I've even tried yelling at it, still won't start
Postby mtjarrett [OP] » April 28th 2011, 3:41am
Here's what I know:
-2001 Astro, 215k miles
-in the past several months, every now and then it just won't start. cranks and cranks but won't catch. day or two later, no problem.
-every now and then throws up P0300 (random cylinder misfire) and at other times throws up a random cylinder misfiring (eg P0304 or P0303)
-it has head / head gasket issues. doesn't overheat, but uses up coolant
-last week, while driving down the road, engine lost power and then cut off. cranked back up after a few minutes but only ran with minimal power a few yards and then died again. hasn't started since.
-in the driveway, it will crank and crank but never catch. every now and then it seems like one cylinder might fire but not enough to actually start
-gas smell is strong after cranking for several seconds
-no codes on the OBDII
Here's what I've done:
(in the past)
-changed fuel pump and filter August 09
-changed cap and rotor December 09
-changed plugs and wires December 10
(today)
-new ICM
-new coil
-getting spark at spark plugs (checked one)
-spark plug smelled like gas (but otherwise clean)
-behavior doesn't change with starter spray
After changing the coil, it did in fact start for about 5 seconds, ran rough then died. Now sounds exactly the same as before changing coil and ICM.
Thoughts????
mtjarrett
Years of Membership: mtjarrett has been a member for 9 full yearsmtjarrett has been a member for 9 full yearsmtjarrett has been a member for 9 full yearsmtjarrett has been a member for 9 full yearsmtjarrett has been a member for 9 full yearsmtjarrett has been a member for 9 full yearsmtjarrett has been a member for 9 full yearsmtjarrett has been a member for 9 full yearsmtjarrett has been a member for 9 full years
  • No Start, Here's What I've Done
    by zippy » January 16th 2021, 7:46am in Engines
    Last post by zippy View the latest post
    January 19th 2021, 9:25pm
  • New Fuel Pump, Still 0 PSI
    by OldSchoolNoe » Yesterday, 2:05am in Engines
    Last post by OldSchoolNoe View the latest post
    Today, 4:54pm
    38
    March 6th 2021, 6:44pm
Re: I've even tried yelling at it, still won't start
Postby chevymaher » April 28th 2011, 8:20am
check compression you already said it got head gasket issues.check for fouled plugs while they out for compression check.check and see if water getting in oil (head gasket thing)check PVC see if anything in there again moisture from gasket.Find out where coolant going would be the biggie to me.if it getting in engine it could ruin it.
Postby fast68 » April 28th 2011, 9:26am
since theres lots of fuel i would go with a new ICM
fast68
Years of Membership: fast68 has been a member for 11 full yearsfast68 has been a member for 11 full yearsfast68 has been a member for 11 full yearsfast68 has been a member for 11 full yearsfast68 has been a member for 11 full yearsfast68 has been a member for 11 full yearsfast68 has been a member for 11 full yearsfast68 has been a member for 11 full yearsfast68 has been a member for 11 full yearsfast68 has been a member for 11 full yearsfast68 has been a member for 11 full years
Topics: 12
Alias (AKA): fast
Extra Info: 4.3L Z EXT RWD
Postby NY Safari TONKA » April 28th 2011, 3:40pm
Ok try re checking sparkplugs take them out and one by one chk if the ceramic moves...if all good make sure gap is correct ;another think it could be your fuel pressure regulator...Lets us know how it goes! dont :banghead:...hey also if you going to change it you can use the Kit less $$$ less metal jajaja
NY Safari TONKA
Years of Membership: NY Safari TONKA has been a member for 9 full yearsNY Safari TONKA has been a member for 9 full yearsNY Safari TONKA has been a member for 9 full yearsNY Safari TONKA has been a member for 9 full yearsNY Safari TONKA has been a member for 9 full yearsNY Safari TONKA has been a member for 9 full yearsNY Safari TONKA has been a member for 9 full yearsNY Safari TONKA has been a member for 9 full yearsNY Safari TONKA has been a member for 9 full years
Extra Info: AWD EXT 4.3L V6
Postby mtjarrett [OP] » April 28th 2011, 8:55pm
the answer was....
bad distributer. somebody on one of these forums had the same issue a while back. anyhow, now we got a different issue.
i keep getting a P0351 code. gonna post as a new topic though. thanks for the help.
mtjarrett
It is currently March 6th 2021, 6:44pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 02 '21
Time: 2:20pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 01 '21
Time: 7:27pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
Users browsing this forum: No registered users and 26 guests
