weird oil pressure problem?
Postby sambalayne [OP] » March 24th 2011, 3:27am
this started happening in my safari a couple days ago and it has me stumped so i used my iphone to video the gauge and maybe you lovely folks can tell me whats what.normally when idling the gauge sits at about half and anything above idle its up all the way. its been like that since i bought the van a couple years ago. is it even normal for the gauge to be all the way to max with the engine at anything above idle? anyway this problem only happens at idle. HELP! is it even a problem or just something engines do as the get older (mine has 170K)
EDIT: youtube is n00bing it up. hers the link http://www.youtube.com/watch?v=AgyFMcFrPi4
23,862 miles since last oil change and counting.
sambalayne
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: sambalayne has been a member for 9 full yearssambalayne has been a member for 9 full yearssambalayne has been a member for 9 full yearssambalayne has been a member for 9 full yearssambalayne has been a member for 9 full yearssambalayne has been a member for 9 full yearssambalayne has been a member for 9 full yearssambalayne has been a member for 9 full yearssambalayne has been a member for 9 full years
Topics: 10
Extra Info: AWD 4.3L...POS
  • Correct Oil Pressure Reading
    by Safarimeister » August 19th 2020, 12:42am in Engines
    Last post by Safarimeister View the latest post
    August 19th 2020, 1:11am
  • Lost oil ptessure, oil all over motor
    by equitube » September 26th 2020, 1:51am in Engines
    September 26th 2020, 3:25am
    9
    44
    December 1st 2020, 12:46pm
Re: weird oil pressure problem?
Postby RECox286 » March 24th 2011, 4:23am
Don't rely on what the gage is doing to be honest. This could be a problem with the sending unit, the gage or the wiring in between. Get a pressure gage and plug in where the sending unit is... Then tell us what it really is doing.
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby 'cudapaul » March 24th 2011, 4:24am
Try replacing the sending unit.
Had the same problem in my 91 and 94.
'cudapaul
Years of Membership: 'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years
Alias (AKA): 'cudapaul
Extra Info: LT AWD
Postby a2l1 » March 24th 2011, 6:14am
You might want to test the gauge first. The specs are in the shop manual There are set parameters and readings for the gauge on a tester. if it tests good then try the same for the sending unit. Most people discount it but there is always the possibility of the wiring between the two. Before buying parts its always better to test. Fifty cents for a section of wire or a connector seems better than an new sending unit.
The point is that it can be several different things that can create this problem and rather than just replace parts it would be better to test things then repair/replace the item that is the problem.
Lots of help here huh.Good luck
1995 Regency conversion really a work in progress !!
Hernando County - West Central Florida
a2l1
Years of Membership: a2l1 has been a member for 9 full yearsa2l1 has been a member for 9 full yearsa2l1 has been a member for 9 full yearsa2l1 has been a member for 9 full yearsa2l1 has been a member for 9 full yearsa2l1 has been a member for 9 full yearsa2l1 has been a member for 9 full yearsa2l1 has been a member for 9 full yearsa2l1 has been a member for 9 full years
Topics: 73
Alias (AKA): A J
Extra Info: 4.3-auto-RWD
Postby sambalayne [OP] » March 25th 2011, 5:55am
was a bad connection. got it patched up works great now! thanks guys
sambalayne
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 10
Postby RECox286 » March 25th 2011, 6:32pm
Thank you for letting us know what happened, and that you got er done !
Love to hear feedback. Gives us a warm fuzzy feeling.
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Postby justinf89 » April 8th 2011, 3:09pm
sambalayne wrote:was a bad connection. got it patched up works great now! thanks guys
If you don't mind, where was the bad connection? Mine's been acting up for a while now. Thanks.
justinf89
Years of Membership: justinf89 has been a member for 10 full yearsjustinf89 has been a member for 10 full yearsjustinf89 has been a member for 10 full yearsjustinf89 has been a member for 10 full yearsjustinf89 has been a member for 10 full yearsjustinf89 has been a member for 10 full yearsjustinf89 has been a member for 10 full yearsjustinf89 has been a member for 10 full yearsjustinf89 has been a member for 10 full yearsjustinf89 has been a member for 10 full years
Topics: 37
Extra Info: RWD
It is currently December 1st 2020, 12:46pm
Attached by: icebrrg3rd
icebrrg3rd
Date: Today
Time: 12:16am
djpigs
Comments: 42
Date: Nov 26 '20
Time: 11:23pm
Date: Nov 26 '20
Time: 12:43am
Attached by: Slime
Slime
Date: Nov 24 '20
Time: 11:11pm
K-TRON
Comments: 23
Date: Nov 16 '20
Time: 1:07am
