Time to change out fuel pump, 98 gmc safari, product advice
Postby rollinhome [OP] » March 10th 2011, 7:49pm
I have been on here, struggling with, at times, a loss of power. through discussion here and further diagnostics:pump pressure (52 at idle), other tune up attempts and more. I have decided to pull the tank down to check for something at times clogging the pick up screen. While the tank is down, i will replace the pump, air out lines to relieve any blockage. Is there a pump that has proven reliable.
thanks, ray
rollinhome
Years of Membership: rollinhome has been a member for 11 full yearsrollinhome has been a member for 11 full yearsrollinhome has been a member for 11 full yearsrollinhome has been a member for 11 full yearsrollinhome has been a member for 11 full yearsrollinhome has been a member for 11 full yearsrollinhome has been a member for 11 full yearsrollinhome has been a member for 11 full yearsrollinhome has been a member for 11 full yearsrollinhome has been a member for 11 full yearsrollinhome has been a member for 11 full years
Extra Info: WINDOWS WITH BED
  • fuel line rusted out
    by baily144 » June 2nd 2020, 5:30pm in Engines
    June 2nd 2020, 6:04pm
  • 2000 gmc safari died, wont restart
    by DAS2020 » May 24th 2020, 11:43pm in Engines
    May 26th 2020, 5:32pm
    65
    October 31st 2020, 5:53pm
Re: Time to change out fuel pump, 98 gmc safari, product adv
Postby paintdrying » March 10th 2011, 8:15pm
Almost everyone here will tell you ac delco only.
paintdrying
Years of Membership: paintdrying has been a member for 9 full yearspaintdrying has been a member for 9 full yearspaintdrying has been a member for 9 full yearspaintdrying has been a member for 9 full yearspaintdrying has been a member for 9 full yearspaintdrying has been a member for 9 full yearspaintdrying has been a member for 9 full yearspaintdrying has been a member for 9 full yearspaintdrying has been a member for 9 full years
Topics: 94
Extra Info: 108 000
Postby RECox286 » March 10th 2011, 11:29pm
Delphi and A/C Delco are the OEM parts for these vehicles. I have nothing against using those, however I have always gotten the Airtex brand, which is what my LAPS carries, and I have never had cause to complain.
Beware of the cheaper brands, especially if it has "Made in China" on it. (You pay for what you get and get what you pay for.)
Make sure to change both the in-tank filter, and the in-line filter when you change the pump.
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby rollinhome [OP] » March 11th 2011, 6:40am
Thanks all, I would typically have my mechanic complete this work though he let me down getting this condition diagnosed correctly, which caused loss of time with the van and loads of extra money. this has been a good van and i like to travel in it so
i will feel better once things are working reliably again.
so, i will follow the thread on this site for tank and pump removal and the advice to change out the inline filter, doing the repair my self.
ray
rollinhome
Postby rollinhome [OP] » March 11th 2011, 7:22am
So most here are using the OEM ac delco pump cartridge. Is there an online source that most use. I am seeing pricing from 280.00
to 380.00. Locally, advance auto carries the ac delco at a reasonable price.
rollinhome
Postby Gary » March 11th 2011, 7:28am
Delco only.History and reliability is the answer for why.I have a Airtex and nothing but regrets.Come further into spring I am going to take a running van and drop the tank to remove it and replace it with a Delco.Then create a new sport.How far can I throw the Airtex??. :2:
Gary
Dearly Departed
Firing on 4 Cylinders (L3)
Topics: 136
Extra Info: high top
Postby rollinhome [OP] » March 11th 2011, 7:47am
and a weighted rock to the airtex pump n it will go further. so, what is that cab and chassis rv in your response.
rollinhome
Postby Gary » March 11th 2011, 9:28am
It is a Chevy and a 81 Winnie.
Gary
Dearly Departed
Topics: 136
Postby Leeann_93Leeann_93 is online! » March 11th 2011, 11:01pm
Postby rollinhome [OP] » March 24th 2011, 4:36am
what is the part number for the fuel pump. I have a 98 gmc, v6 vortex eng. getgmjparts.com, does not have a listing for parts number though i may have missed it. I tryed reaching them by phone though i always end up at their voicemail with no one returning my call.
r
rollinhome
Postby Matrixx » March 28th 2011, 8:05am
ACDELCO Part # MU1782
DELPHI Part # FG0068
Information was gathered from here:
http://www.rockauto.com/catalog/x,carco ... ttype,6256
As for Airtex pumps? I'll keep my comments to myself on this one and suggest you do a site search for "Airtex" to find out the real scoop is on this sorry excuse of a pump it is.
Matrixx
Postby Gary » March 28th 2011, 8:21am
The short version on Airtex.They are pcs of crap that sucks.
Gary
Dearly Departed
Topics: 136
Postby Matrixx » March 28th 2011, 8:38am
Hehe, well I'm glad you said it and not me Gary.:)
Matrixx
Postby rollinhome [OP] » March 28th 2011, 4:20pm
thanks guys, it is warm enough in chicago for me to do this work in my unheated space. so, i am going get it out and see what it looks like.
I have heard that the wiring harness is a major problem with these and have seen them burned at the connector in the scrap yard. is it unreal to think that this may be, at times, the only repair to make when the connector is found to be melted or is it wise just to replace the pump, in view of it's age, with the upgraded harness and be done with the extensive labor. the later is how i am leaning.
It sounds like guys are fabricating the strapping. i have access to some stainless and have not seen a price for tank strapping
so i don't have a thought on this part of the work yet.
r
rollinhome
Postby Gary » March 28th 2011, 6:49pm
rollinhome wrote:thanks guys, it is warm enough in chicago for me to do this work in my unheated space. so, i am going get it out and see what it looks like.
r
It is the chicken or egg question.IF the wire harness is melted,is that happen as a result of a short in the harness OR the pump heating up and failing??.Do reread my post about the internal wire harness.These pumps rely on the fuel cooling the pumps.It is not a good idea to let the fuel level get below 1/4 tank because of that.
Gary
Dearly Departed
Topics: 136
Postby Leeann_93Leeann_93 is online! » March 28th 2011, 10:43pm
Yup, if the wiring harness is melted, you can be sure the pump is damaged. Whether the melted wiring harness caused the pump damage or a dying pump caused the melted harness, we'll never know.
But I'd never replace one without the other.
It is currently October 31st 2020, 5:53pm
Date: Oct 29 '20
Time: 11:54pm
Date: Oct 29 '20
Time: 8:41pm
Buzman63
Date: Oct 29 '20
Time: 2:06pm
kade225
Date: Oct 28 '20
Time: 11:27pm
djpigs
Date: Oct 27 '20
Time: 10:01pm
Users browsing this forum: 95AstroLT95AstroLT is online!, Leeann_93Leeann_93 is online! and 22 guests
