Hard Starting When Engine Is Cold...
Postby pharbach [OP] » June 3rd 2017, 8:53pm
I have a 2001 Astrovan. It runs fine, accelerates fine and does highway speeds without hesitations or bucking. However, it is a bear (sometimes....to "usually") to start when its the first start of the day, and the engine is cold. I always have to cross my fingers to hope the thing starts. Once it has been running for awhile and I shut it down, I can start it up with no problems until the engine goes cold again either overnight or during the day while I am working at work. I live in Florida, so there is no freezing weather, just normal cooling down of the engine to cold merits a war in trying to start the van up again risking the battery going dead. I can't hear the fuel pump running, but that doesn't mean its not running, as it WILL start eventually with patience after numerous attempts. The fuel filter has been replaced recently, along with spark plugs, wires, rotor and distributor cap. I don't suspect a spark problem, as as long as it starts, the van performs well. I am leaning towards some sort of fuel problem or whatever kind of temp sensor controls the MAF sensor, or other temp sensor involved in fuel delivered to the engine thru the ECU. Am I on the right track here ??
pharbach
Years of Membership: pharbach has been a member for 7 full yearspharbach has been a member for 7 full yearspharbach has been a member for 7 full yearspharbach has been a member for 7 full yearspharbach has been a member for 7 full yearspharbach has been a member for 7 full yearspharbach has been a member for 7 full years
Topics: 5
Alias (AKA): Paul
Extra Info: LS 4.3L V6 RWD
  • Hard Cold Start and Rough Idle. No Codes. Diagnosis?
    by AstroTan » October 17th 2020, 5:26am in Engines
    Last post by AstroTan View the latest post
    December 31st 2020, 5:53pm
  • starting issues, backfire. 2000 Astro 4.3
    by popehentai » December 13th 2020, 2:47pm in Engines
    Last post by Astrojohn View the latest post
    February 3rd 2021, 6:06pm
    9
    43
    February 25th 2021, 11:56am
Re: Hard Starting When Engine Is Cold...
Postby Leeann_93 » June 3rd 2017, 9:48pm
So the engine turns over, just doesn't start?
Next time, do KOEO (key on engine off) for three seconds, then off, then KOEO for 3 seconds, then off, then KOEO for 3 seconds, then try to start.
Three fuel pump prime cycles should be good.
Postby AstroWill » June 3rd 2017, 9:54pm
A cheap OBD2 adapter will show you what the computer is seeing from various sensors.
Images: 471
Postby pharbach [OP] » June 3rd 2017, 10:02pm
Leeann_93 wrote:So the engine turns over, just doesn't start?
Okay...........I will try that method..................will let you know how it goes........
AstroWill wrote:A cheap OBD2 adapter will show you what the computer is seeing from various sensors.
I have an Actron OBDII Scan Tool. No Codes.................
pharbach
Topics: 5
Alias (AKA): Paul
Postby AstroWill » June 3rd 2017, 10:06pm
A lot of those will only show you fault codes, not live data, depending on the model. You can get bluetooth adapters to use with your smartphone/tablet for about $7 with shipping, see the link in my sig.
Images: 471
Postby pharbach [OP] » June 3rd 2017, 10:34pm
The OBDII Scanner does live data.................will check it out.................thanks
pharbach
Topics: 5
Alias (AKA): Paul
Postby pharbach [OP] » June 11th 2017, 3:58am
I am getting to feel that my fuel pump pressure is low. I would like to test it with a fuel pump pressure gauge. Where exactly IS the port to check the fuel pressure? Will I have to remove the doghouse, or is it accessible under the hood ??
pharbach
Topics: 5
Alias (AKA): Paul
Postby chevymaher » June 11th 2017, 4:42am
Doghouse off right rear of engine.
Postby Astro Pop » June 11th 2017, 4:57am
Are you saying it turns over at a normal speed and it takes a while to start or is it slow to turn over? Quick and simple way to tell if it's fuel related is to shoot some starter fluid down the intake while trying to start. If it fires you're on the right track of fuel problems. If not you still need to continue on with spark problems.
Astro Pop
Topics: 41
Images: 9
Alias (AKA): Xfirepop
Van Model Year: 1996
Extra Info: AWD - 5 inch lift
Postby Leeann_93 » June 11th 2017, 2:16pm
Just to clarify: Randy means driver's side rear.
Postby pharbach [OP] » June 11th 2017, 4:10pm
Alright, will have to either borrow or buy a fuel pressure tester........
pharbach
Topics: 5
Alias (AKA): Paul
It is currently February 25th 2021, 11:56am
Ken2.7
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
Attached by: WinnieVan
WinnieVan
Date: Feb 23 '21
Time: 8:07am
Ken2.7
Date: Feb 22 '21
Time: 11:43pm
Users browsing this forum: No registered users and 17 guests
