First post here! Been a long time lurker thinking about building an Astro camper conversion. Finally pulled the trigger on a 1999 in pretty good shape except for a leaky intake manifold. Got that job done along with a new water pump, hoses, and whatever little things I could think of replacing while I was in there.
I ended up replacing the radiator cap with a 16 psi cap but after reading a bit here I decided to go down to a 13 psi instead just to keep the pressure down a bit. Only problem is if you search for a 13 psi cap for a Chevy Astro you're not going to find one at a parts store.
I ended up buying a Stant 10329
https://www.amazon.com/Stant-10329-Lev-R-Vent-Radiator-Cap/dp/B000B8N3IM
Seems to fit just fine but I haven't tried using it yet. I'm curious if this is the same cap others on here are using.
Thanks for any help!
