98 Astro Won't Start , Confused!
Postby justjanets [OP] » April 19th 2017, 12:30am
Someone please help me!? My astro is giving me problems with not starting at all. Put the key in the ignition and turn to start and I get a click. Don't call me a dummy now...lol . I have replaced the battery with a new one. It had originally started out with this and then I would be able to try to start it again and it would turn the engine over and start, now it won't. I can actually jump start it though. But to try to start it without getting a jump won't work. Could it be the ignition? I dunno, I'm a newbie to trying to fix on my own and a poor person to take it to a mechanic. Any suggestions would be greatly appreciated!
justjanets
Years of Membership: justjanets has been a member for 3 full yearsjustjanets has been a member for 3 full yearsjustjanets has been a member for 3 full years
  • 1992 Astro wont start
    by diceman » September 27th 2020, 2:34pm in Engines
    September 27th 2020, 6:03pm
  • Astro wont start, has spark and fuel
    by OrangeToad10 » December 4th 2020, 8:16am in Engines
    December 18th 2020, 9:06pm
    30
    February 26th 2021, 7:50pm
Re: 98 Astro Won't Start , Confused!
Postby dramey » April 19th 2017, 1:27am
It sounds to me like you run the battery down. Connect a voltmeter to the battery and see how many volts the battery has. If it is less than 12 volts, then charge the battery.
dramey
Firing on 7 Cylinders (L1)
Extra Info: AWD Cargo Van
Postby Davo2530 » April 19th 2017, 1:53am
Welcome, You said you put a new battery in and it still won't start, but will if you jump it. A few things to check would be the connections to the battery, make sure they are clean and tight. Next check the connection of the ground lead to the motor, make sure it is clean and tight. Next check the connection to the starter and make sure it is clean and tight.(a little harder to get to but not overly difficult.) Make sure the Battery has 12 volts, I have gotten defective new batteries in the past, it can happen. Check those things out and let us know what you find.
Davo2530
Years of Membership: Davo2530 has been a member for 5 full yearsDavo2530 has been a member for 5 full yearsDavo2530 has been a member for 5 full yearsDavo2530 has been a member for 5 full yearsDavo2530 has been a member for 5 full years
Topics: 20
Alias (AKA): Dave
Van Model Year: 2002
Extra Info: 186kmiles
Postby Astrofarian » April 19th 2017, 2:00am
dramey wrote:It sounds to me like you run the battery down. Connect a voltmeter to the battery and see how many volts the battery has. If it is less than 12 volts, then charge the battery.
^^^^^^^^^^Yup, START there (no pun intended). Then, move on to checking/cleaning/securing EVERY ground you can find; then, do the same with all the ones you CAN'T find. lol
Seriously, this CAN be a great opportunity to learn an awful lot about your van. Work safely and pop back with questions. Someone will be more than happy to help you along. And no matter HOW much someone knows, there was a time when they knew less than you so don't get intimidated with tech-speak and jargon. Best of luck to you!
-M!ke-
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby dramey » April 19th 2017, 4:28am
I know that everyday that I live, I know less than I did the day before.
dramey
It is currently February 26th 2021, 7:50pm
Ken2.7Ken2.7 is online!
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
Attached by: WinnieVan
WinnieVan
Date: Feb 23 '21
Time: 8:07am
Date: Feb 22 '21
Time: 11:43pm
Users browsing this forum: AstrojohnAstrojohn is online!, Yandex [Bot] and 31 guests
