PCM Programing/Tuning-Lets make this even better and easier
Postby AstroWill [OP] » December 17th 2016, 10:20am
So there might be a few people that need or want to have some changes done to their PCMs and it may not be worth it to invest in the hardware/software to do minor changes and such.
So I'm going to start doing this for the 96 and up PCMs, for now I am going to offer up the ability for you to make the following changes:
Modify EGR/AIR/EVAP/VATS settings
Change VIN number
Adjust for different sized injectors(for marine or 2114 intake swap).
Adjust for tire size/gear ratio changes.
Enable electric fan control on models that support it(97 and up?)
Eventually, this list will expand, to include tuning adjustments, depending on what you guys want/need to have done.
Images: 463
  • engine noise and over heating
    by lukas » August 9th 2020, 4:02pm in Engines
    Last post by MmusicmanMmusicman is online! View the latest post
    August 9th 2020, 8:02pm
  • Need quick response on hissing and missing
    by Jawon » August 31st 2020, 2:59pm in Engines
    August 31st 2020, 10:40pm
    52
    January 24th 2021, 11:21pm
Re: PCM Programing/Tuning-Lets make this even better and eas
Postby chevymaher » December 17th 2016, 2:45pm
You the new computer modification guy.
Since this is your thing. And your doing a good job I may say. The dinosaur computer info was awsome.
Do the world a favor and make a list of the protocol for making body and engine computers communicate as you run across them. It makes the 2 computers sync and sets the passkey systems without the dealer only scanners. For the poor SOB's that eventually need to put a computer in.
After talking to the dealer guy. Seems the computer if it has a dead battery more than a few days will loose this and need reset. And the computer may fry when a new battery is installed. So always keep a trickle charger on it when working on it and the battery is out. They actually recommended keeping it powered while changing the battery to avoid the power surge that damages the computer.
Hey I aint making this crap up either. I put a engine in a buick and the computer went out from not having a battery in it for 2 weeks. Put a battery in and the headlights flashed and went out. Computer was dead after that. After that one or the other headlight would periodically come on when the light switch was turned on.
It is a silly combination of random acts that clear them and make them sync to work as a unit. I sheet you not the buick had as example. And i don't remember the exact order. You turn the key on and off 3X lock and inlock the door a couple times. Then turm on and off the radio in a certain sequence. Then you get a dash light signaling it is activated. Wait till it does its little flashing lights show.
Now the key and computer for the passkey system work both computers are in sync and it starts and eveything works.
But you sill got a code it was the wrong vin. Which never got fixed.
Postby MmusicmanMmusicman is online! » December 17th 2016, 3:20pm
I'd LOVE to be able to adjust my timing and make a few adjustments on my 2000! I'll be watching here with interest!
In the meantime... the only thing I can easily do is make adjustments on my 92's carbureted V8 without issue, without programming cables, without a computer, without a specific program or programming knowledge! :D
My 92 can also sit dead for ANY length of time... and with fresh battery it will fire right up every time! :D
So... what do I need to get started? (not my 92..lol)
Firing on 7 Cylinders (L5)
Topics: 73
Images: 49
Postby juststartin » December 17th 2016, 4:08pm
I'll be watching
03 Astro Cargo 4.3L RWD
I love Oscar the van....most of the time
juststartin
Years of Membership: juststartin has been a member for 9 full yearsjuststartin has been a member for 9 full yearsjuststartin has been a member for 9 full yearsjuststartin has been a member for 9 full yearsjuststartin has been a member for 9 full yearsjuststartin has been a member for 9 full yearsjuststartin has been a member for 9 full yearsjuststartin has been a member for 9 full yearsjuststartin has been a member for 9 full years
Topics: 9
Extra Info: cargo 4.3L RWD g80
Postby WimpTech » December 17th 2016, 4:19pm
Will do you have a TECH2? You're welcome to use mine for the cause, PM me.
