changed tranny now starting problem
Postby bernie1951 [OP] » May 13th 2011, 2:56am
Hopefully I've forgotten something or have freak coincidence and am hoping for your help. I bought a 2001 Astro, 225K one owner miles. Always serviced meticulously and in excellent shape. AWD and tranny problems. Drove it home drove and ran excellent. Acted like clam shell broke, removed tranny had it rebuilt (yes on the clam shell).reinstalled tranny and it would crank but no start. Left it overnight, tried to start it next day noo start. Had to leave town to work. Came home a week later went out tried to start it and it fired right up and ran great. topped off tranny fluid, refilled transfer case and eased it out of the garage still running great went for a short drive did great. Restarted fine . Later in the day went to move it and no start. Next day reached in and started perfectly. Next day no start again . Had to leave town again and it's sitting in the driveway. Have I forgotten something simple? Going home next weekend and don't have a lot of time before I have to leave again. Any ideas of something I missed so I don't have to spend all the time troubleshooting. Or is this just coincidence that something went out at the same time I changed the tranny. You guys seem to have encountered all the normal and bizzare problems and I'm just trying to cheat some time. Thanks to anyone with any suggestions. I can hear the fuel pump running and have voltage at the coil are the only two quick checks I had time to do .
bernie1951
Years of Membership: bernie1951 has been a member for 10 full yearsbernie1951 has been a member for 10 full yearsbernie1951 has been a member for 10 full yearsbernie1951 has been a member for 10 full yearsbernie1951 has been a member for 10 full yearsbernie1951 has been a member for 10 full yearsbernie1951 has been a member for 10 full yearsbernie1951 has been a member for 10 full yearsbernie1951 has been a member for 10 full yearsbernie1951 has been a member for 10 full years
Re: changed tranny now starting problem
Postby NY Safari TONKA » May 15th 2011, 6:51am
If it does not go ON tap the starter and see...We will get you to do the Banana :banana: Dance ok...jajaja...
NY Safari TONKA
Years of Membership: NY Safari TONKA has been a member for 9 full yearsNY Safari TONKA has been a member for 9 full yearsNY Safari TONKA has been a member for 9 full yearsNY Safari TONKA has been a member for 9 full yearsNY Safari TONKA has been a member for 9 full yearsNY Safari TONKA has been a member for 9 full yearsNY Safari TONKA has been a member for 9 full yearsNY Safari TONKA has been a member for 9 full yearsNY Safari TONKA has been a member for 9 full years
Extra Info: AWD EXT 4.3L V6
Postby cowboydan » May 23rd 2011, 4:19pm
loose connection, bad ground, or broken battery terminal. i might lean towards a loose connection in this case. side post batteries will strip out threads long before the post will break.
check that your flexplate bolts are tight along with the starter bolts. starter solnoids can go when ever they want because of it's proximity to the exaust.
2006 sebring 2.7 touring: DD
cowboydan
Firing on 8 Cylinders (L2)
Topics: 67
Alias (AKA): cbd
Extra Info: 4.3w CL AWD
Postby Leeann_93 » May 23rd 2011, 9:51pm
Tell us what it does when it won't start. Click-click-click? Nothing? Cranks, but doesn't fire?
Postby rev_les » May 24th 2011, 9:10pm
That's an odd one....the last time ( which was the 2nd time) I replaced the transmission on my '99, I got it all in, and it would crank but not start. I went out of town for a week, and it fired right up when I got home. Mine however, has been fine ever since....it didn't start doing it again. :confused:
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby bernie1951 [OP] » May 28th 2011, 1:03pm
Thanks guys, It cranked but wouldn't start. Happened to be coincidence I guess when I changed the tranny but turned out the coil took a crap. Replaced it and fired right up. thanks
bernie1951
Postby cowboydan » May 28th 2011, 11:49pm
should have had a diaper on standby eh? glad to see your rocking now!
cowboydan
Topics: 67
Alias (AKA): cbd
It is currently November 29th 2020, 8:28pm
djpigs
Comments: 42
Date: Nov 26 '20
Time: 11:23pm
Date: Nov 26 '20
Time: 12:43am
Attached by: Slime
Slime
Date: Nov 24 '20
Time: 11:11pm
K-TRON
Comments: 23
Date: Nov 16 '20
Time: 1:07am
Attached by: Devonian
Devonian
Date: Nov 13 '20
Time: 2:19am
Users browsing this forum: sixsixsixsix is online! and 10 guests
cron
