 Chevy Astro 346k
LQ9
4L80E
NP262
Full float 14 bolt 3.73
Tuned for e85
Headers 4in Exhaust
3500 spindles and hubs
285\85-16
98 Pontiac Grand Prix GTP 253k
***Removed Dead Image***
grandamle91
Years of Membership: grandamle91 has been a member for 12 full yearsgrandamle91 has been a member for 12 full yearsgrandamle91 has been a member for 12 full yearsgrandamle91 has been a member for 12 full yearsgrandamle91 has been a member for 12 full yearsgrandamle91 has been a member for 12 full yearsgrandamle91 has been a member for 12 full yearsgrandamle91 has been a member for 12 full yearsgrandamle91 has been a member for 12 full yearsgrandamle91 has been a member for 12 full yearsgrandamle91 has been a member for 12 full yearsgrandamle91 has been a member for 12 full years
Topics: 137
Images: 2
Alias (AKA): Evan
Extra Info: LT 6.0 V8 4L80E NP2
  • Chronic ignition module failure
    by Bikley » July 1st 2020, 4:38am in Engines
  • Sorta Heavy Exhaust (Update cooling pressure system test).
    by gman » March 13th 2020, 6:38am in Engines
    Last post by gman View the latest post
    March 25th 2020, 11:05pm
    68
    July 9th 2020, 4:26pm
Re: P1406 Auxiliary Emission Control System Failure
Postby Phantom » January 21st 2011, 2:47am
DTC P1406 Exhaust Gas Recirculation (EGR) Position Sensor Performance
Phantom
Firing on 7 Cylinders (L4)
Years of Membership: Phantom has been a member for 9 full yearsPhantom has been a member for 9 full yearsPhantom has been a member for 9 full yearsPhantom has been a member for 9 full yearsPhantom has been a member for 9 full yearsPhantom has been a member for 9 full yearsPhantom has been a member for 9 full yearsPhantom has been a member for 9 full yearsPhantom has been a member for 9 full years
Postby grandamle91 [OP] » January 21st 2011, 6:25am
And what does that mean? I know were the egr is, but does it mean its not opening\closing or something else
-Evan
LQ9
4L80E
NP262
Tuned for e85
Headers 4in Exhaust
285\85-16
grandamle91
Topics: 137
Images: 2
Alias (AKA): Evan
Postby Phantom » January 21st 2011, 2:28pm
P1406 is described as
While driving, the EGR monitor commands the EGR valve closed and checks the
differential pressure across the EGR orifice. The test fails when the signal from the DPF EGR sensor continues to indicate EGR flow even after the EGR valve is commanded closed.
Things that can cause it
Downstream hose is disconnected.
Downstream hose is plugged (ice).
Plugged or damaged EGR tube.
Look for signs of water or icing in the hose.
Verify the connection and routing (no excessive dips).
Verify the DPF EGR sensor proper mounting and function. View the DPFEGR PID while applying and releasing vacuum directly to the sensor with a hand pump.
Phantom
Postby grandamle91 [OP] » January 21st 2011, 5:10pm
What hose am i looking for?
-Evan
LQ9
4L80E
NP262
Tuned for e85
Headers 4in Exhaust
285\85-16
grandamle91
Topics: 137
Images: 2
Alias (AKA): Evan
It is currently July 9th 2020, 4:26pm
Yuip
Time: 5:11pm
Comments: 14
Date: Jul 07 '20
Time: 6:27am
Comments: 9
Date: Jul 03 '20
Time: 6:15pm
Star Stuff
Comments: 87
Date: Jul 03 '20
Time: 4:22am
Attached by: ri$e*above
ri$e*above
Date: Jul 03 '20
Time: 1:14am