WimpTech
Firing on 3 Cylinders (L5)
Topics: 38
Images: 322
Alias (AKA): =Wimpy=
Extra Info: AWD 3+1 Lift
Postby AstroWill [OP] » December 18th 2016, 8:08am
Wimpazz wrote:Will do you have a TECH2? You're welcome to use mine for the cause, PM me.
I have access to one on and off, but have decided not to buy one. I will be getting one of the $100 adapters to use with Tech2Win(does everything tech2 does but in an emulator).
Images: 463
Postby Corsemoto » December 18th 2016, 7:58pm
Thanks Will, I've been researching and thinking about Tech2Win as well. Is this the adapter you've been looking at or something different?
http://www.ebay.com/itm/New-VXDIAG-VCX-NANO-Code-Reader-for-GM-Tech2Win-and-GDS2-Diagnostic-Tool-/252297917469?hash=item3abe20b41d:g:yZ8AAOSwoudW2k~d&item=252297917469&vxp=mtr
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby AstroWill [OP] » December 18th 2016, 8:29pm
Corsemoto wrote:Thanks Will, I've been researching and thinking about Tech2Win as well. Is this the adapter you've been looking at or something different?
Yes, that is exactly the one(and the one with Wifi) I have been looking at.
Images: 463
Postby redfury » December 18th 2016, 8:33pm
keep us Updated on this adapter. I can't justify buying a Tech2, or any scanner that is in the 500 dollar range used that is halfway decent for my own use, this would be nice to use with my laptop ( which I paid a whopping $90 for this summer ).
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Postby AstroWill [OP] » December 18th 2016, 9:13pm
redfury wrote:keep us Updated on this adapter. I can't justify buying a Tech2, or any scanner that is in the 500 dollar range used that is halfway decent for my own use, this would be nice to use with my laptop ( which I paid a whopping $90 for this summer ).
If you keep an eye out on sales and such, the clone tech2 can be had for right around $200, usually $250-300 without a storage case. But the Tech2win software is faster(depending on the computer you run it on), larger screen, touchscreen support if your laptop has a touchscreen, etc etc.
I can also confirm that using the RedDevilRiver ALDL adapter(they have them in bluetooth as well, but I have the USB model) in combination with ALDLdroid and a microUSB adapter work perfectly with my tablet on the older models for getting real time information out of them. Not as easy or cheap as OBD2, but you have to work with what you have.
Images: 463
Postby dramey » December 18th 2016, 9:55pm
They ship worldwide but not to Alaska. idiots.
dramey
Firing on 7 Cylinders (L1)
Extra Info: AWD Cargo Van
Postby AstroWill [OP] » December 18th 2016, 10:00pm
dramey wrote:They ship worldwide but not to Alaska. idiots.
Who are you talking about?
BTW, I won't ship to Alaska either ;)
Images: 463
Postby dramey » December 18th 2016, 10:07pm
I was referring to that adapter in the ebay link that corsemoto posted.
dramey
Postby AstroWill [OP] » December 18th 2016, 10:26pm
dramey wrote:I was referring to that adapter in the ebay link that corsemoto posted.
Just grab one from a different seller.
Images: 463
Postby AstroWill [OP] » December 18th 2016, 11:08pm
chevymaher wrote:So always keep a trickle charger on it when working on it and the battery is out. They actually recommended keeping it powered while changing the battery to avoid the power surge that damages the computer.
I think that is more of removing the battery to charge it, some of the crap chargers will put out more than 17-18volts and yes, that can definitely fry computers. So if you are using one of those chargers, definitely remove the battery to charge it which really is a good practice anyway.
chevymaher wrote:It is a silly combination of random acts that clear them and make them sync to work as a unit. I sheet you not the buick had as example. And i don't remember the exact order. You turn the key on and off 3X lock and inlock the door a couple times. Then turm on and off the radio in a certain sequence. Then you get a dash light signaling it is activated. Wait till it does its little flashing lights show.
