95 Fuel pressure reulator?
Postby pauledude [OP] » May 21st 2011, 1:55am
Pulled the plenum off. I have the the CMFI (airbox on fan shroud) Turn the key, and fuel comes out the regulator??
Is this a cold start? Or bad?
No injectors leak, but it runs rough.
Thanks.
Debating on putting new injectors in it. or taking off my 4WD stuff and junking the rest. I realy want a full size :)
pauledude
Years of Membership: pauledude has been a member for 12 full yearspauledude has been a member for 12 full yearspauledude has been a member for 12 full yearspauledude has been a member for 12 full yearspauledude has been a member for 12 full yearspauledude has been a member for 12 full yearspauledude has been a member for 12 full yearspauledude has been a member for 12 full yearspauledude has been a member for 12 full yearspauledude has been a member for 12 full yearspauledude has been a member for 12 full yearspauledude has been a member for 12 full years
Topics: 12
  • 2003 Fuel pressure regulator location
    by fitter » November 4th 2020, 8:55pm in Engines
    November 4th 2020, 9:24pm
  • 4.3L V6 Hesitant To Start When hot - Fuel Pressure Test
    by K-TRON » November 5th 2020, 4:42am in Engines
    November 17th 2020, 3:05am
    7
    88
    March 2nd 2021, 5:19pm
Re: 95 Fuel pressure reulator?
Postby Leeann_93 » May 21st 2011, 2:06am
Bad. The diaphragm is leaking.
To replace the fuel pressure regulator will cost you about $40 - it's a Dorman/HELP! part available at your local autoparts place...I got one at AutoZone. It'll come with the Torx security bit required to remove the old and install the new.
Postby Mr_Bowtie » May 21st 2011, 2:22am
X2 just do the regulator and it will run great again.
Fullsize? :naughty: :lol:
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
Postby Casey » May 17th 2014, 4:43pm
Leeann_93 wrote:Bad. The diaphragm is leaking.
Gah. I was wondering why the Dorman part included a Torx bit...Didn't see this message in my searches, and noticed the "security" part. Off to Sears I go. ;)
Casey
Years of Membership: Casey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full years
Topics: 24
Extra Info: 4.3L LT 5-speed
Postby Casey » May 18th 2014, 9:48pm
Is each plastic injector housing(?) supposed to have a rubber o-ring on it? I've seen them listed for sale, new/re-man spiders don't seem to include them, and my '95's injectors didn't have any when I removed them:
Casey
Topics: 24
Postby chevymaher » May 18th 2014, 11:09pm
Casey wrote:Is each plastic injector housing(?) supposed to have a rubber o-ring on it? I've seen them listed for sale, new/re-man spiders don't seem to include them, and my '95's injectors didn't have any when I removed them:
yes they should.
Postby Casey » May 18th 2014, 11:52pm
Looking at images of new, re-man, and used spiders again, I don't see any which have o-rings installed. I'd like to see a pic of a spider with o-rings in place if anyone has one.
Casey
Topics: 24
Postby Leeann_93 » May 19th 2014, 12:03am
On neither my '93 Bravada nor my '93 Astro were there o-rings on the poppets. There were o-rings on the 'nut kit' - the fuel lines that push into the spider and an o-ring on the fuel pressure regulator on the other side.
Postby chevymaher » May 19th 2014, 12:36am
Could be. I always buy a set if they are not there. I just thinking it is better suckin gas than air from the upper intake area.
Postby Leeann_93 » May 19th 2014, 12:42am
You're probably right. Can't hurt, especially if the poppets click in place as needed.
It is currently March 2nd 2021, 5:19pm
Attached by: MHM
MHM
Comments: 18
Date: Today
Time: 2:20pm
Attached by: MHM
MHM
Comments: 18
Time: 7:27pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
Users browsing this forum: WoodButcherWoodButcher is online! and 19 guests
