Fuel in oil
Fuel in oil
Postby Chey64 [OP] » February 1st 2011, 2:58pm
I have an 94 Astro AWD 4.3
I don't drive it much, and as a matter fact I'm trying to sell it.
The thing is, since I don't drive it much, I would start it let it run to warm it up. Now I smell fuel in the oil.
This motor was swapped in by some Shade trees that I paid to do the job.
New plugs, wires, cap and rotor.
It runs fine down the highway, just that when it is idling it runs rich.
MAP sensor?
Chey64
Years of Membership: Chey64 has been a member for 11 full yearsChey64 has been a member for 11 full yearsChey64 has been a member for 11 full yearsChey64 has been a member for 11 full yearsChey64 has been a member for 11 full yearsChey64 has been a member for 11 full yearsChey64 has been a member for 11 full yearsChey64 has been a member for 11 full yearsChey64 has been a member for 11 full yearsChey64 has been a member for 11 full yearsChey64 has been a member for 11 full years
Extra Info: 4.3L V6 AWD
  • Fuel gauge and fuel filling problems related?
    by swishalump » March 10th 2021, 8:52pm in Engines
    Last post by swishalump View the latest post
    March 12th 2021, 7:48pm
  • Replacing engine sump/oil pan
    by Wokka » October 18th 2020, 8:41pm in Engines
    October 19th 2020, 2:16pm
    50
    April 12th 2021, 3:45am
Re: Fuel in oil
Postby paintdrying » February 1st 2011, 3:02pm
I think the presure regulators on those leak and do that but not sure. I would change the oil and filter and see if the smell returns.
paintdrying
Topics: 94
Extra Info: 108 000
Re: Fuel in oil
Postby Phantom » February 1st 2011, 3:42pm
How long has it been since an oil change?
Regulators may leak ,,,fuel injector may leak , and the design of engines allow gas vapor into the crankcase which is why there is PCV valve which helps expel some of the vapors , If you just let engine run at idle till warm and rarely drive it , it likely has a build up of fuel vapor in oil , time to change the oil as it is diluted with gas and will not protect as it should
Phantom
Firing on 7 Cylinders (L4)
Re: Fuel in oil
Postby RECox286 » February 1st 2011, 7:52pm
1. Oil and Filt change. (for sure)
2. Hook scan tool up and see what the live data is. Possibly it may be easy as the PCM is not going closed loop.
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Re: Fuel in oil
Postby Leeann_93 » February 2nd 2011, 12:03am
Definitely run it down the highway after an oil/filter change and see if you smell anything. These will tend to get a fuel smell if only idling, even if the oil level doesn't increase at all.
Re: Fuel in oil
Postby maximus7001 » February 2nd 2011, 6:31am
Phantom wrote:How long has it been since an oil change?
X2 and as well the normal fuel that gets by the rings during short trips especially in winter.
97 Safari SLT AWD
68 AMC Javelin SST
97 Honda Accord
maximus7001
Years of Membership: maximus7001 has been a member for 12 full yearsmaximus7001 has been a member for 12 full yearsmaximus7001 has been a member for 12 full yearsmaximus7001 has been a member for 12 full yearsmaximus7001 has been a member for 12 full yearsmaximus7001 has been a member for 12 full yearsmaximus7001 has been a member for 12 full yearsmaximus7001 has been a member for 12 full yearsmaximus7001 has been a member for 12 full yearsmaximus7001 has been a member for 12 full yearsmaximus7001 has been a member for 12 full yearsmaximus7001 has been a member for 12 full years
Topics: 10
Images: 2
Extra Info: AWD 400000km
Re: Fuel in oil
Postby Gary » February 2nd 2011, 6:45am
Which fuel injection system do you have??.TBI or CPI??.It could matter. :think:
Gary
Dearly Departed
Firing on 4 Cylinders (L3)
Topics: 136
Extra Info: high top
Re: Fuel in oil
Postby Chey64 [OP] » February 2nd 2011, 1:10pm
I believe that I have TBI.
Is CPI meaning port injection?
Chey64
Re: Fuel in oil
Postby chevymaher » February 2nd 2011, 1:19pm
If you look under hood TBI have an air cleaner that looks just like a carb.The other style is obviously way different.
Topics: 91
It is currently April 12th 2021, 3:45am
kvargas1356
Time: 10:20pm
Attached by: jfunkngroove
Comments: 17
Date: Apr 10 '21
Time: 10:38pm
Date: Apr 08 '21
Time: 8:52pm
Comments: 17
Date: Apr 08 '21
Time: 1:55am
Date: Mar 22 '21
Time: 2:11pm
Users browsing this forum: Google [Bot] and 20 guests