Don't forget to do it during a full moon.
Images: 463
Postby markmitchmarkmitch is online! » December 18th 2016, 11:15pm
anyone have the ability to do 1st gen vans? I need a chip burned eventually after I add vortec heads, headers etc for my V8 which is a 92 TBI 350
Firing on 7 Cylinders (L6)
Topics: 624
Images: 20
Extra Info: RS V8 AWD
Postby Corsemoto » December 18th 2016, 11:29pm
Thanks again Will.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby AstroWill [OP] » December 19th 2016, 12:36am
Mmusicman wrote:I'd LOVE to be able to adjust my timing and make a few adjustments on my 2000! I'll be watching here with interest!
Just carb the 2k, problem solved. ;)
Mmusicman wrote:My 92 can also sit dead for ANY length of time... and with fresh battery it will fire right up every time! :D
Your 2k should do that just the same, my 99 sat for about 3years, threw a battery in it, and it started just fine. I miss that low mileage beauty... :(
Mmusicman wrote:So... what do I need to get started? (not my 92..lol)
A carb ;)
I have thought about getting a programmer that I can get a deposit, send you the programmer, you flash your computer(would only work with the VIN you supplied) and then you send it back(or possibly to the next person) and I refund your deposit. Problem is that the programmers are a LOT more expensive than what you can get a used PCM for.
I want to keep this as cheap as possible for everyone, but I would like to recoup some of what I am going to put out for it as well.
The option that I think will work best for everyone right now is to mail me your PCM, I will hook it up next to the computer, read the original calibration, email you that calibration, make the changes, reflash to your PCM and then I mail it back to you. I can even set it up so that YOU do all of the changes to your PCM through the likes of Teamviewer or something similar.
I want to keep this as cheap as possible for everyone, but I would like to recoup some of what I am going to put out for it as well. What do you guys think would be fair for such a service? Send in a donation with your PCM ;)
I would like to get a few PCMs and wiring harnesses as well, so someone that lives in the lands where you get PCMs from the JY for $20, they could ideally grab two(or more) of their PCMs for $40(and the wiring harness as well please), send them to me, I program one and send it back so you can just swap it out with no down time and I get to keep the other(s).
Thoughts, ideas, please speak up.
Thanks again Will.
Any time.
markmitch wrote:anyone have the ability to do 1st gen vans? I need a chip burned eventually after I add vortec heads, headers etc for my V8 which is a 92 TBI 350
Just carb it ;) There is a slight chance that I get into these as well, but don't hold your breath.
Images: 463
Postby markmitchmarkmitch is online! » December 19th 2016, 3:06am
ahhh that won't work I live in Califormunism I mean communism california
Topics: 624
Images: 20
Postby redfury » December 19th 2016, 5:37am
I got a newer(411) PCM for my Astro from a guy on the GM performance forum for 99 shipped with a base tune about 3 years ago. A butt dyno tune locally would have cost me an additional 200 bucks, where a full Dyno tune would have been upwards 500.
So, your time is valuable, but we want to serve as many customers as possible, so figure out your time x the number of units you hope to see at that price point. If you invest 1500 into the software/hardware and only do 10 computers, then you are going to need 150 each to cover shipping costs, your time, and part of the cost of start up. You can always ala carte certain options if you want to...mostly depends on the logistics of the whole thing. If you do it like a group buy and you get 20 people to commit, then you can lower the cost.
redfury
Topics: 53
Images: 13
It is currently January 24th 2021, 11:21pm
Time: 4:14am
Date: Jan 10 '21
Time: 7:37pm
roachmon
Date: Jan 10 '21
Time: 4:04am
roachmon
Date: Jan 09 '21
Time: 6:34am
OldSchoolNoe
Comments: 9
Date: Jan 01 '21
Time: 8:46pm
Users browsing this forum: Google Adsense [Bot], SilkyModineSilkyModine is online! and 21 guests
